05-10-2012, 09:50 AM | #1 |
Rep 188
997 Turbo Stock Brakes For E92 M3
HELLO
Is is possible to fit 997 turbo brakes(red brembo ones) to e92 m3.I am asking this because brembo offers bbk for e92 m3 in 6 piston at the front and 4 piston at the rear.Maybe calipers are the same part number ? |
05-10-2012, 09:54 AM | #2 |
BimmerPost Supporting Vendor
308
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
05-10-2012, 10:58 AM | #3 |
JDM whore
189
Rep 3,341
yea prolly not... theres more then just bolting it up, you need custem fab'd brakets, new steel braided lines, bushings, shims, brake boosters... just a whole lotta headache...
05-10-2012, 12:50 PM | #5 |
trollololol
150
Rep 878
The cars also have different bolt patterns, so you can't simply slide on the rotor either.
05-11-2012, 01:45 AM | #6 |
Rep 85
Cutting brackets is not hard you can buy a prop valve and adjust bias. I'm sure you can find a rotor to fit just measure backspacing and what not. I own a shop I make stuff work like that all day don't listen to these people. If you never try it will never happen.
05-11-2012, 12:41 PM | #8 | |
Rep 2,792
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
05-11-2012, 12:46 PM | #9 |
Rep 5,508
No, they move different amounts of fluid based on the measurement of fluid displaced for pedal pushed and the size of the pistons it needs to displace. So you can end up with a very sensitive pedal or one that isn't responsive at all. The ABS system will be way out of whack as well.
05-11-2012, 04:17 PM | #10 |
Rep 85
There is always fluid in the caliper your not filling it every time it only has to move a small amount of fluid. If you are really concerned about it measure the fluid volume in each caliper. How do you think aftermarket brake companies make big brake kits? For the most part they sell the same caliper with different mounting hardware and lines. It's not rocket science it's a BMW guys.
05-11-2012, 04:51 PM | #11 | |
Rep 5,508
Believe me, I know what I am talking about. I've ran BBK setups on all sorts of cars. Retrofitted 300ZX 4 piston brakes onto the 240SX. Ran Wilwood big brakes on a Honda Civic... it doesn't work. You need to change the master cylinder, slave cylinder to match the brakes you are using. Even then you end up with uneven F/R brake bias and a whacked out ABS system. My 240SX with large front 300ZX brakes was crazily front brake biased. I would step on the pedal on track, the front brakes would lock up and the rear brakes would be barely applied at all. It was downright dangerous to drive. The front wheel would lock up and the rear end would step out every time you hit the brake. What you are talking about would work on an old car before modern brake systems came about. But to put brakes from another car the correct way is to replace the entire brake system with the components from the other car. |
05-11-2012, 06:16 PM | #13 |
Rep 5,508
05-14-2012, 06:23 PM | #14 | |
Rep 1,519
04-26-2015, 10:31 AM | #15 |
Rep 2,719
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
I wanna see this project go forward! lol
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
04-26-2015, 09:24 PM | #16 |
Rep 392
The brake bias will be way off because the 997 Turbo's weight distribution is very different than the M3 because their engines are on different ends of the vehicles.
04-28-2015, 08:40 PM | #17 |
Rep 6,733
You guys need to check m3forum. We've done this on the e46 M3 platform and even checked brake bias with no issues. Look for thread from P0lar.
Can it be done, sure.. with enough determination. Should you do it, well that is up to the individual to assume risk and expense if something were to go wrong. |
