07-14-2012, 12:59 PM | #1 |
Supreme Allied Commander
3885
Rep 54,487
Drives: F80 M3
HP Autowerks | JRZ Suspension for your BMW E82 1M
JRZ Suspension Engineering is proud to introduce the JRZ RS1, a revolutionary development in multipurpose high performance damping.
Applying our race winning technology, JRZ designed the JRZ RS1 to give ultimate comfort for public roads and precise chassis control when driving on track. The JRZ RS1 is a high gas pressure, single adjustable monotube damper. The canister has been designed inside of the damper. JRZ inner canister technology gives the advantages of monotube canister dampers without the mounting concerns and complexity. Easy to install, the JRZ RS1 is available as a complete kit with mounting hardware and springs for all applications we support. Built on the same production line and sharing components with our pro racing applications, the JRZ RS1 is of true professional heritage. Following JRZs design philosophy, the JRZ RS1 has a large 22mm diameter piston rod in strut applications and a 16mm diameter piston rod in aluminium damper applications. The large piston rod magnifies the high pressure gas charge which means great chassis control without using a high spring rate or increasing harshness. Utilizing a mono tube design with a high flow piston ensures the smoothest possible ride in normal conditions while the bleed adjustment gives the ability to tune for racing situations. Unlike many other single adjustable suspensions, damping balance is carefully maintained between compression and rebound. This damping balance is critical to maintaining tire contact with the road in addition to controlling the main mass of the vehicle. To satisfy the diverse needs of each drivers application, the JRZ RS1 has an extra large adjustment range. With a few clicks you can turn your smooth street car into a crisp, rock solid track car in seconds. Features 22 mm rod strut, 16 mm rod damper 24 clicks of rebound Adjustable gas pressure, mono tube Piston designed for high performance Large adjustment range JRZ has designed the JRZ RS1 to give the end user the best possible damper to drive daily, while maintaining the racetrack performance that wins championships. The JRZ RS1 is shipped as a bolt-on kit and always comes with the personal support JRZ is known for. Using the best materials, coatings and aerospace standard manufacturing processes as in our motorsport line; the JRZ RS1 is designed to perform flawlessly. Adjustment is easy to perform and comes with the knowledge base only JRZ provides to his customers. Benefits Easy to use and bolt-in Street ride, racing performance Extra long product life One adjustment for complete control of ride and handling Professional racing quality Recommended applications Daily driving Drivers education (DE) events and track days Club racing Both fixed height or height adjustable systems are available for your E9x M3. You can also purchase dampers only to fit your own springs. Price starts at $2499 Complete JRZ height adjustable system with springs and camber plates for your BMW M3 is $4145. Swift spring/Vorshlag camber plate package is also available. Please PM, email or call us if you have any questions. Order here: http://www.hpashop.com/JRZ-RS1-Singl...JRZ-1M-RS1.htm Last edited by HP Autosport; 09-25-2012 at 03:36 PM.. |
07-19-2012, 09:07 PM | #2 |
3885
Rep 54,487
Drives: F80 M3
JRZ RS RS1 RS Pro dampers
PM, email or call us with any questions you may have on these JRZ's.
http://www.hpashop.com/JRZ-RS1-Singl...-Set-1M-M3.htm |
11-13-2012, 04:54 PM | #6 |
3885
Rep 54,487
Drives: F80 M3
Another set of JRZ RS1 going to a happy 335i customer with M3 rear control arm conversion! Add the sleeves and these will fit the 1M and M3!
Notice the new reinforced anti roll bar mounts? |
12-13-2012, 04:40 PM | #7 |
3885
Rep 54,487
Drives: F80 M3
JRZ RS1
Look what awaits my arrival this morning on top of my tool box!
Full assembly and going to a happy 1M/M3 home for Xmas soon! |
02-09-2018, 03:23 PM | #9 |
3885
Rep 54,487
Drives: F80 M3
Looking for JRZ coilovers and live in Santa Barbara, Ventura or San Luis Obispo Counties? HP Autosport, Inc. is your local source.
We install everything we sell. www.hpashop.com |
03-01-2018, 08:24 PM | #10 |
3885
Rep 54,487
Drives: F80 M3
05-27-2018, 11:13 PM | #16 |
3885
Rep 54,487
Drives: F80 M3
