11-08-2012, 11:01 PM | #1 |
Rep 560
just did golf tee mod :D
Pinched the tube and ziptied it..sounds much deeper at startup....can tell its definitely the right side that has the new deeper sound..
now gonna switch the pipes from 1 out each side to 2 out each side..save like 3K on a new exhaust (and the wait) pretty happy with the sound..was just looking for a bit more from the exhaust but rather spend the 3K on a LSD |
11-09-2012, 07:22 AM | #2 |
Rep 1,356
this is what i did on mines
if you have JB4, you also have an option to leave it open by adjusting the settings in it. no mod required and can go into quiet mode at any given time |
11-12-2012, 04:53 AM | #3 |
Rep 1,448
I like the fact you've got the parts to block this. I simply put a screw inside the pipe, which grips and blocks the airflow. I can simply unscrew it from the pipe if required. I've had to do this on mine as the flap rattles from time to time.
11-12-2012, 08:18 PM | #4 |
Rep 560
The flap rattles? at what rpm?
btw, having taken off the rear msport bumper to install diffuser..i realize that for anyon doing the golf tee mod, if you want to have easier/neater access (like Hoa's pics), taking off the bumper makes it so much easier. |
11-12-2012, 10:40 PM | #5 |
Rep 1,356
12-27-2012, 06:54 PM | #6 |
Rep 118
different method
Guys - I have been reading about the golf tee mod for a while. I really want to take a shot but now I'm a bit confused.
I just saw this video. Is this an easier way of doing the same thing? What do you think? |
12-28-2012, 05:06 AM | #7 | |
Rep 1,448
On the z4 you simply block the vacuum pipe near the rear right back box. |
01-22-2013, 10:57 AM | #8 |
Mpbruin108
187
Rep 854
so this golf tee mod is putting you rubber things on 2 vacuum outlets? Can I do this without lifting the car on a lift? Does it sound deeper only at startup or while you drive too? I already have a catless DP so I wonder how much louder the car will be? Crazy enough, this is the first I've heard of this exhaust mod. I must be in a Z hole.
So Cal Drivers: Get your Tires from us to get them QUICKLY (same or next day) and at a GREAT Deal.
2244 Tyler Avenue, South El Monte| Call: 626-443-8539 Active: 2015 BMW i8, 2024 BMW iX, 2018 Mclaren 720s |
01-25-2013, 01:12 PM | #10 |
Rep 1,793
sometime i hear the flap rattling on a cold start with hard acceleration, and under all other conditions its quiet
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
02-07-2013, 12:38 AM | #15 |
Rep 329
02-07-2013, 03:00 AM | #16 |
Rep 766
02-07-2013, 03:21 AM | #17 | |
Rep 329
http://www.youtube.com/watch?feature...&v=p5phT3LPl80 |
02-07-2013, 03:50 AM | #18 | |
Rep 766
02-07-2013, 05:47 AM | #20 |
Rep 766
Apparently it is as a few posts have been stated. Going to give this a whirl tonight but unclear how to stick ones hand down such a tiny opening. I had serious issue with lux halos as the slot was so small to get my hand in there to twist it on correctly.
02-07-2013, 10:26 AM | #21 |
Rep 73
02-07-2013, 10:35 AM | #22 | |
Rep 73
For the lux i asked my wife i have too much big fingers |
