02-06-2012, 09:03 PM | #1 |
Supreme Allied Commander
3885
Rep 54,481
Drives: F80 M3
>> HP Autosport<< Rogue Engineering BMW 1M Short Shift Kit
Rogue's BMW 1M SSK is designed from years of experience building BMW shifters, and addresses many unique shortcomings of the OEM shifting system that are often left ignored with more basic short shifter solutions. From the shift carrier on, Rogue has improved on BMW's own shifter design.
Rogue's modified BMW shift carrier raises the pivot point of the shifter, effectively raising the handle height without increasing the length of the throw for a more ergonomic solution. The carrier also perfectly centers the shift lever, giving the correct shifting geometry, ensuring a smooth feel. Delrin carrier bushings round out the carrier, and give the shift lever itself a stable base with no deflection, for added precision. By relocating the shift lever's position up and to the rear, the shifter is positioned closer to the steering wheel for a better, more ergonomic feel. A special selector rod also allows for better geometry and a properly aligned shift mechanism. Price: $395 Purchase Here: http://hpashop.com/Rogue-Engineering...ssk-e82-1m.htm Weighted Shift Rod is included but not pictured. Last edited by HP Autosport; 01-17-2017 at 01:34 PM.. |
08-02-2016, 10:48 PM | #18 |
Rep 389
Drives: Toyota Land Cruiser HE
Does this offer a shorter throw compared to the BMW Performance SSK?
