01-20-2012, 06:54 PM | #1 |
1771
Rep 7,653
iND | 1M Brembo GT Brake Kits
With almost 5 decades of celebrated motorsport history, Brembo is one of the most notorious names in OEM, street, and motorsport braking solutions. With multiple global foundries and a distribution network driven by quality and consistency Brembo maintains control of every aspect of production. Possessing their own foundries allows Brembo full authority over the metallurgy of all braking components. For the E82 1M Brembo will release the GT brake kit. The same GT brake kit that ran 746,000 cycles without failure at: 110 Bar (1,617 PSI) line pressure / 4,526 Newton-Meters (3,338 ft-lbs). This feat is made possible by the culmination of every single attribute of the GT caliper design. All modern GT brake kits feature the infamous monobloc caliper design. The monobloc caliper allows the user to experience maximum pedal feel all the while minimizing the overall component weight. Rigidity of the caliper is increased via the design of the bridged front caliper. Among the many benefits one will experience from a bridged caliper, the design feature will allow the use of a substantially larger brake pad without a compromise in weight. Duration of the GT kit is also improved upon by the use of multiple dust seals per piston. The multiple seals reduce contamination of the brake fluid and internal caliper hydraulics. The E82 1M kit features a front 6 piston caliper and the option of either a 380x34mm or 365x34mm disc. The rear option entail a 4 piston caliper and the option of either a 380x34mm or 345x34mm disc. Regardless of rotor size all Brembo GT kits are available in either slotted or drilled rotors. From Brembo the E82 1M kit will come with a low dust low noise Ferodo FM1000 pad. Standard finish options include Red, Yellow, Black, and Silver. All kits purchased through IND are able to be custom finished in the color of your choice Please contact a iND representative for pricing and availability Phone: 866.963.4520 Email: info@ind-distribution.com Front 6 piston 380x34mm (R,Y,B,S) Front 6 piston 365x34mm (R,Y,B,S) Rear 4 piston 380x34mm (R,Y,B,S) Rear 4 piston 345x34mm (R,Y,B,S)
01-23-2012, 12:48 PM | #3 |
1771
Rep 7,653
ALL E82 1M front kits will be available early February. Rear kits are set for mid February. We will accept pre orders on these kits. Contact myself or Nate for more information.
PM Sent
02-22-2012, 04:22 PM | #6 |
1771
Rep 7,653
Almost that time gents! Full kits should be ready to go shortly. Pm with any questions or information on pre ordering a set
