      02-07-2012, 07:45 AM   #1
robbieredknapped
robbieredknapped's Avatar
14
Drives: 130i M Sport, 6sp
Sway bar question
Hi Guys, which M3 front sway bar do you guys upgrade to? E92 or the E93
The E93 is 28mm and E92 slightly thinner 26.5mm i think.
Is there a trade off for going to thick?
      02-07-2012, 07:50 AM   #2
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
I went with E93 as everyone recommended it (there was also a group buy on it).
      02-07-2012, 08:16 AM   #3
luster
Drives: e90, e88
From my understanding you can use either.
There are the part numbers and their German names!
1. Front anti-roll bar / sway bar (Stabilisator vorne)
31352283515 (Stabilisator vorne)
31352283516 (Gummilager Stabilisator Unterteil, 2x)
31352283517 (Gummilager Stabilisator Oberteil, 2x)
31352283037 (Haltebügel Stabilisator, 2x)
31352283441 (Pendelstütze vorne links)
31352283442 (Pendelstütze vorne rechts)
07119904295 (Bundmutter selbstsichernd, 4x)
33326768884 (Sechskantbundmutter, 4x)
      02-07-2012, 02:54 PM   #4
robbieredknapped
14
Thanks. I think tischer has a M3 Kit. Including bushes etc. is the group buy still available?
      02-07-2012, 05:01 PM   #5
robbieredknapped
14
Hi Rai
Is this kit all you need for the swap?
http://www.trademotion.com/partlocat...catalogid=4462
Or is the left and right linkage is also required, like Luster mentioned.
31352283442
      02-07-2012, 06:08 PM   #6
luster
Drives: e90, e88
with links is a level 2 upgrade
http://www.ecstuning.com/Search/M3_Sway_Bar/
      02-07-2012, 06:11 PM   #7
robbieredknapped
14
Thanks Lucter, i will keep that in mind
      02-07-2012, 06:32 PM   #8
mcmn
Drives: MY10 AW 135i
I went the M3 Vert kit.
      02-07-2012, 06:38 PM   #9
luster
Drives: e90, e88
An alternate to the level 2 upgrade is to have Meyle HD control arms installed. They are harder than 1 and 3 series, but softer than M3.
HP Autowerkes have them
http://www.1addicts.com/forums/showthread.php?t=645274
1addicts
