XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      04-10-2013, 09:32 PM   #1
donsbabybeamer
Drives: 2014 x1
Heated side mirrors ?
For those of you that already have your X1's do they have heated side mirrors that work in conjunction with the rear defroster. Reading through the Owners manual I see no mention of this.
Thanks
      04-10-2013, 09:53 PM   #2
leatherpants
Hide Encased Member
leatherpants's Avatar
Drives: 2013 X1 xDrive28i
I don't think so. The Cold Weather package only includes heated front seats, heated steering wheel, and retractable headlight washers. I have the cold weather package and there doesn't appear to be any buttons for this.
If it's any consolation I'll say that I've lived in the north (Boston and Seattle) all my life and I've never had much use for the feature in previous vehicles that had it.
      04-10-2013, 09:56 PM   #3
Red Bread
Drives: Smog machines
They come with the cold weather package and they are always heated, regardless of outside temperature. Same for the washer nozzles and drivers door lock.
      04-10-2013, 11:49 PM   #4
leatherpants
Hide Encased Member
Wow, learn something new every day. I had no idea I had them!
      04-11-2013, 04:20 AM   #5
donsbabybeamer
Drives: 2014 x1
Thanks, but when you said they are always on do you mean when the rear defroster is on (usual scenario) or anytime the car is running?
Thanks
      04-11-2013, 07:19 AM   #6
vbbuilt
Drives: x28i
From page 49 of the owners manual (.pdf). Standard on all versions of X1:
Automatic heating
Depending on the external temperature, both exterior mirrors are automatically heated when the engine is running or the ignition is switched
on.
Vince.
      04-11-2013, 08:48 AM   #7
Red Bread
Good point, I forgot that they finally put an outside temperature check into the system. For years, BMW's have just heated the mirrors, windshield and headlight squirters and door locks, regardless of outside temp. It was funny to feel my door lock or mirrors on my old M Coupe when it was 110 degrees out and they were still being heated.
I think they made the change around 2007 or 2008.
      04-11-2013, 10:13 AM   #8
edx1
Drives: X1 xDrive35i
Was that text in the manual for an X1 with the cold weather package? I thought I read somewhere that all X1's have heated mirrors?
      04-11-2013, 12:53 PM   #9
nospam
Drives: 2015 Alpina B6; 430i; X5 40e
Automatic heating
on.
Vince.
Nice...considering there is no cold weather package for M Sport owners.
      04-11-2013, 05:20 PM   #10
Grovsnus
Flight Lieutenant ≛
Drives: Le Mans blue X1 35i
The cold weather package consists of two things: Heated front seats, and a heated steering wheel. M-Sport buyers can still get heated front seats, even if there isn't an M-branded steering wheel with heat.
      04-11-2013, 05:23 PM   #11
Grovsnus
Flight Lieutenant ≛
The manual is the same for all X1s, regardless of engine, line, packages and options.
      04-11-2013, 08:16 PM   #12
trek8000
Drives: X1 35i Alpine White
In my X1 Owners manual it is on page 47 indicating the Automatic Heating as Vince states above. I live in Chicago and I did notice that snow did not stick around too long on the outside mirrors. The X1 climate control this winter in my opinion is excellent.
      04-11-2013, 08:58 PM   #13
Grovsnus
Flight Lieutenant ≛
Up here in the North, I wish it would heat both feet a bit better - to get an okay average temperature, you'll have one scorched leg and one footcicle.
The rear window deicer is also a tad on the slow and small side, but if I understand it correctly, it doubles as the radio antenna, so I guess that puts a limit to the size and heat.
Otherwise, it's a pretty good winter car. Drives well too. To the point that it's easy to forget how heavy it is, and that it won't stop on a dime
      04-12-2013, 12:01 AM   #14
nospam
The cold weather package consists of three things:
•Retractable headlight washers
•Heated Steering Wheel
•Heated front seats
I have no need for the headlight washers but heated steering wheel would have been nice for cold mornings. I had to settle for heated seats only with my M Sport. How will I ever survive this Southern California climate?
      10-23-2017, 09:12 AM   #15
SharpAndCunning
Drives: 2014 X1 35i
My x1 heated mirrors don't appear to work. Even when the car notifiies me that it's 37* outside with the snow symbol, the mirrors stay fogged up and don't clear.
Now that I know the door locks are heated, I'm going to try and see if they are warm when I get home on the next cold day.
Thanks for the information, guys!
      10-27-2017, 09:14 AM   #16
X1Denver
niner
Drives: 13 X1 Alpine Xdrive35i M
They work but very weak.. it will take a 20 min drive for mine to deice....
      11-01-2017, 08:46 AM   #17
SharpAndCunning
Drives: 2014 X1 35i
It;'s a temperature thing. Today at 32*F I turned the automatic wipers on and the mirrors defrosted pretty quickly.
The other day at 37* without the wipers on, they did not defog quickly.
I wish there was just a damned button.
I'm going to do some searching, someone has turned them off automatic and made them run of the rear window defogger button, I'm sure, because this malarkey is crazy.
xbimmers
