05-10-2012, 02:36 PM | #1 |
Rep 579
How much better will an F80 M3 handle than an F30 with adaptive suspension?
The 335 has more power than I'd ever really use on the street (and I have no intention to track the car), but I want the best possible handling & responsiveness. So I'm wondering how different or improved could the F80 M3 handling be compared to an F30 with the adaptive suspension?
Obviously nobody's driven an F80 yet, but I'm hoping some anecdotal evidence from the e90 M3 or an eduactaed guess can answer my question. TIA!
Instagram: te37sl_m3
05-11-2012, 07:10 PM | #2 |
Rep 10,407
I think it will be markedly different. Each individual component contributes to the entire handling differences. Ride height, spring rate, suspension arm geometry and weight, damping rates, elastomer mounts/stops durometer, presence or absence of rigid pivots, tires, steering ratio and leverage, DSC, ABS and suspension software, etc., etc. All of these things are different from a base car to the M car and they all add up in each model in a very noticeable fashion. If you want the best handling go for the M, hands down, no questions.
Or... buy the base car and mod the piss out of it, typically making many things actually worse and then boast about how the base car can be made better than the M for less money...
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
05-12-2012, 02:21 PM | #4 |
Rep 1,140
05-12-2012, 03:24 PM | #5 | |
Rep 295
Because when you put coilovers+sway bars on the M3 it handles better than a modified 335i. And I did have a 335i w/ full bolt on. |
05-12-2012, 04:33 PM | #6 |
Rep 1,716
some people like to have some flexibility in their spine when theyre not on the track though, thats y the m3 stock is just the best car out there
i had an e46 m3 then i modded it out, loved it for awhile but really didnt need all the suspension upgrades, it drove awesome as it was and ill never forget it. i was young then and just doin it cause i could.
Formerly addicted to e46fanatics
Formerly addicted to e90post |
05-12-2012, 09:32 PM | #7 |
Rep 10,407
Certainly it would not without adding equivalent or better tires. Even then I doubt it would. It would have less body roll but that is only one aspect of handling.
05-12-2012, 10:01 PM | #8 |
Rep 295
05-13-2012, 12:45 AM | #9 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
Anyone who thinks springs/shocks, sway bars and tires are the only parts that contribute to the handling of a vehicle are seriously mistaken.
There is a reason why the M3 shares nothing in it's suspension save two trailing links in the rear. As Swamp mentioned above, geometry, leverage, bushings, mounts, etc have a very large effect on how a chassis responds and handles. |
05-13-2012, 03:18 AM | #10 | |
Rep 295
05-14-2012, 09:26 AM | #12 | |
Grease Monkey
295
Rep 2,646
If BMW could have, they would have just left the E90/92/93 chassis alone and changed only springs, shocks, sway bars, and wheels and tires to achieve the handling improvement for the M3. The R&D to re-engineerall of the components cost a lot of money, and if they could have achieved their goal with only a few parts they would have. All the time they spend on the ring with the M cars is for good reason, to test, re-engineer, re-test, re-engineer and so it goes on until they have every bushing, arm, link, etc. dialled in! |
05-14-2012, 02:51 PM | #13 | |
Rep 295
The M3 race cars share nothing in common with our M3. Their suspension is totally different. And are you bashing with actual time spent in a suspension modified car? Yes M3 has awesome balance stock, but theres plenty of room for improvement buddy. |
05-14-2012, 07:25 PM | #14 | |
Grease Monkey
295
Rep 2,646
P.S. Yes I have modified the suspension in many of my previous cars and I can tell you the result was not always better. I will agree that there is room the M3 for improvement but that improvement is not as simple as buying a set of coil overs and sway bars. Improvement comes from hours and hours of testing, adjustments/changes (to alignment specs and parts), more testing and so on and so fourth. |
05-14-2012, 08:07 PM | #15 | |
Rep 3,303
Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
05-14-2012, 08:37 PM | #16 | |
Rep 295
No a lot of you defend the M3. So do I. I drive one and love it. But the OP stated he was happy with his 335s power and wanted to know if it can handle like an M3. Now, obviously 335 has shortcomings of an M3, but he can get mods and be close to, if not better. Now that doesn't mean a 335 is better than an M3. M3 can get after market products too. Stop trying to make this a M3>335 thread. All I stated was hey, if you ilke your 335 and you like your power but want good handling (similar to that of an m3) you can start with KW coils + sway bars + wheels and tires. Fuk, he can get get $10,000 motons and get it properly dialed in and tear up an M3 handling wise. Last edited by StylePoints; 05-14-2012 at 09:00 PM.. |
05-15-2012, 09:05 AM | #17 | |
Rep 19,368
Consider, first off, that even an M3 without adaptive suspension (EDC) will easily out handle a stock 335i, even when the latter is optioned with the M Sport suspension. Secondly, keep in mind that adaptive suspension is by and large a tool to make modern automobiles more comfortable while requiring minimal compromise in the handling department. Although, on the other hand, I believe that an M3 today will in fact be slightly faster on the track with EDC when spec'd than without. However, just because you give a 335i that same technology, it does not mean you elevate it to M3 performance. Disclaimer: I am not up to speed yet on the latest technology used by BMW for their adaptive suspension. Things have likely evolved markedly from the EDC used in the M3 which was developed years ago. That said, everything above still applies. |
