04-18-2013, 09:22 PM | #1 |
Rep 556
Got Eibachs installed on my e90 - before and after
When I was deciding on whether to drop my car I loved reading before/afters, so I thought I'd post my own for others benefit - though I know Eibachs are old hat around here.
When I bought my e90, it was a standard model with EDC, but no ZCP. This was the car on day one: I wanted a change in the wheels, so I switched them out for 220Ms (edit: should read 359M): The wheels looked great, but the front fender gap was really accentuated with the 19 inch wheels. The problem is that the 19s really changed the stance of the car compared to the 18s. I didn't want a slammed look, but I wanted something lower which closed up that gap and tightened the stance. I wavered between the Dinan and Eibach and ultimately decided for the latter: Different view - before: And after: I'm very happy with it. In person, the ride height and gap is perfect for me. I wouldn't dare go lower with our roads, speed bumps and driveways around here. We'll see if it settles down lower. It's subtle, but obviously lower in person. Here's a comparison of the fender gaps: Before: After: I'm withholding judgement on the handling. There is nothing obviously off and the ride is pretty close to stock. I still need to let it settle and get it aligned. That said, so far so good. I really can't imagine anything more conservative than this and after seeing the drop, I'm not too worried about premature wear. Edit: Added Macht Schnell 12/10 spacers Last edited by Rk-d; 04-25-2013 at 09:39 PM.. |
04-18-2013, 11:36 PM | #2 |
You got my money?
3250
Rep 4,716
Drives: Ice Cream Truck
Best pics Ive seen yet. You clearly show the gap and the contrast is good to actually see the gap. Most pictures people are are in the sun which makes it hard to tell exactly how much gap is removed. Nice job man.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
04-19-2013, 12:15 AM | #3 | |
Rep 556
Pics can be misleading for sure - the Eibach drop is definitely conservative, which is what I was looking for. Another angle |
04-19-2013, 12:52 AM | #4 |
*_*
812
Rep 3,160
Good picts for sure and comparison. For added info., the ZCP and Eibach are close to each other. Front is a two finger gap, loose vs. tight, respective to each option.
04-19-2013, 01:12 AM | #5 |
Rep 3,178
OP nice pics illustrating the difference, personally not one for the slammed look too so appreciate the subtle drop. I think you meant you swapped out to 359Ms not 220Ms
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
04-19-2013, 02:49 AM | #6 |
Rep 10,033
^^+1 if those are OEM wheels that you switched to, then they're the 359M's
but nonetheless your car looks great with the drop, thanks for sharing!
TiAg FTW! |
04-19-2013, 06:24 AM | #7 | ||
Rep 556
For me, the Eibach drop is definitely lower than the ZCP, but it's not a huge difference - you are correct that they are close. I'm actually glad for that - as soon as I saw it in person, I felt a lot more comfortable about it. I doubt (hope) the additional wear from this drop is going to do much. |
04-19-2013, 10:41 AM | #10 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
For comparison, here is my ZCP car with Eibach's installed. The height ends up even slightly lower in the front since the perches are lower on the ZCP struts!
Your car looks GREAT on the Eibach's with the ZCP's |
04-19-2013, 03:05 PM | #12 |
Rep 953
Looks great!
| 2011 M3 Sedan | Le Mans Blue | M-DCT | ZC2 | ZCP | ZP3 | Moonroof | Enhanced Premium Sound | Dinan exhaust | Dinan software | Dinan pulley | Dinan intake | Dinan pedals | Bimmian LED interior | Lux H8 V3 | WeissLicht PY24W LED | 20% tint | IND reflectors | IND front grills | IND key hole cover | IND hood vents | IND M5 mirror covers | Reus Systems audio | Verstraβe shifter paddles | BBS LM 20x9 et 15 and 20x10.5 et 15 | Hankook Ventus V12 255/30/20 and 295/25/20 | Red BBS Racing lug nut kit | H&R Sport springs |
04-21-2013, 02:59 PM | #15 |
Rep 556
Just to follow up - I haven't hit the bumpstops and the handling difference is negligible. The car is stiffer and damping seems best matched in Sport EDC mode, as opposed to Comfort. Overall ride comfort is very stock feeling. Incidentally, I went with OEM bumpstops and not the e36 ones, after mulling it over for a few days before the install.
These cars looks so much better with a subtle drop - anyone on the fence should go for it. |
04-21-2013, 03:23 PM | #16 | |
Rep 24,949
Is this the - 1 cm drop ? BTW..very nice drop |
04-21-2013, 03:56 PM | #17 |
Rep 556
Thanks! It's the pro-kit. -0.8 in/ -0.6 in f/r. Works out to ~ 2cm front/1.5cm rear. For comparison, ZCP is supposed to be a 10mm drop all the way around. I may end up getting 15/12 spacers to set the wheels out a little - haven't decided yet if I want to do that.
04-21-2013, 04:14 PM | #18 | |
Rep 24,949
I have found a link to your Eibach setup & spacers, and i think you will like it v v v http://www.m3post.com/forums/showthread.php?t=461787 |
04-21-2013, 05:35 PM | #20 |
Rep 3,341
You may rub with spacers. I'm on Eibachs, 220M's w/PZero's, stock sizes and rub in the rear with only 10mm spacers...not even full compression, just on decent dips. I'm also on the aggressive end of a street alignment. There's just not that much travel before you hit that liner nub in the back.
04-21-2013, 08:56 PM | #21 | |
Rep 556
04-22-2013, 04:49 AM | #22 |
Rep 24,949
Also...think about the difference...Denk has a E92,and you a E90
