11-29-2012, 05:56 AM | #1 |
Rep 1,518
Anyone DIY removed rear subframe bushes?
Has anyone removed their rear subframe bushes without the use of a press or a proper tool like the HPA one?
I've bought AKG 75d rear bushes to replace the current ones and on my e36 I burnt them, drilled holes and then the metal ring with a saw blade. Has anyone taken the e92 m3 bushes out in a similar manner (bar using a saw blade). Unfortunately I'm located in the UK so hiring a tool is much harder and I don't trust the local shops here to use a hydraulic press without damaging the subframe. |
12-01-2012, 12:56 PM | #2 | |
Supreme Allied Commander
3890
Rep 54,597
Drives: F80 M3
12-01-2012, 03:54 PM | #3 |
Rep 1,518
Thanks Harold, your feedback is much appreciated. I'm considering buying a 12 or 20 tonne press so might leave it a for a while until I can source one at a reasonable price. I've used that same process for my e36 and it is a horrible job with the smoke and smell.
12-02-2012, 09:36 AM | #4 |
Rep 3,456
Drives: Harrop E90 M3
It's worth buying the bushing tools. I've done many sets and the correct tools make the job so much easier!
12-02-2012, 12:56 PM | #5 |
3890
Rep 54,597
Drives: F80 M3
If you have the subframe completely out of the car, you can certainly use a press to remove and install the bushings.
01-09-2013, 04:46 AM | #6 |
Rep 112
I removed mine with a 6" two arm gear puller. The rears came out fairly easy because the hooks on the puller can grab the sub-frame fairly easy. On the fronts I had to use a large C clamp to span and hold the hooks tight since its hard to get much bite on the subframe. In both cases you will also need a small plate that will fit over the hole in the bushings that the screw on the puller can push against. I used a 1.5" diameter x .25" thick piece I had.
I also heated the subframe a bit to release the rubber. Just warmed it up. Did not damage the paint. Took about an hour. |
01-17-2013, 09:38 AM | #7 |
Evo Junkie
35
Rep 157
I replaced the bushes on mine on the drive, I lowered the subframe enough without disconnecting the brake pipes etc and used a few things I had laying around, (bearing cases, gearbox syncro sleeves etc!) and some threaded bar and nuts and penny washers to enable me to pull out the old bushes and pull-in in the new ones.
01-17-2013, 05:07 PM | #8 |
Rep 2,792
When I remove large bushings or wheel bearings, I use a big washer the size of the bushing shell, a short piece of pipe big enough for the bushing to slide into as it's coming out, and a big bolt, washer or plate with hole to cover the end of the pipe, and a nut to create an at-home press to pull out the bushing. Often times, the new one can be pulled in in a similar fashion.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
12-08-2013, 08:18 PM | #9 |
Rep 1,665
Will your tool work on an e92 m3? I want to put in MRF bushings and turner diff mounts
12-09-2013, 11:56 AM | #10 |
3890
Rep 54,597
Drives: F80 M3
12-09-2013, 02:23 PM | #12 |
3890
Rep 54,597
Drives: F80 M3
12-10-2013, 11:45 AM | #14 |
3890
Rep 54,597
Drives: F80 M3
