08-22-2012, 10:12 PM | #1 |
Supreme Allied Commander
3885
Rep 54,481
Drives: F80 M3
HPA | Burger Motorsport Oil Catch Can 1M N54
Keep Oil Out of your BMW 1M Air Intake System
It's no secret that the BMW N54 motor suffers from serious oil control problems causing oil to blow through and coat the intercooler and charge piping, gunking up intake valves and the VANOS system, lowering the effective octane, and generally degrading engine performance. The higher your boost levels the more apparent these problems become. The solution to this problem has finally arrived. The BMS oil catch can. While there are other catch cans on the market they all fall short in various areas. Some are mounted on the hot/turbo side of the motor preventing proper vapor condensation. Others utilize hoses that are too small and runs that are too long to allow proper PCV ventilation causing internal motor / ring sealing issues. Some have insufficient or no internal baffle system while others have internal baffles systems that are too restrictive for the N54 motor. Most are simply repackaged oil catch cans from smaller / lower power motors shoe horned in to place in the N54 engine bay. To solve these problems BMS designed their oil catch can kit from the ground up specifically for the N54 application. It features 100% CNC machining with zero welding for a precision fit and long life. The hoses exceed the OEM PCV piping in diameter and that flow rate is maintained throughout the entire oil catch can ensuring no excessive crankcase pressure buildup. The mounting location is out of the way under the cowl allowing for shorter lines, more efficient operation, and a very stealthy look. Install takes around 20 minutes, includes all required hardware, and is 100% reversible. Simply unscrew the base of the can to empty it's contents every 3-6 months. BMS Oil Catch Can Features • Increases Air Intake Efficiency • Promotes Engine Longevity • Non-Clogging Air/Oil Separation Double Baffle • Free Flow Solid Design • Large Intake / Exhaust No Tapering Down • Stealth Mounting on Cool Side of the Motor • Anodized Black Lightweight Aluminum • Mounts Out of Sight Under the Cowl • Made in USA Applications • 2008+ E82 Coupe 135i / 1M • 2006+ E90 Sedan 335i / 335xi • 2006+ E91 Touring 335i / 335xi • 2006+ E92 Coupe 335i / 335xi / 335is • 2007+ E93 Convertible 335i / 335xi • 2008-2010 E60 Sedan 535i / 535 xi Replacement BMS Oil Catch Can Bracket Screws Available at most hardware stores: #10-32 x 1/2" Stainless Steel Installation instructions: https://www.n54tech.com/instructions/occ_install.pdf Intro Price: $179 Order here: http://www.hpashop.com/Burger-Motors...tchcan-N54.htm ***Can not ship to California or internationally*** Last edited by HP Autosport; 11-25-2019 at 08:48 PM.. |
10-16-2012, 09:50 PM | #2 |
Rep 840
Drives: BMW 1M VO
Just curious...could you provide some details on this...does it require any modifying or cutting? How easy is it to install? Is there a video installation? Any info like this would help out in my decision to get one as well as any customer out there interested.
10-17-2012, 02:35 PM | #3 | |
3885
Rep 54,481
Drives: F80 M3
10-17-2012, 07:52 PM | #4 |
Rep 840
Drives: BMW 1M VO
Thanks, appreciate it.
10-16-2013, 08:33 AM | #6 | |
Rep 2,898
Neil |
