Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > BMW M6 Forum (F12 / F13)
      02-12-2012, 08:19 AM   #1
southlight
Moderator / European Editor
southlight's Avatar
1545
Drives: X3M
Lightbulb BMW M Carbon Ceramic Brakes For M6 (F12/F13) In Detail
BIMMERPOST NEWS
70
COMMENTS
The debut of the all-new 2013 BMW M6 models also marks the debut of the long-awaited M Carbon Ceramic Brakes option. Details are limited so far but we've compiled what's known so far:
The M Carbon Ceramic Brakes have bigger rotors at the front axle (410mm vs 400mm standard), reduce the unsprung weight by 19.4 kg or 42.8 lb, and obviously increase fade resistance. While the standard brake calipers for the M6 models are painted in dark blue metallic, the carbon ceramic brakes are painted in a noble gold shade.
There's no word on pricing yet, but they won't be cheap for sure (option code is 2NK). The M Carbon Ceramic brakes will be available for the BMW M6 models and -- from July production on -- for the BMW F10 M5.
See below for a comparison table and a feature on the M Carbon Ceramic brakes (courtesy of M-Power.com).
Specifications M Compound Brakes (Standard)M Carbon Ceramic Brakes (optional)
Size:  10.5 KBName:  CF_c2.jpg
RotorsSteel-aluminum compoundCarbon-fibre compound ceramic
Brakes, front Six-piston fixed-calliperSix-piston fixed-calliper
Diameter (mm)400 x 36 / vented 410 x TBA / vented
Brakes, rear Single-piston floating-calliperSingle-piston floating-calliper
Diameter (mm)396 x 24 / vented 396 x 24 / vented
ColorDark Blue Metallic with colored M LogoGold with white M Logo
Weight reduction 19.4 kg / 42.8 lb
M-Power.com Feature
The latest version of the compound high-performance braking system helps give the new BMW M6 Coupe and Convertible outstanding stopping power. Its stand-out features include even lower weight, excellent feel and fade-free performance even under heavy loads.
The diameter of the inner-vented and perforated brake disks is 400 millimetres at the front and 396 millimetres at the rear. The six-piston fixed-calliper brakes at the front axle – painted dark blue metallic and complete with the M logo – are radially bolted to the pivot bearing.
The M carbon-ceramic brakes available for the first time for the new BMW M6 Coupe and Convertible (in conjunction with 20-inch M light-alloy wheels) are without parallel worldwide and take the cars’ stopping power to another new level.
The brake discs measure 410 millimetres in diameter at the front axle and 396 millimetres at the rear. Made from a new type of carbon-fibre compound ceramic, the discs boast even greater resistance to heat and combine this with significantly reduced rotating masses. The M carbon-ceramic brakes are 19.4 kg (42.8 lb) lighter than the standard-fitted items, yet the innovative material also displays exceptional resistance to wear, and the operating life of the discs is many times that of conventional equivalents.
The optional M carbon-ceramic system also sees six-piston fixed-calliper brakes at the front teaming up with single-piston floating-calliper brakes at the rear. The callipers can be identified by their special gold-coloured paint finish.
Source: M-Power.com
Press Release
An innovation designed to deliver precise handling: M carbon-ceramic brakes.
The latest version of the compound high-performance braking system helps give the new BMW M6 Coupe and Convertible outstanding stopping power. Its stand-out features include even lower weight, excellent feel and fade-free performance even under heavy loads. The diameter of the inner-vented and perforated brake disks is 400 millimetres at the front and 396 millimetres at the rear. The six-piston fixed-calliper brakes at the front axle – painted dark blue metallic and complete with the M logo – are radially bolted to the pivot bearing.
The M carbon-ceramic brakes available for the first time for the new BMW M6 Coupe and Convertible (in conjunction with 20-inch M light-alloy wheels) are without parallel worldwide and take the cars’ stopping power to another new level. The brake discs measure 410 millimetres in diameter at the front axle and 396 millimetres at the rear. Made from a new type of carbon-fibre compound ceramic, the discs boast even greater resistance to heat and combine this with significantly reduced rotating masses. The M carbon-ceramic brakes are 19.4 kg (42.8 lb) lighter than the standard-fitted items, yet the innovative material also displays exceptional resistance to wear, and the operating life of the discs is many times that of conventional equivalents. The optional M carbon-ceramic system also sees six-piston fixed-calliper brakes at the front teaming up with single-piston floating-calliper brakes at the rear. The callipers can be identified by their special gold-coloured paint finish.
      02-12-2012, 12:35 PM   #2
ki__
Drives: 19 M2C 6MT
Great looking Ceramic Brake Kit, it's about time BMW got into this business. Hopefully the next M3/4 will have the option as well.
      02-12-2012, 12:36 PM   #3
bavarian19
bavarian19's Avatar
Drives: Car
nice features, but the colors of the brakes are killing it IMO.
Why doesn't BMW offer different color calipers?
      02-12-2012, 12:39 PM   #4
Auto
Sweden
171
Drives: MB CLS 63 AMG
Damn! They look amazing! They must cost a fortune to change.
For an Audi S8, Audi charges aprox 10.000USD for new ceramic discs and pads all around in Sweden.
      02-12-2012, 12:42 PM   #5
BMW BRAD
BMW BRAD's Avatar
Drives: F10 535d M, F31 328d M
Awesome, but yeah........ big bucks to replace!
