Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      10-27-2012, 01:44 AM   #1
malter2.0
Drives: em-funf
F80 M3 rotor size
Based on current spy pictures, do we have data if the rotors will be bigger than the current 360mm rotors on E9x M3?
      10-29-2012, 07:38 AM   #2
richardg
richardg's Avatar
Drives: MacanGTS, 991.2GT3, E63wagon
So far no one knows for sure but what we can tell is that the calipers appear to be the same from the F30 Performance Brakes. Those brakes are 370x30 in the front which is larger in diameter but thinner than the e9x fronts and 345x24 rearward, which are both smaller in diameter and thickness. They are also slotted and drilled. The F8X has been seen with only drilled disks so I would assume same caliper (could be different bore sizes or few other factors) with different rotors. Expect larger than what we have now. Would have been cool to get the front brakes from the M5/6. Large and sexy.
      10-29-2012, 04:34 PM   #3
malter2.0
Drives: em-funf
Oh interesting. I didn't know F30 perf has larger diameter brakes than E9x M. If history repeats itself, brakes on the new M3 should not differ too much from current F10 M5. For example E60 M5 has 376x36 vs E9x M3 380x30 (i think im recalling correcty on thickness).
      10-31-2012, 11:50 AM   #4
richardg
richardg's Avatar
Yeah I highly doubt the rotors will be 390mm monstrosities that are on the M5/6. In a perfect world. I am sure they will put something more than effective on the car though.
      11-02-2012, 01:55 PM   #5
Brosef
Brosef's Avatar
Drives: F90 M5
e9x m3 rotors are not 380mm. They're noticeably smaller. I think they're more like 360.
      11-02-2012, 04:57 PM   #6
scott@bmwhn
Drives: Msport X3
correct stock E9x M3 front rotors are 360mm
My guess is that the F80 will be either 370mm (like the Mperformance brakes) or 380mm
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      11-12-2012, 11:19 PM   #7
swamp2
swamp2's Avatar
Drives: E92 M3
It might depend on the factory wheel options as well. If you can not get the car with 18" but only 19" or 20" wheels then they could fit a bit larger brakes. I also think 370 mm is a good guess as 380 mm is very large for a 19" wheel.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
f80post
