05-09-2013, 08:53 AM | #1 |
Rep 880
Crack in Stock Rotor... is this still safe or are they toast?
This is a new car only a few months old, have just 2 track days on it and yesterday I see cracks like this in both front rotors and they seem to be shallow cracks but they go all the way across the face. I'm wondering what people think..... is this safe for additional track events or should these be trashed? I've been tracking for a while so I'm in advanced run groups and I'm pretty tough on brakes.
My setup is 275/35-18 Toyo R888's, SS lines, Carbotech XP20 Front/XP10 Rear, and I do have the Cantrell ducting system installed and use it for both events I've been to. I had major issues with cracking/warping front rotors in my 335i and I was kinda hoping the better rotor design in the M3 and adding the ducting would help but apparently not. Is looking like a BBK may be my only option to really fix/avoid this issues. Due to high costs of the BBK's I was trying to not go that route if i didn't have to. |
05-09-2013, 09:04 AM | #2 |
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
can you feel the crack with your nail? bc to me this looks more this pad deposits, but that just me.
05-09-2013, 09:10 AM | #3 |
Rep 7,887
Are you sure that is a crack?Looks like the pad imprinted on the rotor and left some pad material.If it is a crack(which I doubt)junk the rotor for sure.
05-09-2013, 09:18 AM | #4 |
Rep 880
I do need to scrub those deposits off and that will give me a better view, just went to track this weekend and have been very busy so didn't clean em off like i usually do. Hopefully you're right and it's not a crack. Just seemeed weird it was all the way across and it did seem like i could feel it with my fingernail. But I could just be being paranoid after my previous bad experiences though.
05-09-2013, 09:53 PM | #5 |
Rep 3,456
Drives: Harrop E90 M3
That's a crack for sure. When in doubt, change them out is what I say. Brakes are to important to let something questionable pass.
05-09-2013, 10:26 PM | #7 |
Rep 1,463
The nail theory doesn't apply here, sometimes stress fractures are not even visible to the naked eye and have to be examined under magnification. And under further heat cycles (expansion/contraction) you could have a serious failure.
OP I would replace them, these are your brakes, why take a chance? |
05-10-2013, 12:21 AM | #8 |
8300
19
Rep 573
This 100% a crack. Too radial to be a deposit from the edge of the pad. If it were from the center grove there would be a pair of imprints.
Rotor is gone for sure. R-compounds and high temps should be to blame along with a probably not so good batch of rotors, which would be otherwise fine for street. If you are still under warranty, it should be covered. Track pads ate supposed to work with this car. |
05-10-2013, 07:18 AM | #10 |
Rep 6,285
I'm not convinced that's a crack, as when you look at the glazed area of the rotor you cannot see the continuation of what one would perceive as being a crack.
Perhaps do a simple dye check, or even just rub some coarse emery paper on the area to see if it is still remaining once you rub the affected area. P.S I'm a metallurgical engineer working in the rolling stock/rail industry and see crack defects quite often, so I would like to think my comment carries some merit |
05-10-2013, 09:13 AM | #11 | |
Rep 521
For what it's worth, 99.9999% of the time, cracks don't run in a straight line, that's just not how the world works. Further to dr-jekl's comment, you can pick up a dye penetrant kit from your local industrial supply house for under $50, and you should be able to find instructions online on how to use it. Cheaper than a new rotor, and you get a definitive answer on your suspected crack. |
05-10-2013, 01:35 PM | #12 |
Rep 864
Drives: '08 E92 335i
Looks like a crack to me.
05-10-2013, 06:42 PM | #13 |
Rep 1,848
Looks like deposits to me. I had something similar on rear rotor. It was too linear to be a crack and matched perfectly angle wise with edge of pad. I had a lot of heat stress cracking on front rotors and it was a lot smaller indications.
05-10-2013, 07:57 PM | #14 | |
Rep 3,456
05-10-2013, 08:05 PM | #15 |
11818
Rep 23,187
+1 but also doesn't look like a crack. Hard to tell though from pictures.
05-13-2013, 01:49 AM | #16 |
Rep 8,077
Drives: 11 E90 M3 Individual
That looks like pad deposits. Why would a crack NOT start at one of the holes...which would be the weakest part of the rotor? BTW, there's an internal vain that runs behind that line so I highly doubt that's a crack.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
05-13-2013, 09:44 AM | #18 |
11818
Rep 23,187
what type of pads have a square edge like that?
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
05-15-2013, 12:42 PM | #20 |
Rep 521
05-15-2013, 02:49 PM | #21 |
Rep 1,285
Drives: A Car
Carbotechs are known to be pretty harsh on rotors. That being said, given your setup, you probably want to look for a good set of OEM replacement slotted rotors. If you find you don't have enough heat capacity, only then look at moving up to a BBK.
05-15-2013, 03:02 PM | #22 |
Rep 880
Hey guys, I was out of town for a while so just getting back to this. Anyway, I did bed the OEM pads in really good yesterday to clean the rotors off and I think this line was indeed just a pad deposit. It is still there but you can just barely see it now and you cannot feel it with a thumbnail.
Someone up above made a good point.... the crack would more than likely start in a hole and not all the way across the solid part of the rotor. I tried some Racing Brake replacement rotors on my 335i a couple years ago and they always started cracking around the holes first. Long story there, but I will never buy racing brake products again. I am pretty sure I'm going the BBK route. On track day my biggest issue/worry is brakes and if I could not have to worry about them so much and make pad changes quicker (with the stoptechs) then the $$ will be worth it in the long run. I'm starting to save some $$ now and looking for the best deal on the stoptechs. Hopefully sometime this summer I can get em. |
