BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Australia
BPM
      08-23-2012, 10:05 PM   #1
Totti
Troll
Totti's Avatar
Italy
79
Drives: 2011 E92 M3
Tyre Pressures
Hi guys,
Just wondering what pressures you guys run front/rear.
Cheers
BMW E92 M3 Coupe | Jerez Black | Fox Red Extended / Carbon Black Trim| Fully Loaded | Moonroof | 6MT | Gintani Sport
Originally Posted by ES_TRADER
Use the stick like u would a manual. If that doesn't work, put it in D mode and put both hands at 10 and 2. If that doesn't work, just sit on your right hand.
      08-24-2012, 01:49 AM   #2
E92325i
E92325i's Avatar
Australia
10
Drives: E92 325i
I don't own an M3 but a general rule with tyre pressures that i have found is to start at what the manufacturer recommends then increase/decrease 2psi at a time to find the tyre pressure/steering feel that you are happy with. I guess what i am trying to get across is that there are no hard and fast rules as to what pressure you should run for daily/street driving as long as you don't stray too far from what the factory recommends for your tyre/rim size.
I personally like a "heavier" steering feel so I run Front: 40psi (235/35/R19) and Rear:42psi (255/30/R19).
      08-24-2012, 06:40 PM   #3
DaveDee
DaveDee's Avatar
532
Drives: BMW X5M Comp
Originally Posted by Totti View Post
Hi guys,
Cheers
30 bar (44 lb) rear and 27 bar (39lb) front (nitrogen). Firm but good tyre wear.
      08-24-2012, 09:12 PM   #4
Totti
Troll
Totti's Avatar
Italy
79
Drives: 2011 E92 M3
Suh-weet. I've been running the same front/rear around 40 psi I think.. Would yours be same for good old fashioned air?
      08-24-2012, 10:19 PM   #5
DaveDee
DaveDee's Avatar
532
Sure, just the same. It's the higher recommender pressure on the tyre placard. Rears on mine are a different size to stock (295x30x19) but I've always run the same pressure (air or nitrogen) and been happy with the results.
      08-26-2012, 05:30 PM   #6
MFKN3
MFKN3's Avatar
Australia
127
Drives: supercharged 4.4L stroker E92
38psi on 20"s
m3post
