03-24-2013, 11:40 PM | #1 |
Supreme Allied Commander
3890
Rep 54,590
Drives: F80 M3
Pagid RS19/29 Brake Pads for AP, Brembo, OE and Stoptech Calipers
Pagid RS19
Best compound for endurance racing on the basis of the RS14. A slight reduction of the friction value improves the modulation (controllability). Nevertheless, the friction value is enough for cars without power-assisted brake system and ensures comfortable low effort on the brake pedal. Constant temperatures up to 600°C (1,100°F) are possible. The combination of friction value, fading stability and low wear rates on pads and discs (rotors) realised with this material is unmatched up to now. Due to its excellent release characteristics and controllability PAGID endurance materials are also often used for sprint races. A multiple winner of Daytona 24h, Le Mans 24h, Sebring 12h, Spa 24 h, Nürburgring 24h, often with no pad change and usually no disc (rotor) change. Application: All endurance racing cars from Group N (Speed-WC, Grand Am Cup), Group A up to GT and Sport-Prototypes (Grand Am DP). Pagid RS29 A recent development from the bases of RS29, with a very similar friction coefficient to RS19 with improvements in initial bite offering quicker response and slightly more temperature stable at the upper levels of the temperature range. Developments in raw material selection and compounding have resulted in improvements also in pedal feel and feedback, helping with modulation particularly on lighter applications. Check listings for your vehicle This material provides very good levels of performance and response at all temperature levels, only slight temperature inputs are required to bring the pad up to its optimum performance level. Another favourite with endurance racers having won many classes at all major endurance events, such as Le-Mans, Daytona, Spa, Nurburgring, etc. Due to the exceptional pad life and very low wear on brake discs it has been possible to run 24 hours with out a change of pads or discs. Able to withstand slightly higher disc temperatures than RS19, this has proved more suitable for applications running very high disc temperatures. Although designed primarily for endurance racing, because of the consistent levels of performance and user friendliness many competitors use this material successfully for sprint and short distance races also. This has been seen in British GT Cup class, winning the Championship for the last 3 years in races averaging 1-2 hours in duration. RS19 has also found favour in the growing track day market due to the level of control, good cold performance, long life and low disc wear. While not being the cheapest brake pads on the market, we have proved that due to the longer life and less disc wear in comparison to other competitor’s product, running costs can be reduced in comparison to cheaper, inferior products. It is clear that the customer should look beyond the initial purchase price and make an accurate comparison with other competitor’s products to find the most cost effective braking solution. When compared to cheaper pads that wear more quickly and reduce disc life, and may also not perform consistently to the same level, the initially more costly product can often work out to be cheaper when calculated over the entire season. Friction Level Cold 0.40 At 100°C 0.43 At 300°C 0.47 Max at (@ 550°C) 0.49 Constant working temperature: 400 – 700°C Max temperature for short period only: 750°C AP BBK 1M and M3 RS29 Front $432 Rear $332 BMW OE Calipers 1M and M3 RS19 Front $359 Rear $329 Brembo BBK Monobloc Calipers 1M and M3 RS29 Front $695 Rear $335 Order here: http://www.hpashop.com/Pagid-RS19-29...E9x-M3-BBK.htm Stoptech ST-40 and ST-60 Calipers RS29 ST-60 $432 ST-40 $329 Order here: http://www.hpashop.com/Stoptech-ST-4...brake-pads.htm http://www.hpashop.com/Stoptech-ST-6...brake-pads.htm |
04-16-2013, 01:05 PM | #3 |
3890
Rep 54,590
Drives: F80 M3
