06-24-2012, 02:06 PM | #1 |
Rep 61
KW Installation
Hi,
I just installed some new to me KW V3s. The front stock endlinks are way too long to attach to the KWs. Does anyone know if KW has shorter endlinks? Are they necessary? I'll call them on Monday. |
06-24-2012, 02:35 PM | #2 |
Rep 1,031
You sure? The KW's come with the heavy duty Meyle ones and when I was comparing them with stock they looked the same. How low did you go with your settings? I am at the highest setting possible in the front.
06-24-2012, 03:30 PM | #3 |
Rep 61
I don't recall actual measurements but it was about 3" shorter. I bought them used, the endllinks provided were no different that the OEM ones. Waiting to here from seller as well.
06-25-2012, 10:34 PM | #4 |
Rep 61
KW says the factory ones should bolt up. Does the sway bar require rotation to attach the factory end links?
I'm about a 1" drop. I don't want to resort to turner adjustables if I don't have to. |
