01-03-2013, 03:30 AM | #1 |
78
Rep 684
BBK - Wheel Fitment Compatibility Database
I thought this may be helpful for those shopping for a BBK and wheels. Let's focus on 18" wheels because 19" wheels should clear most BBK on the market for M3. Also, rear kits other than the ones listed below should work on 18" wheels.
Please respond with your BBK and wheel specs. I will compile everyone's input and update this post as often as I can. Disclaimer: many variables can affect BBK - wheel fitment compatibility. Always check the clearance after installing new components. When in doubt, consult with your supplier and/or manufacturer. Use information below at your own risk. Alcon 384 F Volk Racing TE37SL 18x9.5 ET15 Alcon 370 R Volk Racing TE37SL 18x10.5 ET20 AP 368 Front Yes Apex EC-7 18x10 ET25 Apex EC-7 18x9.5 ET22 No Brembo 380 Front Yes Apex EC-7 18x10 ET25 Apex EC-7 18x9.5 ET22 Volk Racing TE37 18x9.5 ET22 BBS FI 18x9.5 ET20 No OEM 18x8.5 ET29 OEM 18x9.5 ET23 Brembo 365 Front Yes OEM 219M 18x8.5 ET29 (need low profile weights or 10 mm spacer) OEM 219M 18x9.5 ET23 TRMotorsport 18x10 ET25 Apex ARC-8 18x9.5 ET22 Apex ARC-8 18x10 ET25 No Brembo 380 Rear Yes Apex ARC-8 18x10.5 ET27 Apex EC-7 18x10.5 ET27 Apex EC-7 18x11 ET25 BBS FI 18x10.5 ET25 No OEM 18x9.5 ET23 PF 372 Front Yes OEM 219M 18x8.5 ET29 HRE R40 18x9.5 ET23 HRE R43 18x9.5 ET2118x10et22 R PF 371 Rear Yes OEM 219M 18x9.5 ET23 HRE R40 18x10 ET25 HRE R43 18x10 ET22 StopTech 380 Front Yes OEM 219M 18x8.5 ET29 (need 10 mm spacer) OEM 219M 18x9.5 ET23 (double check wheel weights) TRMotorsport 18x10 ET25 Apex ARC-8 18x9.5 ET22 Apex EC-7 18x10 ET25 Apex EC-7 18x9.5 ET22 BMW Motorsport GT4 18x9.5 ET25 Volk Racing TE37 18x9.5 ET22 HRE R43 18x9.5 ET22 StopTech 355 Front Yes Apex ARC8 17x10 ET25
01-03-2013, 07:31 AM | #3 |
Rep 5,929
PFC 372/371 BBK fits under the stock 18" 219M wheels (no spacers required)
Also, it easily fits behind HRE R40 18x9.5et23 F and 18x10et25 R, and HRE R43 18x9.5et21 F and 18x10et22 R wheels |
01-03-2013, 11:38 AM | #4 |
Scythe-Meister
90
Rep 1,053
Do you have any pictures of the clearance between the calipers and front 219Ms? Cheers.
01-03-2013, 12:26 PM | #5 |
Rep 5,929
No pics. No longer have my stock wheels so I can't take pics either. However, this kit was designed to work with the stock 219M wheels - if you don't believe me contact James at BimmerWorld because his e92 M3 with 219M wheels was used to develop this kit...
01-03-2013, 12:47 PM | #6 |
Scythe-Meister
90
Rep 1,053
That's ok. Do you have a picture or can you point me to the right picture showing the floating mechanism of the discs? I've googled, but there are a number of variations and I don't know which one the M3 kit uses. Thanks.
01-03-2013, 12:54 PM | #7 | |
Scythe-Meister
90
Rep 1,053
01-03-2013, 12:58 PM | #8 | |
Rep 5,929
http://www.performancefriction.com/m...ake-discs.aspx http://store.bimmerworld.com/perform...kit-p1823.aspx |
01-03-2013, 01:00 PM | #9 |
Rep 5,929
01-03-2013, 02:08 PM | #12 |
78
Rep 684
Updated. Keep them coming guys!
01-03-2013, 04:50 PM | #13 |
Rep 2,792
edit: The previous owner has informed me that the grooves were caused by pebbles getting jammed between the caliper and the barrel NOT the brakes themselves!
I have a set of Advan TCIIIs (18x10.5 +25) that belonged to another member who had 380mm Brembos all around. Three wheels have shallow grooves from the brakes (the bolts on the calipers I guess) rubbing the barrels. Presumably during heavy use when everything has expanded. Not sure what category they belong in considering that.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R Last edited by M3PO; 01-07-2013 at 06:18 PM.. |
01-03-2013, 07:38 PM | #15 |
Rep 3,246
From what i've seen, my Alcons clear the TC-III's, TE37(SL), HRE R40's, BBS FI's (actually test fitted) and EC-7's. Might be others, but those are off the top of my head. Oh, and the Alcons have 384 front rotors
mods: track ready stuff
01-03-2013, 08:43 PM | #16 |
Rep 8,077
Drives: 11 E90 M3 Individual
OEM 18 rears will clear 380mm stoptechs...no spacers. Just have to make sure you put the wheel weights on the inside or the outside of the inner barrel.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-04-2013, 07:51 PM | #17 |
BimmerPost Supporting Vendor
3592
Rep 6,818
The EC-7s in 18x9.5" ET22 and 18x10" ET25 will clear the Brembo 6 piston 380mm BBK and the Stoptech 6 piston 380mm BBK up front on an e9x M3, along with the AP Racing 368mm BBK and Brembo 365mm BBK. These same wheels will also clear the 380mm rear BBKs from Stoptech and Brembo also.
The ARC-8s in 18x9.5" ET22 and 18x10" ET25 will clear the Brembo 6 piston 365mm BBK, but not the 380mm version for the fronts. The 18x10.5" ET27 ARC-8s & EC-7s as well as the 18x11" ET25 EC-7s will work in the rear with a 380mm Brembo or Stoptech BBK. Volk Racing TE37s in 18x9.5" ET22 also clears the Stoptech and Brembo 6 piston 380mm BBK in front of an e9x M3: We will try to get brake templates for the PFC and Alcon kits to test against both the EC-7s and ARC-8s as well, but usually Brembo utilizes the largest calipers in our experience, so wheels that clear the Brembo 380mm BBK should clear the others as well with the same or smaller rotor sizes.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
01-05-2013, 01:55 AM | #18 | |
78
Rep 684
Could you please provide the specs for the wheels you mentioned?
01-06-2013, 12:05 PM | #21 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
See the link below for thread with similar content in the wheel / tire section. It would be great to merge the threads...
http://www.m3post.com/forums/showthr...ghlight=18+bbk
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 01-07-2013 at 04:51 PM.. |
01-06-2013, 09:20 PM | #22 |
Rep 3,246
Don't have specs, but from what I've gathered, anything that fits the brembo 380, fits the alcons.
