ZPOST
Go Back   ZPOST > Marketplace > Sponsors Classifieds
  TireRack
      10-18-2012, 04:24 PM   #1
ApexWheels
ApexWheels's Avatar
1445
Drives: M3
► APEX | ARC-8 Light Weight Track Wheels
Thanks for your interest in our ARC-8 wheels! This thread will no longer be updated, but the discussion continues on our combined Flow Formed wheel thread at: https://www.zpost.com/forums/showthr...5#post25582445
We hope to see you there!
      10-28-2013, 11:42 PM   #2
RedDotRacer
Drives: 07 Z4mc
Anyone have a pic of these powder coated in white on an mc? I'm thinking about it..
      10-29-2013, 09:07 AM   #3
Beedub
Drives: 2007 Z4 M roadster vt2-500
z4m fitment can you check the AP bbk on the 17" rim in 9" width with et30 please..
heres the template...
http://www.apracing.com/Drawings/P16230.pdf
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      10-29-2013, 04:03 PM   #4
Expert@ApexWheels
Expert@ApexWheels's Avatar
3595
Drives: M3
We have not seen that yet, you would be the first!
Not a problem, we will test it and will report our findings for you!
      10-30-2013, 03:08 PM   #5
Beedub
thankyou david.... if this can clear i will order :-) payday in 3 days!!
      11-09-2013, 12:57 PM   #6
Bandlu
Drives: Z4M coupe
Originally Posted by David@ApexRaceParts View Post
Satin Black ARC-8s on this Z4M Roadster:
We have many sizes finishes of the ARC-8's in Z fitment in stock right now!
I really like how concave these wheels are. I have kw v3's on the highest ride height possible without camber plates. Would this setup fit on my car without any rubbing? I believe the car in the photo is running 18x9.5 et35 and 18x10 et 25 with -2.5 camber without camber plates. My car is driven daily.
Thanks
      11-11-2013, 06:54 PM   #7
Expert@ApexWheels
3595
Drives: M3
Thanks
With the KW Variants/ ST Coilovers, using the 18x9.5" ET35 ARC-8 with a 255/35/18 tire, you would hit either the spring perch or the bottom of the spring itself with the V shaped springs, so you will need to add a small 5mm spacer, or perhaps even larger depending on your ride height, to push the tire out away from the spring perch or spring. With the added spacer, you will need to dial in additional negative camber for the wheels and tires to clear the fenders properly, probably more than -3 degrees. In order to fix this issue with the 18x9.5" ET35 wheel clearance, you would want to switch to a linear spring. Because of their shape, it is recommended to be used with camber plates. You may be able to source upper top hat that would work with the OEM upper mount.
Some people go with a stretched tire of a 245/40/18 on the front, but we do not believe this would be a good solution as it would not provide the proper wheel protection due to the tire stretch. The best solution is still to change the KW V-shaped springs to the 6" linear race springs for proper fitment. The KW spring perch accepts a 60mm spring, thus you should look for a 6" 60mm spring from Swift, Hyperco, Eibach, or H&R. This will allow you to remove your V shaped spring and raise the lower spring perch higher to avoid the wheels and tires interfering.
      11-12-2013, 11:55 PM   #8
Bandlu
Drives: Z4M coupe
Thanks for that David
I'm not really interested in changing my springs. Would the 18x8.5 et 38 and 18x9.5 et22 fit with my standard v3s and without need for camber plates? How much camber would I need? Would they still look as concave? What tyres would you normally run on these rims?
Thanks
Kerstien
      11-13-2013, 04:53 PM   #9
Expert@ApexWheels
3595
Drives: M3
Thanks
Kerstien
Kerstein, the 18x8.5" ET38 and 18x9.5" ET22 will indeed work with your car with the KW V3's without the need of switching to a linear race spring or camber plates, as it would be compatible with the OEM alignment specifications. However, the 18x8.5" ET38 is a flat faced wheel, so you'd have a staggered look with a concave rear wheel. The street tire sizes that we usually recommend are 235/40/18 and 265/35/18. Some people have gotten away with 245/35/18 and 275/35/18 street tire sizes, but extreme performance summer tires, such as Hankook RS3's and Dunlop Direzza Star Specs, would require a fender roll in the rear to avoid rubbing, and some added negative camber in the front depending on your ride height.
      12-26-2013, 01:43 AM   #10
zubydafa
tosser
Isle of Man
32
Drives: '07 Z4MC
Awesome post david. I'm interested in running a similar setup as below. My understanding is that this example is running 18x9.5 et35 and 18.10 et25 with 275/35 square tires. I have the same spec rims and am shopping for some competition tires for track use.
Problem is, I have kw v3 which have the progressive spring. I'm dialed in at around -3.5 degrees front camber. I don't rub at all with 19x8.5 et32 with 245/35 tire. Do you know how my car would respond to a 275/35 front on 18x9.5 et35? I am not opposed to using spacers.
'07 MCoupe
lots of mods
      12-27-2013, 04:04 PM   #11
ApexWheels
ApexWheels's Avatar
1445
Drives: M3
275/35/18 is a pretty wide tire for an 18x9.5" wheel in the front of a Z4. We have experienced clearance issues with the KW suspension with the 18x9.5" ET35 and a 255/35/18 tire, which is why we recommend a 5mm spacer for that setup. Since you have the V-shaped progressive springs with your V3's and you plan on running a 275 tire, you may need a 12mm spacer or larger to clear the spring perch. This may require additional camber as well to clear the fender since you will be pushing the wheels further out past the fender than you would with a 5mm spacer.
