10-26-2011, 11:45 PM | #1 |
Rep 2,266
Will E9X Brembo Brakes fit 1M?
Does anyone have any idea? I have a 380mm GT kit, and I have a friend's friend who's interested.
Cheers
Ben |
10-27-2011, 12:46 AM | #3 |
Supreme Allied Commander
3885
Rep 54,495
Drives: F80 M3
10-27-2011, 12:56 AM | #4 |
Rep 2,266
Specifically, it's an E92 m3 BBK. Thanks.
Unfortunately, I'm in Canada, and he's in Hong Kong. Probably easier to sell to the same car, but since he's a good friend of a close friend, it's worth the trouble.
Cheers
Ben |
10-27-2011, 12:59 AM | #5 |
3885
Rep 54,495
Drives: F80 M3
Yes, direct bolt on.
We(Stoptech) basically fitted the E9X M3 front and rear Stoptech Trophy BBK on our 1M on the day of the R&D and everything is the same. 1M shares just about all the suspension hardware with the M3 with the exceptions of brake pad compound, spring rates, ARB size and damper valving. If you want to consider subframe part of the suspension, the 1M uses the 135i front subfame. |
10-27-2011, 01:03 AM | #6 | |
Rep 2,266
Now you got me intrigued on whether my Moton's fit on his car! Haha!
Cheers
Ben |
10-27-2011, 01:20 AM | #7 |
3885
Rep 54,495
Drives: F80 M3
10-27-2011, 02:50 AM | #8 | |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
10-27-2011, 03:11 AM | #9 | |
Rep 2,266
I'm using Hyperco 800# front springs and 1100lb rear springs with KW CS Camber plates. Using helper springs, and KW Perches on the rear. Would that be way too much for the car? For now, I'm keeping my suspension until I fully part out, but interested to see what options I have.
Cheers
Ben |
10-27-2011, 11:13 PM | #10 | |
3885
Rep 54,495
Drives: F80 M3
My DD that will see some track days is on 400F and 750R with AST4200 I like to run the softest spring I can get away with for the most mechanical grip and buy the best dampers I can afford. |
10-27-2011, 11:16 PM | #11 | |
Rep 2,266
Thanks for the great insight/advice as usual.
Cheers
Ben |
10-28-2011, 02:13 AM | #13 |
Rep 2,266
Mike I never got a reply to our previous email. Could you reply to it again?
Cheers
Ben |
