07-18-2012, 12:03 AM | #1 |
Supreme Allied Commander
3897
Rep 54,605
Drives: F80 M3
JRZ RS1 Suspension for your BMW E82 1M
JRZ Suspension Engineering is proud to introduce the JRZ RS1 for your BMW e82 1m, a revolutionary development in multipurpose high performance damping.
Applying our race winning technology, JRZ designed the JRZ RS1 to give ultimate comfort for public roads and precise chassis control when driving on track. The JRZ RS1 is a high gas pressure, single adjustable monotube damper. The canister has been designed inside of the damper. JRZ inner canister technology gives the advantages of monotube canister dampers without the mounting concerns and complexity. Easy to install, the JRZ RS1 is available as a complete kit with mounting hardware and springs for all applications we support. Built on the same production line and sharing components with our pro racing applications, the JRZ RS1 is of true professional heritage. Following JRZs design philosophy, the JRZ RS1 has a large 22mm diameter piston rod in strut applications and a 16mm diameter piston rod in aluminium damper applications. The large piston rod magnifies the high pressure gas charge which means great chassis control without using a high spring rate or increasing harshness. Utilizing a mono tube design with a high flow piston ensures the smoothest possible ride in normal conditions while the bleed adjustment gives the ability to tune for racing situations. Unlike many other single adjustable suspensions, damping balance is carefully maintained between compression and rebound. This damping balance is critical to maintaining tire contact with the road in addition to controlling the main mass of the vehicle. To satisfy the diverse needs of each drivers application, the JRZ RS1 has an extra large adjustment range. With a few clicks you can turn your smooth street car into a crisp, rock solid track car in seconds. Features 22 mm rod strut, 16 mm rod damper 24 clicks of rebound Adjustable gas pressure, mono tube Piston designed for high performance Large adjustment range JRZ has designed the JRZ RS1 to give the end user the best possible damper to drive daily, while maintaining the racetrack performance that wins championships. The JRZ RS1 is shipped as a bolt-on kit and always comes with the personal support JRZ is known for. Using the best materials, coatings and aerospace standard manufacturing processes as in our motorsport line; the JRZ RS1 is designed to perform flawlessly. Adjustment is easy to perform and comes with the knowledge base only JRZ provides to his customers. Benefits Easy to use and bolt-in Street ride, racing performance Extra long product life One adjustment for complete control of ride and handling Professional racing quality Recommended applications Daily driving Drivers education (DE) events and track days Club racing Both fixed height or height adjustable systems are available for your E82 1m. You can also purchase dampers only to fit your own springs. Last edited by HP Autosport; 09-11-2012 at 11:04 PM.. |
07-18-2012, 08:33 AM | #3 |
Rep 1,170
Drives: M2 Competition, E30 M3 DTM
Yes very good you have them in stock.
I am very happy with them!!! I did a 7.45 BTG ring time with them on PS2 tires on the 1M coupe. |
07-18-2012, 09:11 PM | #6 |
Rep 562
Drives: 2011 1M VO
07-18-2012, 10:52 PM | #7 |
3897
Rep 54,605
Drives: F80 M3
07-18-2012, 10:58 PM | #8 |
3897
Rep 54,605
Drives: F80 M3
07-19-2012, 04:23 AM | #9 |
Rep 1,170
On my youtube 7.45 ring movie i used rs1 shocks with the eibach pro kit. Last week i have updated my rs1 to hight adjustable with race spring because i use my 1m mostly for track now. The eibach pro kit wit jrz rs1 is for road use and some track work the best compromise you can find! And on the road on soft setting it has much more comfort then original shocks but the car stays nice flat in cornering. When going on track just turn youre shocks above setting 12 you wil have race car feel on track. Last edited by Advevo; 07-19-2012 at 04:30 AM.. |
07-21-2012, 08:52 PM | #10 |
3897
Rep 54,605
Drives: F80 M3
We will be doing an install soon with stock upper mounts and Swift springs, then later with Vorshlag camber plates. This way the community will have far more options and know what works and what doesn't.
08-05-2012, 09:22 PM | #12 |
3897
Rep 54,605
Drives: F80 M3
I can't list a price in this thread. Please visit our store for prices and options:
http://www.hpashop.com/JRZ-RS1-Singl...JRZ-1M-RS1.htm Please PM or email if you have specific questions. Harold |
08-26-2012, 06:37 AM | #14 |
Rep 5,329
lovely stuff!!!
im guessing these are rebuildable?? the jrz option although alittle more expensive looks very solid imo..... id definitely be going for that option!! if i was usa side JRZ would be my number one option.
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
08-27-2012, 05:40 AM | #15 | |
Rep 4,848
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
08-27-2012, 12:26 PM | #16 |
3897
Rep 54,605
Drives: F80 M3
08-27-2012, 06:51 PM | #17 |
Rep 291
Thanks for the aswer...
I have another concern, right now I'm running Tires Hankook Ventus V12 EVO 265/35/18 Front & 285/35/18 Rear, it rubs a little in the front liner at full steering lock, if I drop the car lets say 1 inch max the rubbing issues will be worst? |
08-27-2012, 11:41 PM | #18 | |
3897
Rep 54,605
Drives: F80 M3
08-29-2012, 07:29 AM | #19 |
Rep 5,329
genuinely didnt realise these guys were european. In the uk at least they arnt readily available due to other more popular options. JRZ seem to be used on alot of high end builds state side.
09-11-2012, 11:07 PM | #20 |
3897
Rep 54,605
Drives: F80 M3
They are in the Netherlands!
Here are a few photos of a BMW 1M height adjustable kit using OEM upper mounts and Swift main and helper springs stack. |
09-16-2012, 10:13 AM | #22 |
3897
Rep 54,605
Drives: F80 M3
Here is the final front strut set-up with some really trick helpers that produce an ultra low block height.
