KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
11-13-2011, 05:46 PM | #1 |
Rep 1,672
Pros and cons of a wider front tire
Hi everyone - I've been reminiscing about the pros and cons of a wider front - I've got lots of opinions on it but would like to know what you guys think
BTW I run 275/30/19 front, 295/30/19 rear with stock ZCP's and 275/35/18 front, 285/35/18 rear with apex arc-8 10 and 10.5's at the track |
11-13-2011, 07:20 PM | #2 |
Rep 5,482
Lack of feel and worse bump steer for not much grip improvement, worse aero, its a bandaid for classes or chassis that cant be set up to rotate around a more staggered setup. Considering our cars and their unfavorable weight distribution i think a 275-ish front is a necessary evil.
11-13-2011, 07:40 PM | #3 | |
Rep 2,190
I don't find it that bad with the stock 245/265 in PS2 form. However, add grip to the chassis and it starts pushing (245/265 PSS). It may be more fun on 245 or 265 all around... DSC issues notwithstanding... hrmmm |
11-13-2011, 07:50 PM | #4 |
11818
Rep 23,187
I run a square set on the track. 265-30-19 and it does get rid of a lot of understeer, but still does it. Much more neutral I feel with this set up.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
11-13-2011, 08:06 PM | #5 |
Rep 2,190
Good to hear! Even a very neutral car is going to understeer if you go in with too much entry speed and steady state throttle.
11-13-2011, 08:48 PM | #7 | |
Rep 1,672
I'm planning to go with an ess kit and bump up the power to 600hp so I'm likely to go 315's in the back and keep 275's up front. |
11-13-2011, 09:51 PM | #8 |
Rep 8,077
Drives: 11 E90 M3 Individual
I don't think BMW setup the camber to be adequate for serious track use. During my PCD, I noticed that the M3 I was in had pretty bad wear on the outer edges as well as the M5s that the instructors were driving.
I think wider front tires with more negative camber will usually be a given at the track for those who are pretty fast drivers. Comparing the M3 to other cars...I think the fact that we can get almost 2 degrees in the front is pretty good.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
11-13-2011, 11:29 PM | #9 |
Rep 4,319
I run a 275 front and just switch back to my 245 front for winter. It was remarkable how much lighter and more fluid it felt. There is no mistaking the grip from a wider front (though not as much as you would expect if sticking with the stock suspension), but I kind of miss that lighter feeling with more feedback. When the 275s wear out I will likely step down to a 255/275 combo.
GT3 RS | Desperately seeking the next great M car...
11-13-2011, 11:43 PM | #10 | |
Rep 2,190
Good idea... 275 fronts are huge... |
11-14-2011, 09:57 AM | #11 |
Rep 1,962
A simple pros/cons would be:
Pros: More Grip Cons: More Weight Less steering wheel feel (less crispy feeling)
Peanut Butter Chunky
11-14-2011, 11:57 AM | #13 | |
Rep 4,319
It was just stark going back to a 245 front how much more feel came back through the wheel. I wish I could put the 275s out back and buy new 255 fronts but I need a 275/35 and not a 275/30.
11-14-2011, 11:58 AM | #14 |
Rep 4,319
BlackLight, you won't get the right OD with those compared to stock (if that matters to you.)
11-14-2011, 12:35 PM | #15 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
255/35front and 275/35 rear are the best compromise
at least for the street
