05-15-2013, 03:52 PM | #1 |
Rep 1,512
Kw Sleeve kit review
I figured it best to wait a few thousand km's before giving my review on the kw sleeve over kit. That time is now!
The good: From the moment the kit was installed I was amazed at how perfect the drop was. It still has a finger gap all around so clearance was not an issue. The bad: To give a little background on the car, at time of install I had 22000kms. I went with new BMW top plates just to be sure.... The drive I can honestly say is horrible. Horrible is putting it kindly, uncontrollable is more like it. I don't mind spending money on a car but if there is one thing I absolutely can't stand is spending money to make it worse than it was... When it was stock the ride was excellent, bumps were a non issue and bounce was nonexistent. High speed driving was tight and composed. I never had the feeling my skill level was over the suspension's capability. With the sleeve kit I find the car to be unsettling to say the least. Granted I do live in eastern Canada and the roads are not the smoothest in the country. Still the difference from stock is unbelievable. Any imperfection in the road is amplified. At higher speeds you feel like you can lose control, very uninspiring. I thought I might be imagining things as everyone else's review of the kit was excellent so I went out last night for a drive with a close friend that also happens to be a driving instructor at a local track. We took a drive up to some winding back roads we frequent and from the first downward left turn he tells me to slow down. To make a long story short he was surprised at the handling. The progressive springs don't seem to do well with the factory suspension. Anyways this is my personal opinion on the product and I can say I expected more. I'll be swapping these out for the Ohlins R&T kit by the end of the month. I'll be sure to write a review. Alex
2022-G80 Xdrive BG
2014-GTR BE FBO 2016-HURACAN 610-4 (SOLD) 2021-G82 BASE (SOLD) |
05-15-2013, 04:29 PM | #3 | |
John
75
Rep 885
Current - 2012 AW/FR E92 M3 | 2014 AW X5 | 2015 MB S550 | 2016 RR V8 (White FTW) Mods - BPMTune Stg1/Servo, Euro Visors & Side Mirror, IND Gloss Blk Pkg, OEM Perf. CF Trim/Spoiler, Grills, Lights, Pedals, Umnitza V4 AE, ModeCarbon GTS V1, 19" HRE P40 Sold - 2008 BSM/Black E92 335i |
05-15-2013, 04:55 PM | #4 | |
Rep 1,512
By uneven you mean in terms of height or camber? How do you like the swift springs?
2022-G80 Xdrive BG
05-15-2013, 05:44 PM | #5 |
Rep 1,130
This is not what I wanted to hear. I want to lower the car with either springs or a sleeve kit and so far all of the reviews of the sleeve kit have been glowing..
05-15-2013, 06:09 PM | #7 |
Rep 1,512
I don't have EDC and I think that might add to the problem.
I can't believe EDC would make 100% of a difference but from what I read it helps.
2022-G80 Xdrive BG
05-15-2013, 06:12 PM | #8 | |
Rep 1,512
Kw do make great products, I've been in a car with kw v3's and the ride felt stable and compliant. If you have EDC you will most probable enjoy the ride.
2022-G80 Xdrive BG
05-15-2013, 06:30 PM | #9 | |
Rep 1,164
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL |
05-15-2013, 06:36 PM | #10 | |
Rep 1,512
The car was aligned after install. Are you on factory sway bars?
2022-G80 Xdrive BG
05-15-2013, 07:12 PM | #11 |
Rep 5,508
I had the KW Sleeve kit before. The ride quality is very dependent on how low you set the ride height. Looking at the picture, it looks pretty low. Also, if your shocks are worn, it will increase shock wear and amplify the difference.
I found the ride to be stock-like when set to maximum height (about 1 inch lowered). Slightly softer on small bumps and harder on larger bumps. The problem is the stock shocks do not have enough dampening and rebound to keep up with the springs and so it feels a bit floaty when you are driving fast. I changed to KW V3s and it is a night and day difference. That really woke up the car and it feels much more responsive. The ride quality is not as smooth as stock but it's fine most of the time with none of the floating feeling of stock shocks.
Auto Detailing Enthusiast!
05-15-2013, 09:16 PM | #12 | |
Rep 1,512
Yes I agree the spring rates are too much for the stock shocks to handle. When I was asking around before I made the purchase no one mentioned the ''floating feeling''.... I thought about going with the v3's but since i've been running ohlin's on my bikes for years I figure why not give them a try.
2022-G80 Xdrive BG
05-16-2013, 11:53 AM | #13 |
Rep 1,164
Yes, I'm still on factory sway bars. I keep my EDC on comfort except for the track which I use sport mode. I have 50,000 miles on mine and the ride is not floaty as others have mentioned. On the 3 tracks that I run, I have noticed an average of around 1-2 second improvement in lap times after switching to KW S/O from Eibach sport springs.
05-16-2013, 12:14 PM | #14 | ||
Rep 5,508
05-16-2013, 01:41 PM | #15 | |
Rep 1,512
2022-G80 Xdrive BG
