04-29-2013, 05:27 PM | #1 |
Rep 63
305/30/20 Pss
As most of you know 305 PSS rears are not available here in US until the fall, but Canada has them! Putting these bad boys on my new hre p40sc when Nate gets then in. Just figured I share this.
F10 M5 Black Sapphire Metallic
E46 M3 Interlagos Blue (retired) |
04-29-2013, 10:41 PM | #3 |
Knight Commander
559
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
Can you also get 275s for the front to keep it balanced?
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
04-29-2013, 10:42 PM | #4 |
Knight Commander
559
Rep 5,948
Shouldn't be an issue. The problem is keeping the balance to the front width to avoid creating oversteer.
04-30-2013, 01:20 AM | #5 |
Rep 961
04-30-2013, 04:00 AM | #6 |
Rep 852
What is the difference in the manufacture's contact patch (not just the math off the tires spec 295->305, but the actual spec from manufacture's report).
Is the 305 XL weight rated...? Link/details please? |
04-30-2013, 04:29 AM | #7 | |
Internet Crash Test Dummy
334
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
The specs are 305/30ZR20/XL 103Y – part number 87598 http://www.michelinman.com/tire-sele...05/30/20/tires I sent an inquiry to Tirerack and a few others to ask about pricing and availability
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
04-30-2013, 08:06 AM | #8 |
Rep 852
Thanks Jan, it appears to meet the weight rating...
No details on *actual* contact patch size (unless I missed it?) http://www.michelinman.com/tire-sele...ails#techspecs |
04-30-2013, 08:53 AM | #9 | |
Rep 63
04-30-2013, 08:55 AM | #10 | |
Rep 63
Sorry Pic didn't work the first time.
04-30-2013, 09:22 AM | #11 | |
Rep 852
The stock tire configurations are as follows: So the Tread Width value for 19" is: 9.4" / 11.1" or 1:1.181 RATIO the Tread width value for 20" is: 9.7" / 11.6" or 1:1959 RATIO Note that the "Section Width" based on YYY/ZZ is the same per the specification chart and why it is important to see the Tread Width value. That means that within the stock tire options you have about 1.26% variance in the ratio of tread width with the stock options. You can work the same math backwards from your new rear tire "Tread Width" values to see how much of a variance it creates, but it is possible (if you don't check) that upping the Section Width of the fronts to the next size would put you too far the other way. I would expect (maybe I have it backwards given Stealth's comments) that the more tread in contact in the back would contribute to understeer, and more tread in contact at the front would contribute to oversteer. (Again) Unless you are driving the car to the limit, it should make very little difference for your day to day life... For example, you could go to the following tire and gain .8" of Tread Width (overall on the two rears)...and it is still a 295 tire. (AND for those fighting the Speedometer is off issue, it would make a meaningful difference in that correction.) Last edited by johntomferg; 04-30-2013 at 09:29 AM.. |
04-30-2013, 09:57 AM | #12 | |
Knight Commander
559
Rep 5,948
I think it is important to keep the relative contact patches similar.
09-13-2013, 12:20 AM | #13 |
Rep 36
Anyone switch to the 305 tires yet?
I am placing an order on BBS CH-R Wheels (20X10.5 ET 35 at the rear) and was wondering if all of that can clear without any poke |
09-16-2013, 03:01 PM | #15 | |
Rep 10,193
http://www.tirerack.com/tires/TireSe...30&diameter=20
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
09-16-2013, 08:30 PM | #16 | |
334
Rep 1,055
10-06-2013, 08:48 PM | #18 | |
Rep 63
10-07-2013, 08:32 PM | #20 | |
Rep 63
