09-04-2012, 11:03 PM | #1 |
Turbo Guru
40
Rep 253
Bedding On The Way To Track?
Got some new Pagids in (rs19), but won't be able to install till a little later on this week. My track day is on Saturday, and was just wondering what the opinion was about bedding them on the way there, I will easily be able to do numerous 80-15 stops and a semi repetitive nature....which I figured should suffice. Any alternative thoughts I should be aware of?
09-04-2012, 11:13 PM | #2 |
11818
Rep 23,187
i usually do my bedding in prior to heading to the track but also do a modified bedding each time i head down as you stated. also on rs19s. shouldnt be a problem doing what you suggested.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
09-04-2012, 11:19 PM | #3 | |
Rep 4,737
09-05-2012, 08:16 AM | #4 |
Turbo Guru
40
Rep 253
I was planning on doing 4 consecutive 80-15 stops....a couple minutes of regular highway driving to get some cooling, and then another 4 consecutive stops.
09-05-2012, 08:40 AM | #5 |
Rep 7,887
The biggest problem is getting enough heat in the pad & rotor to get a good transfer layer on the rotor.I find that if I do not get enough heat during this process on the street I will will have brake shudder on track.I normally do about 7-10 applications from 180 kph to 50 kph with hard braking back to back with full acceleration to do this properly or wait and use my 1st session on track to do this.
09-05-2012, 08:44 AM | #6 |
n1smo
97
Rep 1,483
Drives: E92 M3
I don't bed my brakes on the street. They bed themselves naturally on the track. By the end of the first session, I've got a nice blue tint on my rotors.
09-05-2012, 09:13 AM | #7 | |
Rep 3,246
mods: track ready stuff
09-05-2012, 10:31 AM | #8 | |
Rep 869
If you switch between 2 different pad compounds then I think you have to do a formal and proper bed-in procedure to transfer like-material to the rotor face. I've never felt like my first session at the track is worthwhile for doing this--heat up is too abrupt--maybe its just me and my over enthusiasm on the first big brake zone. I usually do about 10 controlled 70-10mph stops in rapid succession (late at night). Pagids and other race pads require a lot of heat to to do it properly, much more than street pads. I have bedded them in driving to the track in the wee hours, but my car's so loaded down and crammed full of crap (4 tires/rims in the back seat, jacks, tools, tent, etc etc) that its a bit of a PITA! Prefer to do it ahead of time.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
09-05-2012, 10:43 AM | #9 |
Rep 8,077
Drives: 11 E90 M3 Individual
I switch between the ST perf pads and PF01s. When I go to the PF01s, no issues. I do have to bed the ST pads after the PF01s...zero bite. Then after bedding the ST pads do fine.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
09-05-2012, 10:51 AM | #10 |
n1smo
97
Rep 1,483
Drives: E92 M3
I don't know, I feel bedding is just a myth. When I was stock at the Nurburgring, I would bed the brakes (stock pads) on the Autobahn before going onto the Ring but the brakes warped up just the same (or uneven brake pad transfer if you don't believe the rotor can warp).
Since getting the PFC BBK, I have not done any sort of bedding. Basically, I switch out from my street pads to the PF01s before going to the track, drive to the track, and go crazy on the track. Drive home after the weekend is over, take the PF01s off and put the street pads back on. Done. The rotors look fine and there's hardly any wear, the pads are done after 3x HPDEs though. Maybe I'm missing something here but what I've been doing seem to work pretty good. VIR is not heavy on the brakes other than turn 1 and 14/14a. So maybe that is kind of the bedding in process because you brake hard at 1, it cools off and you brake at Oak Tree, it cools off and you brake at 14/14a, bedding process complete..... :P |
09-05-2012, 02:41 PM | #11 | |
Rep 8,077
I believe I got this from Zeckhausen.
09-05-2012, 03:46 PM | #12 | |
n1smo
97
Rep 1,483
Drives: E92 M3
09-05-2012, 10:54 PM | #13 |
Rep 310
I think some street use is highly desirable, prior to bedding. I've read that you want to wear in the pads a little bit, so that they start to conform to the rotors (like 15-25 stops at city speeds). Otherwise, the pads will have microscopic hot spots when you start bedding them. I'm not sure what that does (pad glazing? increased rotor wear?).
09-06-2012, 04:31 PM | #14 |
Rep 20,742
Drives: 2021 911 turbo
I often change my pads at the track in the morning while I install my track wheels. I go on a small side street and do a dozen hard brakings (80-20 mph) then drive slowly back to the padock to let them cool. Not ideal, but it has worked for me .
09-07-2012, 12:50 AM | #15 | |
Rep 4,737
Excellent resource here: http://www.m3post.com/forums/showthread.php?t=396763 |
09-07-2012, 10:31 AM | #16 | |
Turbo Guru
40
Rep 253
Have read and watched everything in the page linked, great information in there. It would be about 8 total, but I understand not to stick to a solid number....thanks for the input.
09-07-2012, 01:45 PM | #17 | |
Rep 869
What the city driving does is clean the previous pad deposits off. Even after bedding, driving around town for a few weeks will scrub all the material off--just bare polished metal. It takes real heat to transfer pad material (burnish) to the rotor face. Cold brakes (city driving) will act as scrubbers over time.
09-07-2012, 01:58 PM | #18 |
Rep 8,077
Not to mention street driving may tear up your rotors much faster. That was my experience with PF01s on e46 M3 euro rotors. The rotors wore out before the pads when I kept them on for street driving.
