      05-30-2012, 02:56 PM   #1
GTM_Challenge
GTM_Challenge's Avatar
Drives: E46 M3, E90 M3
GTMotoring - Akrapovic Downpipes 1M/135
For the ultimate in weight reduction, tuning potential, and racing sound, Akrapovic offer stainless steel, catless downpipes. When used in conjunction with the Evolution System, this is virtually the same setup used on the 1M Moto GP Safety Car. The high-flow downpipes do require ECU reprogramming to eliminate the check engine light and for peak power output. They are only for the dedicated track day car or hardcore enthusiasts.
ECU tune or flash is required to use all downpipes. As they remove primary catalyst.
Please PM or email us for pricing and availability
Please PM / Email me any questions or give us a call at: 847-466-7463 M-F 10-6 central
austin@gtmotoring.com
Payments by Paypal, Visa or Mastercard
      05-30-2012, 03:16 PM   #2
T-Dubbs
Coal Troll
151
Drives: '14 F10 535d
can you plz pm pricing shipped to calgary,ab?
My hybrid burns Diesel & Oil
deleted F10 535d
      05-30-2012, 03:36 PM   #3
GTM_Challenge
PM'D
      05-30-2012, 04:08 PM   #4
T-Dubbs
Coal Troll
151
are there any benefits to these over the ones that cost half the price?
ex. http://gtbperformance.gostorego.com/1-series/e82-e87-e88-2004-2012/exterior/ar-design-hi-flow-3-cattless-downpipes-135i-335i-n54.html
deleted F10 535d
      05-30-2012, 04:42 PM   #5
GTM_Challenge
are there any benefits to these over the ones that cost half the price?[/URL]
The build quality, design, and fitment are the main advantages of the Akrapovic down pipes. They are the benchmark
      05-30-2012, 05:21 PM   #6
T-Dubbs
Coal Troll
151
everyone claims their product is the best...
id like to see an actual test of downpipes for fitment/desgin/dyno/price
thank you for the information !
deleted F10 535d
      08-08-2012, 01:33 PM   #7
1911A145
1911A145's Avatar
34
Drives: 135i
They do make a wonderful product and their build quality does set the bar when it comes to materials, fit and finish, and welds. There are reall only two things that I had questions and they probably should be asked directly to them, but 1: Why use flex tubes in each downpipe when no one else does? long term benefit to prevent cracked exhaust and to offer flexibility in exhaust system? and 2: why not go with a flush, end to end/butt weld for a smoth transition? two section are puffed up/ flared up like any ol' blue bullet exhaust shop bender will do to make a slip fit and then weld it. Its just a cheaper way of fiting two pieces of exhaust pipes together before welding them. For the price these downpipes are, I would expect a better job on that. Either way, I know these are top quality, just wondered about those two things that no other company does. I have been very interested in the complete exhaust pacakge FWIW. Thanks.
      08-08-2012, 01:52 PM   #8
GTM_Challenge
Generally companys use flex sections when they are trying reduce the amount of engine vibration transmitted to the exhuast. The ones Akrapovic flex sections are high strength ones at that. While the slip fit and weld joints are cheaper to do than a butt weld, they are also slightly stronger as well which is the main reason they do this im sure as the rest of their exhaust items rarely do this. Downpipes see ALOT of heat and engine movement so i think this is just Akrapovic's way of trying to make it as reliable as they can.
      08-08-2012, 02:33 PM   #9
1911A145
1911A145's Avatar
34
Drives: 135i
You know, That does make sense with the slip fits. It also makes for a stonger weld between the two pieces as well. Could be their reason. IDK. Either way, I'm sure it has little restiction, if any, and also dosnt have the slag or roughness cheaper downpipes have when butt welding the pices together. Thanks for the fast response. I'll take it all in consideration when upgrading. Thanks.
      09-05-2012, 11:56 AM   #10
GTM_Challenge
Please PM or Email with any questions or for pricing
1addicts
