12-14-2011, 04:50 PM | #1 |
BimmerPost Supporting Vendor
549
Rep 5,695
▀▄ eas | Practically Brand New Dinan Fixed Camber Plates for e9x M3
We have a set of Dinan camber plates from a customer that has decided to not install it on his car. These have never been installed on the actual car, just put together onto the upper mount of the OEM strut.
Here are the pictures: Information from Dinan: Front Camber Plates are now available for use with the Stage 1 Suspension. While the M3s are now provided from the factory with a significant range of camber adjustment, the Dinan camber plates shift the range of the adjuster by -0.7 degrees, providing for a more aggressive negative camber setting that dramatically improves grip in the turns for reduced understeer and razor sharp turn-in. Aggressive drivers will benefit from reduced outside edge tire wear as well. Price: SOLD Note: Please offer reasonable prices. If the offer is deemed to be too low, you will be ignored. Last edited by EAS; 05-07-2012 at 11:05 AM.. |
12-14-2011, 05:05 PM | #2 |
Rep 15,818
I have these on my car and it helped me get about -2.5 camber up front
Which is a good -.9 more than my stock set up could do. Definitely worth the $250. Front camber on the M3 is too limited stock
01-11-2012, 01:52 AM | #3 |
Rep 276
Drives: 2011 M3 Coupe
Bump!
