07-09-2012, 06:59 AM | #1 |
Rep 3,178
E90 M3 Competition pack (ZCP) suspension components
Hoping someone has this on hand or knows where to find it. Searching but can't seem to find the part numbers for E90 M3 ZCP struts and springs.
Before the argument of "there are many aftermarket solutions" comes up, am wanting to stay OEM and would like to retrofit E90 M3 ZCP springs and struts (UK didn't get the option of ZCP for the E90 M3s unfortunately). Not looking at reprogramming EDC, this is purely a mechanical exercise. Thanks in advance.
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
07-09-2012, 08:59 AM | #2 |
H O O N
86
Rep 694
Assuming you have EDC, I believe these are the correct PN's :
http://realoem.com/bmw/showparts.do?...03&hg=31&fg=10 Front R&L strut : 31312284013 & 31312284014 Front Spring PN n/a http://realoem.com/bmw/showparts.do?...17&hg=33&fg=45 Rear R&L shock : 33522284315 Rear spring PN n/a
U WOT M8? |
07-09-2012, 09:37 AM | #3 | |
Rep 3,178
From memory springs are specific to chasis number isn't it?
07-09-2012, 12:35 PM | #4 |
H O O N
86
Rep 694
I think so, but iirc the springs could also differ depending on the options installed on the car. I think that's why realoem says to check with the dealer for the correct PN for your particular car. Unfortunately that's won't be too helpful since you're in the UK, maybe someone else with a E90 ZCP can chime in here.
U WOT M8? |
07-09-2012, 12:41 PM | #5 | |
Rep 4,567
FYI, BMW also makes non-EDC ZCP struts, if you're interested in those as well.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
07-09-2012, 10:52 PM | #6 |
Rep 1,144
I thought someone proved that the struts are the same, it's just different programming in the DSC/EDC controller that works the magic (and slightly shorter/stiffer springs)?
07-09-2012, 11:57 PM | #7 | |
Rep 4,567
The different programming in the EDC simply changes the rebound rate for Sport mode from a static setting to a dynamic one. And the DSC change certainly doesn't impact ride height -- it just makes MDM a bit more lax.
07-10-2012, 03:38 AM | #8 | |
Rep 3,178
07-10-2012, 07:59 AM | #9 | |
Rep 13,024
07-10-2012, 09:16 AM | #10 |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
07-10-2012, 10:51 AM | #11 |
Rep 4,567
BMW does not sell the M3 with ZCP without EDC, but they do make struts for such an application. Again, these are the struts that come equipped on the 1M and the Japanese-market M3.
Rears: 33522284312 Left front: 31312284011 Right front: 31312284012
07-10-2012, 12:56 PM | #12 | |
Rep 13,024
There must be some country where BMW sells a ZCP with optional EDC then, because those P/N are not labeled as an accessory, and share the same S7AA code regardless of EDC (EDC has its own S223A code regardless of ZCP). |
07-10-2012, 01:24 PM | #13 |
Rep 4,567
Could be Japan, but BMW doesn't have a configurator up on its .jp site.
