02-08-2013, 01:01 PM | #1 |
New Lifetime Replacement Policy
821
Rep 11,738
:: ECS Tuning :: DISA Valve|Minor Fix - Major Savings
The symptoms are annoying. The costs can be painful. DISA valves control intake manifold runner length to improve engine performance at different rpm. When they fail, the DISA valve bangs around in its housing, making a rattling noise accompanied by rough idle and off-idle hesitation. If your BMW experiences these symptoms, don't wait to fix it. In some cases, parts of the DISA--including a metal spreader pin--can be sucked into your engine, causing serious engine damage. Easy to replace, your new DISA screws to the side of the intake and comes with pre-installed sealing gasket. Click HERE for the DISA Valve for M54 2.5L Engines Click HERE for the DISA Valve for M54 3.0L engines |
08-09-2013, 12:32 PM | #3 |
821
Rep 11,738
Vaico DISA Valves are Back In Stock!!! Click HERE for the DISA Valve for M54 2.5L Engines Click HERE for the DISA Valve for M54 3.0L engines |
10-21-2013, 01:23 PM | #4 |
821
Rep 11,738
