02-07-2013, 11:13 PM | #1 |
Rep 1,164
KW S/O kit, Corner Balancing, Alignment and Driving Impressions
Thought I would post pics of newly installed KW Sleeve over spring kit, Corner balancing with 140 lbs in drivers seat and new alignment. The aligment was kept the same, Camber-F/R -2.5/-2.0; Toe-F/R .10/.20 degrees; Castor-factory settings
The front was lowered approx 3/8 inch and rear was lowered approx 1/2 inch more than previous Eibach pro-kit springs. The ride IMO is just as comfortable as Eibach springs, except being much lower and more responsive to steering input. All three modes of the EDC felt distinct and about the same as with Eibach springs. I will be tracking at Motorsports Ranch in Cresson, TX this weekend and will report back on how the KW S/O kit handles on track. This will be a new track for me so I will most likely not break any track records. HaHa! I know the diehards will say the Clubsport was the way to go, but I will soon be having to add a baby seat in back and keeping the EDC (comfort mode) then makes more sense. Also with the KW S/O, I get to keep my existing Vorshlag camber plates which I love. Installation, Corner balancing and Alignment were done by Driver Source in Houston, 281-479-1000
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL Last edited by ortho281; 07-24-2013 at 03:35 PM.. |
02-07-2013, 11:17 PM | #2 |
11818
Rep 23,187
nice. thinking im getting the new swift spec-r to use instead of going full coilovers for now. will allow a little more negative camber once im lower.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
02-07-2013, 11:26 PM | #3 |
Rep 1,164
Thanks! First time hearing about the swift spec-r. Sleeve-overs also? Any posts on these yet?
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL |
02-07-2013, 11:29 PM | #4 |
11818
Rep 23,187
no they are spring only but i have vorshlags already and am trying to avoid spending too much money. rates look decent for working with OEM also. yes their is a post by hpautowerks.
02-07-2013, 11:33 PM | #5 |
Rep 1,164
Cool! I will have to check these out. I have a used set of Eibach Pro-kit springs if you are interested. I installed them last June when I started hitting the tracks.
02-07-2013, 11:36 PM | #6 |
11818
Rep 23,187
okay havent purchased yet but they are a decent introductory price. what i hate about springs is the rear is already low enough in comparison with the front and the drop is always almost the same front to rear. they should be dropping the front an inch and the rear none for my taste.
02-07-2013, 11:43 PM | #7 | |
Rep 1,164
02-07-2013, 11:44 PM | #8 |
11818
Rep 23,187
you are correct but i still care about how it looks also sometimes.
02-07-2013, 11:55 PM | #9 |
Rep 1,164
I hear ya!
02-08-2013, 01:10 AM | #10 |
Looking
252
Rep 460
Thanks for posting this up and confirming that the Vorshlag fits KW S/O with no problems.
Your setup for double duty is exactly what I had in mind.
@DCxGarage
IG: |
02-08-2013, 10:41 AM | #11 |
Rep 77
02-08-2013, 10:47 AM | #12 |
11818
Rep 23,187
will do. doing a little more digging before i pull the trigger. not sure how much more camber i want to go and still drive it on the street some.
02-08-2013, 11:30 AM | #13 |
Rep 3,479
Drives: 19 M2C 6MT
Thanks for this! Very interested to see the outcome and your review on them for the track.
02-08-2013, 01:06 PM | #14 | |
Rep 1,164
I will, heading to MSR Cresson shortly.
02-08-2013, 01:28 PM | #16 |
Rep 864
Drives: '08 E92 335i
02-08-2013, 02:41 PM | #17 |
Rep 834
the springs still have to settle so it will lower a lil more correct?, in the pictures are you the lowest setting in the front? also is the ride "bouncy' at times? also when you got your alignment done did you really need to adjust the camber that muhc?
i ask this because im torn between this setup for my edc or going full coilovers with camber plates and a edc module of some sort
Originally Posted by onebadmofo
Some people buy cars to look at them and call them their babies, but not me. This car is my bitch and I bought it to drive it. |
02-08-2013, 05:45 PM | #18 |
Rep 3,479
Drives: 19 M2C 6MT
Are you on PSS's by the way?
02-08-2013, 09:45 PM | #19 | |||
Rep 1,164
Yes, I used the PSS for corner balancing instead of my track tires because they were less worn and almost new.
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL Last edited by ortho281; 02-09-2013 at 05:11 AM.. |
02-09-2013, 09:04 AM | #20 |
Rep 834
good to know thanks! i think i made my decision
02-09-2013, 12:11 PM | #21 |
*_*
812
Rep 3,160
Congrats! I had the same purpose with the KW S/Os when I put them on my car. Loved them when I had them on the track!
Only thing to be aware of is these will wear out your dampers if you go to the track a lot. I had them on for 30 days and my dampers started to feel the effects. The biggest indicator was during high speed turns going into a front straight, the car would ever so slightly bob more than it used to and have that squishy effect. |
