01-17-2013, 07:43 PM | #1 |
Rep 927
Titanium Shims | Good or Bad?
What do you guys think about break pad shims? I recently shot through a set of PFC08 endurance pads in 3 track days. This is much faster than normal for me and the only major change was the titanium plates. I wonder if they keep the heat in the pads and not allow the heat to dissipate.
Thoughts?
Craig Brickner
Click to Join: BMWCCA # 366493 |
01-17-2013, 10:22 PM | #2 |
Professional lurker
129
Rep 376
You went through the pads quicker due to the titanium shims? Interesting. I've always wondered about them.
01-17-2013, 10:33 PM | #3 |
Rep 106
I didn't have much luck with them on stock brakes.
_____________________________
2001 E46 Race Car - S54 Swap - Moton Suspension - CAE Shifter 2011 E90 M3 - ESS VT2-625 Supercharger - Stoptech Trophy BBK - Ohlins Road & Track - MP Exhaust |
01-17-2013, 10:36 PM | #4 |
Rep 381
In my opinion the shims work great in reducing the heat transfer to the calipers and most especially the brake fluid. They have so far eliminated the soft brake pedal I used to get at the end of a session.
So though the piston side pad may run a little hotter the outer pad temp should not be affected (I only run shims on the piston side). I haven't noticed any difference in wear rates from before and after shims. Were you running at the same track as before? Same session length? |
01-17-2013, 10:46 PM | #5 |
Rep 1,463
Consider brake silicone grease instead?
interesting theory on heat dissapation with the shims. I would think they would act as a heat sink drawing heat away from the calipers/pads |
01-18-2013, 10:35 AM | #7 |
Rep 381
Bought mine from Hardbrakes.com. The kit for the OE M3 brakes consists of four shims in the shape of the front pads (no kit avail for the rear). I mounted two up front and reshaped the other two to use in the rear.
In addition to keeping my brake fluid temps down it should help preserve the caliper boots. |
01-18-2013, 10:33 PM | #8 |
Rep 1,250
I always ran them on the stock calipers. It increases pad temp and therefore pad wear, but I'd rather run through PFC's faster (they can take the heat) than boil brake fluid. YMMV.
01-19-2013, 12:09 PM | #10 |
Rep 8,077
Drives: 11 E90 M3 Individual
The only reason that's tested is that the shims keep your pretty fixed calipers from changing colors.
I had the shims with my first set of pads and they lasted a long time. The second set of pads went pretty fast and I did not have the shims. Both pads were PF01s. I also want to test the theory that PFC may have some consistency issues with their pads. I've never really gotten an consistent wear rate. I'm trying some pagids and stoptech pads so I can compare.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-19-2013, 12:45 PM | #11 |
Rep 927
Craig Brickner