This fitment will also depend on the model and brand of the tire you plan on running as some tires run wider than others. You may need to play with spacer sizes and camber settings to find the ideal setup for you. Please let us know if you have any other fitment questions and we'd be happy to assist you.
      12-27-2013, 11:01 PM   #12
RedDotRacer
Drives: 07 Z4mc
Hey Dave, any pics of an alpine white m coupe with concave all around in satin black and hyper silver? I'm undecided on the two colors.
      01-02-2014, 07:22 PM   #13
ApexWheels
ApexWheels's Avatar
1445
Drives: M3
I will take a look for you and send over a PM!
      01-04-2014, 02:27 AM   #14
RedDotRacer
Drives: 07 Z4mc
Sounds good. I'll wait for your pm. The black looks good.
      04-24-2014, 03:32 PM   #15
donoman
Rookie
33
Drives: 03 Z4 2.5i 5MT
Hello David, I have both a Z4 and Z4MC, could you please elaborate which one of the wheels you have below are flat-faced or concave? Thank you!!!
17x8.5" ET20 - 16.50lbs - $259
17x8.5" ET40 - 17.20lbs - $249 - Z4 Non-M Fitment
17x9.0" ET30 - 16.50lbs - $264 - Z4M Fitment
17x9.0" ET42 - 17.20lbs - $259 - Z4 Non-M and Z4M Fitment
17x9.5" ET35 - 16.95lbs - $269 - Z4M Fitment
17x10" ET25 - 18.45lbs - $284 - Z4M Fitment
17x10.5" ET27 - 18.95lbs - $299
18x8.5" ET38 - 18.45lbs - $289 - Z4 Non-M and Z4M Fitment
18x8.5" ET45 - 18.20lbs - $289
18x9.0" ET42 - 18.65lbs - $299 - Z4 Non-M and Z4M Fitment
18x9.5" ET62 - 18.20lbs - $314
18x9.5" ET35 - 18.85lbs - $314 - Z4M Fitment
18x9.5" ET22 - 19.20lbs - $314 - Z4M Fitment
18x10" ET25 - 19.95lbs - $324 - Z4M Fitment
18x10.5" ET27 - 20.45lbs - $344
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      04-24-2014, 06:47 PM   #16
Expert@ApexWheels
3595
Drives: M3
Concave - 17x8.5" ET20 - 16.50lbs - $259
Flat Faced - 17x8.5" ET40 - 17.20lbs - $249 - Z4 Non-M Fitment
Concave - 17x9.0" ET30 - 16.50lbs - $264 - Z4M Fitment
Flat Faced - 17x9.0" ET42 - 17.20lbs - $259 - Z4 Non-M and Z4M Fitment
Concave - 17x9.5" ET35 - 16.95lbs - $269 - Z4M Fitment
Concave - 17x10" ET25 - 18.45lbs - $284 - Z4M Fitment
Concave - 17x10.5" ET27 - 18.95lbs - $299
Flat Faced - 18x8.5" ET38 - 18.45lbs - $289 - Z4 Non-M and Z4M Fitment
Flat Faced - 18x8.5" ET45 - 18.20lbs - $289
Flat Faced - 18x9.0" ET42 - 18.65lbs - $299 - Z4 Non-M and Z4M Fitment
Flat Faced - 18x9.5" ET62 - 18.20lbs - $314
Concave - 18x9.5" ET35 - 18.85lbs - $314 - Z4M Fitment
Concave - 18x9.5" ET22 - 19.20lbs - $314 - Z4M Fitment
Concave - 18x10" ET25 - 19.95lbs - $324 - Z4M Fitment
Concave - 18x10.5" ET27 - 20.45lbs - $344
Absolutely, I've notated all the Flat Faced and Concave wheels as you have requested above.
      04-24-2014, 08:02 PM   #17
donoman
Rookie
33
Thank you... So, no concave front fitments for non-M Z4 even in 17"?
Also, when you say they will "fit" below, are you assuming stock suspension? Neither of my cars have any heavy camber plates (yet) because I want to keep them very streetable... Thank you for your response and time.
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      04-25-2014, 12:43 PM   #18
Expert@ApexWheels
3595
Drives: M3
That is correct, there isn't any direct fitments available for the Z4 non-M with the concave wheels. These recommended fitments are indeed for meant cars with OEM or close to OEM suspension. There are more aggressive fitments available, but those would require suspension modifications with camber plates.
      04-29-2014, 05:56 PM   #19
Expert@ApexWheels
3595
Drives: M3
Here's an example of a track setup for a Z4M, squared 18x9.5" ET35 Hyper Black ARC-8s with 265/35/18:
Feel free to contact us directly if you have any questions.
      04-30-2014, 01:06 AM   #20
donoman
Rookie
33
This fitment looks good! Will it work on a Z4MC with stock suspension?
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      04-30-2014, 05:41 PM   #21
Expert@ApexWheels
3595
Drives: M3
Unfortunately, this fitment would require camber plates to fit on the front of the car without rubbing onto the fender. The OEM suspension would not be compatible without camber plates.
      05-05-2014, 07:54 PM   #22
blitzkrieg989
Drives: Z4MC
Originally Posted by ApexRaceParts View Post
ARC-8's are in stock for your Z4M and Z4 in multiple staggered and square fitments!
Please call, email, or pm us with any questions you may have.
Are those Hyper Black?
zpost
