KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
10-13-2011, 05:43 PM | #1 |
Rep 156
Pros/Cons of running 245/35/19 and 275/30/19 instead of stock sizes
Hi all,
I need to replace my stock PS2's with Pilot Super Sports, but Tire Rack is back ordered for 2 months on the stock size rears...so I'm pondering a change to 245/35/19 and 275/30/19's, but am wondering what the pros/cons are of the switch beyond the visual change. Any help would be greatly appreciated. |
10-13-2011, 06:02 PM | #2 |
Rep 5,678
275/30 rears are too short... you should go 275/35. I ran that and the difference from 265/35 is very small from a visual perspective and gives only a slight improvement in traction.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
10-14-2011, 12:03 PM | #4 |
octane chick
81
Rep 1,187
Drives: ex-M
You're one of several people who have posted this question. I suggest some searching.
Also consider different tires. PSSs are nice, but they're not exactly in a class of their own. |
10-14-2011, 12:57 PM | #6 |
Rep 15,818
245/35 275/35 will be better than 275/30
if you must do a 30 series profile, do a 285/30
10-15-2011, 07:40 AM | #7 |
Rep 751
The potential issue I see, the rear would be a slightly smaller OD than the front. Since DSC is programmed with a larger rear OD, the wheel rpm is going to be indicating wheel spin (in error) much earlier, so if you use DSC, you may see it activate prematurely. I use a set of 275/35-18, and I can detect a small difference in DSC activity with equal sizes all around. I use them mostly on track with DSC off, so it's not an issue. I suggest using the 255/35 and 275/35 combination on your OE 19" wheels.
10-15-2011, 01:53 PM | #8 |
Rep 5,678
IMO, the PSS is pretty much in a class of its own as a street performance tire as it gets everything right (right, quiet, responsiveness, grip, wet). If you are using the tires on the track, then I agree that the RE-11 and AD-08 are better.
10-15-2011, 07:38 PM | #9 | |
Rep 2,940
You could go: 255/35 and 275/35 255/35 and 295/30 (This will give you equal F/R rolling diameter) 245/35 and 285/30 (This will give you equal F/R rolling diameter)
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner |
10-16-2011, 08:40 AM | #10 |
Rep 156
Great feedback everyone. Yes, I've searches across the threads, but wasn't finding the feedback I was hoping for. This all helps and $ aside I do feel the PS2s and PSS are the best tires for mixed use (primarily street with occasional hot laps at the track).
Hoeferland | 2008 E90 M3 | Alpine White | 6MT | 20" HRE P40s | Full Active Autowerke Cat-less Signature System | BPMSport Stage 2 Dev Tune | Eibach Springs & E36 Bumps | EvoSport Underdrive Pulley
