BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Cars for sale/wanted/trade
      04-27-2013, 05:37 PM   #1
sumyungguy
sumyungguy's Avatar
Drives: 08 335i 6MT
95 M3 Build/Restoration/Track Car
BIMMERPOST / Classifieds
Asking Price:
Sold
Or Best Offer
✓ Will Ship
Item Interest
SOLD
Looking to sell my 1995 M3 that I have been restoring over the last year. This was a very hard decision to make but I need capital for a new business venture. The car is pretty much 100% with the exemption of a couple things that I think are personel preference. This is not an unfinished project car.
Build thread: http://forums.bimmerforums.com/forum...-Photos-Galore
Gallery (73 photos): http://www.flickr.com/photos/bradwoo...7633365592684/
Cliff Notes:
Im the second registered owner of this CA only 95 M3, purchased last april with the full intention to just track it as it was. One thing led to another and the car was basically taken down to a bare chassis and every component refreshed or replaced. Engine was completely rebuilt by my self and with a large amount of help from Terry Tinney of Terry Tinney Performance Motors. I was very meticulous in this build, and with the car being 18 years old and 265k of driving, if I didn't like a parts condition it was replaced. The exterior condition is very good, a few small dents and with the car being Cosmos light scratches are visible here and there. Interior is in excellent shape as most of it is gone or new. I have not thrown away/sold any of the parts that were removed/replaced with the exception of the front and rear seats. I even still have all of the engine internals.
e36 M3 Restored by bradthephotog, on Flickr
List of parts that were purchased for the most part:
Engine Parts
  • Built Vanos unit
  • Vanos solenoid
  • Vanos oil line
  • Timing rail pivot bolts
  • Timing chain rail
  • Upper timing chain rail
  • Timing chain tensioner rail
  • Oil pump nut
  • Oil pump drive chain
  • Timing Chain
  • Lower timing chain sprocket
  • Upper timing chain sprocket
  • Thermostat housing
  • Upper chain tensioner
  • Lower chain tensioner - new style
  • Valve cover studs
  • Valve cover caps nuts
  • Valve cover cap nut seals
  • Valve cover rubber mounts
  • ARP head studs
  • ARP main studs
  • ARP rod bolts
  • Bottom end gasket kit
  • Head gasket kit
  • Weisco .5 over 11:1 compression forged pistons
  • Main bearings
  • Rod bearings
  • Head dowels
  • Pilot bearing
  • Oil Pump
  • New Piston Squirters
  • 80C Thermostat
  • New oil filter housing
  • Stainless oil pan hardware
Engine Misc
  • Fuel hose
  • Fuel hose clamps
  • Fuel filter
  • Fuel pressure regulator
  • Euro 3.5" HFM
  • Turner engine chip
  • 24lb injectors
  • Samco intake boot
  • AFE intake
  • Oil cap
  • Engine cover caps
  • Fuel rail cover caps
  • Magnetic Drain Plug
  • Header Install Kit
  • BimmerWorld engine mounts
  • 3 Row s54 z3 Radiator
  • SPAL Electric Fan Kit
  • Low Temp Fan Switch
  • Canton coolant reservoir with custom -10 AN lines for main coolant lines under manifold
  • Royal Purple Purple Ice
  • Joe Gibbs BR30 break-in oil 100 miles -> Royal Purple Braking Oil
  • ICV Hoses
  • S52 Valve cover and coil packs and stainless hardware
  • Supersprint exhaust manifolds and full exhaust
  • Euro radiator cover
  • Refurbished Bosch 80amp alternator
Transmission/Driveline Parts
  • Linkage shims
  • Lower boot
  • Shifter bushing
  • Delrin carrier bushing
  • Carrier bushing
  • Shift rod circlip
  • Shift rod joint
  • Dowel pin
  • ZHP shift knob
  • Delrin clutch pedal bushings
  • Throwout bearing pipe
  • OEM Sachs Clutch
  • OEM Clutch Slave Cylinder
  • Seals
  • 3x Shift Pin Kit
  • 2x Shift Pin Bushing Kit
  • Pressure Plate Screws
  • Stainless steel clutch line
  • Chromoly light weight flywheel
  • 6x Driveshaft lock nuts
  • Royal Purple Synchromax
  • Differential Gasket
  • Differential Drain Plug Gaskets
  • Turner diff mounts
  • 10.9 Front Differential Bolt
  • Royal Purple 75w140 Gear Oil
Suspension/Mounts
  • TC Kline S/A Coulover suspension with 550F/600R springs
  • UUC red transmission mounts with enforcer cups
  • Front subframe bolts
  • Front subframe reinforcement plates welded in - powder coated
  • AKG Rear subframe sway bar reinforcements and diff mounts box welded - powder coated
  • AKG 75D rear subframe bushings
  • ALL Rear subframe bolts and washers
  • RTAB and Limiters
  • RTAB pocket reinforcement plates welded in
  • Meyle HD front control arms
  • BWSport TrackCAB - Solid control arm bushings
  • OEM Motorsport X-Brace
Steering Components
  • PS feed line
  • PS cooler line
  • PS reservoir
  • E46 330i ZHP RackDoctor rebuilt steering rack
Brakes
  • Remanufactured calipers at all 4 corners
  • Stoptech Stainless steel brake lines
  • ATE Super Blue
  • Non-return valve for booster
Interior
  • Recaro Speeds w/Planted seat brackets and Recaro sliders
  • Sparco 3" FIA harnesses
  • Autopower 4pt bolt in roll bar with removable diagonal bar and harness bar - powder coated
  • Stainless roll bar hardware
  • MOMO Mod 8 350mm suede steering wheel and hub
  • RallyRoad suede shift boot and brake boot
  • RallyRoad dual gauge pod
  • Innovate Motorsports Dual Digital gauges - oil press/temp and water temp/battery voltage
  • Cabin filter
  • M floor mats
  • Tail lamp covers and locks
  • Battery cover
  • Headlight switch
  • Door lock striker
  • Msc trim clips
Exterior
  • Windshield cowl cover and screw caps
  • Driver side brake duct
  • BMW emblems
  • M3 emblem
  • SSI Under Panel
  • New OEM front lip
  • Fog light deletes
  • Fuel cap
  • Fuel cap support
There are 3 things that I have not adressed as I think they would be better left to the new owner to decide:
  • Swaybars - I have the stock sways but they are not installed. New owner may elect to go bigger and that would come with sorting out the endlink lengths.
  • Brake Pads and Rotors - Current oem spec pads have plenty of life and the rotors will need to be replaced after this set. I was planning on getting much more agressive pads and rotors but think the new owner would want to pick these items.
  • Engine Tuning - Currently the car is running with a Turner stage 2 package chip. I was having issues with the tune and have just received a new chip from them on 4/26/12. Havent gotten on the dyno yet but initial drive showed positive results. Next step would be a Miller WAR but I think this would be a more personel decision for the new owner.
I have put about 900 miles on the car since the initial startup. Engine oil was changed at 100 and will be again before sale with Royal Purple HPS 5w30 as its only had break-in oil thus far. I will also perform another "nut & bolt" on all of the suspension components before sale. I have other vehicles and this only gets driven 1-3 times a week.
Looking to get $15,000 obo
Car is available to be seen in Tracy, CA. CA SMOG will need to be handled by the buyer, I have the stock mid pipe but it would need to be modified to attach onto the Supersprint headers. Please contact me with any question you may have and additional photos can be taken upon request. I am also willing to help coordinate shipping the vehicle, stock suspension could be installed no problem.
m3post
