BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
BPM
      02-09-2013, 12:58 PM   #1
djseto
Drives: 2013 M5
Low speed brake squeal
I've got about 45K miles on my 08 E92. According to the CBC, I've got about 20K left on the brakes (I'm not the first owner). Recently I've been getting brake squeal but only at very low speeds. By low, I mean like a few MPH when doing things like coming to a slow stop or pulling into a parking space. It doesn't happen initially when I first start up and drive but usually within 10 minutes it starts. It also doesn't happen when I get hard on brakes. It's really only when I'm almost to a stop and I begin to let up on the brakes.
It's driving me absolutely crazy. I'm out of warranty so I don't want to take it to a dealer and I while I know of a good independent shop, I'd like some DIY options first. I can't tell which side it's coming from, but I know it's the fronts. Thoughts? Ideas?
      02-09-2013, 01:16 PM   #2
SeaBeast
Drives: E92 M3 Coupe
what are the temperatures youre driving in?
      02-09-2013, 02:04 PM   #3
r53s65e90
8300
r53s65e90's Avatar
Drives: r53 s65e90
First thing I would try is this: http://zeckhausen.com/bedding_in_brakes.htm
This would definitely update pad/rotor contact.
      02-09-2013, 03:02 PM   #4
djseto
Drives: 2013 M5
I'm in NC so right now the temp are anywhere from 30s-60's.
Does bedding make sense on non new brakes/rotors?
      02-09-2013, 04:46 PM   #5
r53s65e90
8300
r53s65e90's Avatar
Drives: r53 s65e90
Yes it does. If you often do short drives and don't put enough heat into your brakes, the pad material gets scrubbed from the rotor surface. So regular spirited braking or bedding helps.
m3post
