08-30-2012, 04:44 AM | #1 |
Rep 1,665
Compression and Rebound settings for KW Clubsports
could someone give me a little help on what the best compression and rebound settings are for kw clubsports on the track. i know its not the same for all tracks but where would be best to start?
08-30-2012, 11:47 AM | #3 |
Rep 1,250
KW stock setup is:
Front: Rebound-6 Compression-6 Rear: Rebound-9 Compression-6 All numbers are clicks out from full stiff. I ran this setup at Barber and it feels very good, planted all over the track. There was some slight understeer, especially in low speed sections, which I plan on adjusting the front some to cure. Rear is perfect IMO on street tires. |
08-31-2012, 01:10 AM | #4 |
Rep 26
Not sure if it carries over but I have a s2000 with v3s and most track guys hate the recommended settings. I think they are meant to induce understeer and give a more compliant ride for street driving. The best thing for you to do is maybe start 2 full settings closer to stiff and then follow normal adjustments based on tires and amount of oversteer/understeer
08-31-2012, 01:57 AM | #5 | |
Rep 1,250
11-13-2012, 03:22 PM | #6 |
Rep 1,250
Bump for an update. I have played with the settings a bit.
I ran rec'd settings, R: 6/9 C: 6/6, and found it had a little understeer on corner entry and mid corner. This is with -2.5 camber and 0 toe. I softened front rebound to 9, to make it R: 9/9 C: 6/6, and it noticeably worsened the understeer. It made the car push bad with my setup and driving style (295/265 AD08). Returning to the rec'd settings cured the understeer (mostly). I then stiffened front rebound 2 clicks to see if that would completely eliminate understeer, and did not notice a substantial difference between rec'd settings and R: 4/9 C: 6/6. I am now back to the rec'd settings. It is my thinking that the stagger I have is causing my understeer issues, which should be cured by my new 18x10 275/275 conti slick setup. I will report back after testing. I will say that even though the car understeers some, it drives amazingly on track and is much more planted than stock. My 2c. Edit: I would like to get input from other KW CS drivers, perhaps there is something I'm missing that is causing mild/moderate entry/mid corner understeer. I read JAJ's post(s) many times and I know he was pleased with R: 11/11. I don't know if the difference is stock PS2 vs. wider AD08, or driving style, or some other factor. More knowledgable folks please chime in. Last edited by Porschefile; 11-13-2012 at 03:30 PM.. |
11-13-2012, 07:44 PM | #7 | |
Rep 5,930
11-14-2012, 02:16 PM | #8 | |
Rep 1,250
11-14-2012, 02:26 PM | #9 |
Rep 5,930
I'd try changing the rake so the rear is 0.25-0.5" higher than the front (start at 0.25" and then increase to 0.5"). Dropping the rear ride height relative to the front (or increasing front relative to rear) will increase steady-state understeer (other variables come into play but this is generally the case). Depending on your current ride heights, if possible, I'd start by lowering the front first before raising the rear (i.e., always initially start working on the end with the issue because it will help to increase overall grip).
11-14-2012, 02:28 PM | #10 | |
Rep 1,250
11-14-2012, 02:34 PM | #11 |
Rep 5,930
Not ideal for ultimate grip/handling (it's always a compromise!) but you could split the difference - drop the F 0.125", raise the R 0.125" to minimize F-R toe changes. This still won't give you the correct rake (rear higher than front) but it's a change that should still help to reduce overall understeer - if it helps then decide if you want to realign your car and set the rake...
11-14-2012, 03:15 PM | #13 | |
78
Rep 684
The most effective way of solving mid-corner understeer is going to a staggered set up, which you are already doing. I would not directly apply one car's 'optimal' setting to another car because there are too many variables. The driver, tires, wheels, suspension set up, race track... all completely different.
11-14-2012, 03:25 PM | #14 | |
Rep 1,250
