08-21-2012, 01:55 AM | #1 |
Rep 60
Looking to lower my 2010 M3
I just picked up a DCT 2010 M3 and I want to lower my car on 19" HRE P40SC wheels. I am looking for something that will provide the improved aesthetics of the drop while maintaining excellent ride quality. This car will be my daily driver, and I won't be taking it to the track often at all. I'm definitely not the most informed on suspensions so I was hoping you guys could help me out with some good options for my needs.
08-21-2012, 08:03 AM | #2 |
BimmerPost Supporting Vendor
308
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Tons of info here, just do some research. You can't go wrong with the big names...Eibach, H&R, RD Sport.
08-21-2012, 03:47 PM | #3 |
Rep 60
So you think I should lower using springs and nothing else? Does the ride generally become quite bouncy and rough? Would it be sig ificanrly less so with coilovers? I want my a decent look but I definitely want to maintain good ride quality.
08-22-2012, 12:42 PM | #6 |
Rep 1,303
I thought about eibach's and the drop still looked a tad bit too high, so I went with the B&G springs which I have had on my car about 500 miles now and have an excellent drop and ride quality (I believe the drop is .5" in the rear and 1" in the front). I also used e36 bumpstops to allow for further travel. I haven't had one issue.
08-22-2012, 01:04 PM | #7 |
Rep 6,919
H&Rs are bouncy at high speeds and in general IMHO. RD's will give you the lowest drop, Eibach the least drop. A good compromise between springs and coilovers would be a sleeve kit. KW is a popular choice and TCKline now has one as well...those are height adjustable.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
08-22-2012, 01:47 PM | #9 |
Rep 6,919
08-22-2012, 03:02 PM | #10 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Coilovers when properly set-up, are best. Next best are the "spring over" adjustable options from KW, Ground Control, and TC Kline (these use the stock dampers but have adjustable ride-height). Lastly springs from Eibach, H&R, B&G, RD Sport, etc. I had Eibach springs and liked the ride quality and the ride height was conservative (meaning it allowed for reasonable ground clearance). I recently switched to coilovers and the street performance / ride quality is much better even at a very low ride-height. However you pay much more for the extra performance of coil-overs.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
08-23-2012, 06:18 AM | #11 |
Rep 10,686
I agree with the coilover recommendation if you want significant drop. Even with sleeve over kits for you stock struts, you still have stock damping and stock length struts.
All lowering springs are stiffer, so expect a loss in ride quality. And expect a worse ride on your 19 inch wheels than on 18 inch wheels due to the reduced sidewall. I am on H&R Sports with cut strut mount guide tubes and E36M3 bump stops to reduce the suspension travel loss from the lowering. The ride quality is definitely worse on anything but smooth roads, but still good enough that my wife has not noticed that I modded the suspension a little. I have not noticed any bounciness at high speeds, but I have not been much over 140 mph. The drawback for the person whose primary interest is looks is that the lowering is probably just half what he wants. |
08-25-2012, 10:50 PM | #13 | |
Rep 4,003
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
08-27-2012, 10:50 AM | #15 | |
Rep 1,895
08-27-2012, 11:06 AM | #16 | |
Rep 944
E90 M3 AW/Extended FR•Ohlins•Borla•ACM•K&N•IND•BBS•Vredestein•Velos Designworks•Vorsteiner•BMW Performance•Lux AE•Arkym |
