10-10-2012, 08:22 PM | #1 |
Rep 927
Adjustable perches - how many threads
How many threads of the sleeve should the collar come into contact with. I just installed the GC sleeve kit and to get the car lower than stock i needed to be just below the bottom of the threaded sleeve with the collar.
I'm not sure why I needed to get that low, I guess maybe it will settle in and I'll have to raise it back up. I only have about 3/4" of travel before the bump stop.
Craig Brickner
Click to Join: BMWCCA # 366493 |
10-13-2012, 01:44 AM | #2 |
Rep 421
You might not have the sleeve's fully seated on your damper. It's a tapered fit and it needs a decent amount of force to get it properly seated. You should also make sure both sides are equally fitted by measuring.
10-13-2012, 07:14 PM | #3 |
Rep 313
+1 You definitely have an error in your install as you would be significantly lower than stock with the adjusters that low if it was done correctly.
10-13-2012, 08:36 PM | #4 |
Rep 927
The hub's sleeve where the shock goes into or the threaded collar/sleeve/spring perch?
Craig Brickner
10-15-2012, 07:45 PM | #6 |
Rep 927
After 4-5 hours of a road trip and a couple hundred miles round Daytona, the sleeves should be compressed by now. I'll post up some pics of my settings and stance for comparison.
Craig Brickner