[SIGPIC]
      02-12-2012, 12:49 PM   #6
mattmv06
Drives: Accord
Yea I think this is gonna be around an $8K option. Just think ... that's two B&O sound systems hahahaha
      02-12-2012, 01:06 PM   #7
Imola.ZHP
Imola.ZHP's Avatar
Drives: 2014 BMW i3 BEV EE
Wow, 43lbs lighter! Thats nearly 11lbs at each corner!
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17-
- 2015 CPO i01 BEV Laurel Grey Tera World, '17-
- 2015 i01 REx Laurel Grey Tera World, '15-'17
- 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15
      02-12-2012, 01:13 PM   #8
richb811
richb811's Avatar
467
Drives: 2020 G20 330i M Sport
I can already picture my eyes bugging out of my head when I slam on the brakes in this new M6
      02-12-2012, 01:27 PM   #9
SchnellM3
Digger
SchnellM3's Avatar
Drives: 03 E46 M3
I wouldn't want either of those two colors... They're also still putting one of the current style fugly looking calipers in the rear
2009 E92 M3 /// Melbourne Red /// Fox Red /// M DKG
Full Innotech Exhaust - DINAN Intake - IND Engine Bay Appearance - IND Hand Stitched Boot Covers - and much more....
      02-12-2012, 01:41 PM   #10
SlowinFastout
Drives: C63 AMG
i would consider myself a sporty driver, and i take all my cars to the race track.
so this is fantastic news for me.
Cars get heavier and get more horsepower all the time, i always thought someone forgot about good brakes.
On my C63 AMG the brakes will fade on the Hockenheim Racetrack after 4-5 laps...which is ridiculous
      02-12-2012, 01:54 PM   #11
MDyDinanM
OIF Veteran
MDyDinanM's Avatar
Drives: ///M
2008 BMW M5  [6.88]
+1
Retired: '06 BMW E46 ///M3
Current: '08 BMW E60 DINAN ///M5, Interlagos Blue, SMG
DINAN Stage 2 Suspension, Exhaust, Stage III Software, Front strut braces,
Intakes, 13% Underdrive pulley, 3.91 Differential, RPI Scoops.
      02-12-2012, 01:58 PM   #12
E92LNGCGY
Drives: F97/Q5/982 GT4
Probably cost around $10k in Canada. They sure look good. Not sure about the caliper color though.
      02-12-2012, 02:21 PM   #13
Moo
Gold Member
Moo's Avatar
Drives: PSYWGN
They look BLING. Trying to appeal rappers?
      02-12-2012, 02:26 PM   #14
bavarian19
bavarian19's Avatar
Drives: Car
Well, how many M6 owners track their cars? This is certainly more for bling factor, even though I believe it will have performance upgrades.
If it were on the M3, I would think it will be abetter application.
      02-12-2012, 02:33 PM   #15
Pital
Drives:
wonder if they will put out less dust on the wheels?
      02-12-2012, 02:50 PM   #16
coolchu001
coolchu001's Avatar
48
Drives: 09 BMW 335d
will the free maintenance cover the pads and rotors?
      02-12-2012, 02:51 PM   #17
InTheNightKitchen
Ignorance is Bliss?
InTheNightKitchen's Avatar
Drives: 1 of Many
I like both colors of the calipers, but if you're all about performance the color won't matter!!!!!!! Can't wait for reviews...
      02-12-2012, 02:57 PM   #18
MSPORTWORLD
MSPORTWORLD's Avatar
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Ditto I sure hope so
      02-12-2012, 03:02 PM   #19
Zebra99
Zebra99's Avatar
Drives: 2011 335is E93
Not in Canada it won't. You guys in the U.S. ha e purchasing power so you have a good chance at that.
Up north we get raped for every little thing...unfair, but that's the price of
Commercialism I guess
      02-12-2012, 03:19 PM   #20
mattmv06
Drives: Accord
This brake option also comes with a mouth guard to protect your teeth from the steering wheel when you slam on the brakes haha
      02-12-2012, 03:39 PM   #21
vladberca
vladberca's Avatar
Romania
763
Drives: '18 octavia 2.0 tdi dsg
Finally BMW released them
      02-12-2012, 03:48 PM   #22
M3_WC
Drives: M3
Finally BMW offers a proper steel setup.
The carbon ceramic is completely useless on this car. These cars will not see the track use that calls for carbon brakes. Only needed for long hard sessions, to keep brake temps down.
Tags
2011 bmw m6, 2011 m6, 2012 bmw m6, 2012 m6, 2012 m6 coupe, 2013 m6 convertible, 2013 m6 coupe, 2014 bmw m6, 2014 bmw m6 convertible, 2014 bmw m6 coupe, 2014 m6, 2014 m6 convertible, 2014 m6 coupe, bmw carbon ceramic brakes, bmw ceramic brakes, bmw f12, bmw m ceramic brake, bmw m ceramic brakes, bmw m forum, bmw m forums, bmw m5 carbon ceramic brakes, bmw m5 ceramic brakes, bmw m6, bmw m6 carbon ceramic brakes, bmw m6 ceramic brakes, bmw m6 forum, bmw m6 forums, f12 m6, m forum, m forums, m6 coupe, m6 forum, m6 forums, new bmw m6, new m6, new m6 coupe
6post.com
