KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
12-07-2011, 02:29 AM | #1 |
Rep 340
wheel fitment for e90 m3 ? question help
hi everyone
i m new (used ) owner of a 2009 bmw m3 4dr i have a few questions about the wheel fitment i see many here using 18x 9.5 + 22 offset front , 18x 10.5 + 22 offset rear (volks wheel) i want do 18s also , but question is 18 x 10.5 + 22 offset ( with rs3 285 18 30) rear will this fit flush ? or does this require spacer ? rolling the rear fenders? if not flush can i do 18 x 11 +18 offset rear ( if i m doing the math correctly , thats only about 10mm wider then 18 x 10.5 + 22 offset) so the final question is if i m using 18 x 9.5 + 22offset front ( w/ rs3 18 35 265) and 18 x 11 + 18 offset rear ( w / rs3 18 30 285 ) will this fit ? please help . thank you so much |
12-07-2011, 03:20 AM | #2 |
Rep 632
Drives: 2011 E90 M3, 2018 F87 M2
265/35/18 in the front will be good. I recommend 285/35/18 in the rear.
I have the same offset Volks and run those sizes in the NT-05 with no issues. 18x11 +18 sounds pretty aggressive.
12-07-2011, 04:58 AM | #3 | |
Rep 5,937
Not positive about the e90 but there is no fender to roll on the e92 - I think it's the same for the e90. |
12-07-2011, 10:06 AM | #4 |
Rep 277
18x11 +18 will sit nice and flush. I have a e90 m3 too with 18x9.5 +12 and 18x10.5 +12 with 265/35 and 285/35 Michelin PSS. I did some calculations and your 18x11 +18 wheels will sit exactly where mine are but will probably fit better since your 285 will stretch just a tad on the 11 vs my 10.5. I rub very little, nothing to fuss about. It's mainly on the plastic fender lining where the bumper and body meet. Easily fixed with a dremel. No one will be the wiser.
12-07-2011, 08:11 PM | #5 | |
Rep 340
so 18x 9.5 + 12 on the front will not rub? thanks for ur help |
12-08-2011, 12:09 AM | #6 |
Rep 277
depends on your tire choice. i do rub, but very very little. since the front fenders are plastic i will probably just dremel off about 2-3mm of the inside fender lip to get rid of it. but it doesn't really bother me. to me the michelin pss looks to have a rounder sidewall than other brands so your results may vary. i running about -2.3 degree camber front and -2 rear.
12-08-2011, 12:15 AM | #7 | |
Rep 340
wow thx for the info i have 2 sets of front tires here, if i m using 18x 9.5 + 15 what is a better choice , rs3 255 18 35 or rs3 265 18 35? thanks so much |
12-08-2011, 02:10 PM | #8 |
Rep 277
difficult to say since i dont have any experience with rs3's. i would just go with 265. 255/35 will be smaller in OD, 265/35 is already smaller in OD by 0.4" from stock.
12-08-2011, 06:52 PM | #9 | |
Rep 340
thx man . that helps alot already i just ordered my te37 sl mag blue. hopefully it will look ok thx again |
