New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      07-06-2013, 12:05 PM   #1
APDspider
Drives: 2014 Z4 28i
My car wouldn't start... now it won't shut off
2014 Z4 Comfort Access.
Key is in the key slot, and the amber KEY icon was lit. Couldn't start the car. Couldn't start accesories.
Somehow, after trying for 35 minutes, the car started.
Now as I'm driving it, my vehicle status page says, Engine Start Malfunction. Try opening and closing driver side door.
Now, in Park, at home... my car won't turn off. WTF?
Car is still running. Any ideas?
      07-06-2013, 12:12 PM   #2
jparnes1
jparnes1's Avatar
Drives: 2016 340i, 2012 Z4 35i
Disconnect the battery and have it towed to BMW if you cant' shut it off.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      07-06-2013, 05:07 PM   #3
vasmir
eh
vasmir's Avatar
129
Drives: 2011 E82 M, 2016 F25
6spd or auto?
      07-06-2013, 05:19 PM   #4
HpDellNestle
Drives: Z4
Put a potato into the tailpipe. Put water in the gas tank. Cut the fuel line. Do not attempt any of the above.
      07-06-2013, 06:06 PM   #5
APDspider
Drives: 2014 Z4 28i
It's an automatic.
Drove it to the dealer. They have never seen this. It's in their hands now. I'll post an update next week when I get the car back.
      07-06-2013, 07:33 PM   #6
keepittrill
keepittrill's Avatar
Drives: "Daddy-bought" 2010 Z4
Originally Posted by APDspider
It's an automatic.
That's an annoying thing to have to deal with for a brand new car
      07-15-2013, 06:44 AM   #7
BMWZ4RIDER
BMWZ4Rider
BMWZ4RIDER's Avatar
Drives: 2009 BMW Z4 35i
What was the diagnosis?
2009 BMW Z4 35i/SMG/DCT/Premium,Cold, Sound PK/Com Acc/Ash/PDC/Wind Deflector/Smoked Reflectors/Red Calipers/Cl Mask/M Series Grill/6000K LED's/De-Badged/M Pedals/CF Mirrors-Engine Cover/Stubby/20% Tint/H8 LED's/LCI Side Markers/Sniper Sprint Spoiler/VMR V710/H&R Sport Springs/KN.
      07-15-2013, 09:38 AM   #8
Kessler35is
Drives: 2015 F15 50i, 2016 E89 35is
2016 Z4 35is  [0.00]
2015 X5 50i  [0.00]
The alternator would have kept it running. They would have had to pull the fuel pump relay or fuse to kill the engine.
      07-15-2013, 10:26 AM   #9
Nkc
NOOB
Nkc's Avatar
Drives: Cars
Never heard of a car not shutting off. What happened btw? Will dealer cover the gas that was wasted? Is it possible that its a 28i issue?
@BMWclassicdivision
      07-15-2013, 12:46 PM   #10
army_men
army_men's Avatar
46
Drives: E89 Z4 35i
2011 BMW Z4 35i  [10.00]
sounds like a electrical malfunction. I wonder how the dealer is going to deal with this. any updates?
      07-15-2013, 12:57 PM   #11
marcw
marcw's Avatar
Drives: 2021 M2 Competition
I seem to have a similar problem. 2010 6spd 35i with comfort access. Car didn't start last night. On first try the engine turned over once but then stopped when I released the start/stop button. Now all that is happening is some sort of spooling/whining noise when I push the start button. No error messages anywhere. iDrive tells me all systems OK. The instrument cluster comes on and I can use the radio etc so I doubt this is a battery issue. The engine isn't running but I'm not able to turn off the car with the start/stop button. Pushing it while all the electrical systems are on does nothing. I have to insert the keyfob and pull it back out for the car to power down. Let it sit all night and tried again this morning with the same result. Going to have it towed to the dealer tomorrow :/
      07-15-2013, 12:59 PM   #12
jpwolfe31
Drives: 2009 Z4 35i
Sometimes I cannot get my computer to turn off. Not surprising that our computerized cars have similar issues.
      07-15-2013, 02:18 PM   #13
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
That is the behavior for a non comfort access car.
Total speculation here, but maybe your key fob battery just needs to be changed.
      07-15-2013, 03:38 PM   #14
Kessler35is
2016 Z4 35is  [0.00]
2015 X5 50i  [0.00]
The spooling/whining noise sounds to me like the starter solenoid is not engaging, so the motor is just spinning and not moving the starter gear to mesh with the flywheel gear.
This can happen because of a bad solenoid/starter or a low/bad battery (loose or corroded terminals can cause low voltage to the starter also.
90% of the time if the battery is fine they change the entire starter since that also replaces the solenoid.
      07-15-2013, 04:37 PM   #15
marcw
marcw's Avatar
I'll put the battery on a tender when I get home and try my luck starting the car with a new battery in the keyfob and/or the second keyfob. If all fails it'll be towed to the dealership tomorrow. Luckily I'm still within warranty so should be free, unless it's the battery. I've had a low battery on my 530xit before and all sorts of things were malfunctioning because of that. This doesn't seem to be the case here.
      07-15-2013, 05:31 PM   #16
bjarne
Drives: 2014 X3 35i
I wonder if this can be related to the battery terminal recall, did you have that done?
      07-17-2013, 05:56 PM   #17
marcw
marcw's Avatar
Just got a call back from the dealer. No power at the starter. Replaced under warranty. Seems WAY early for a starter to go. Car has under 30k miles!
      07-17-2013, 07:26 PM   #18
jparnes1
jparnes1's Avatar
It is too early , but stuff happens. that's what warranties are for.
      09-08-2013, 12:06 AM   #19
APDspider
Drives: 2014 Z4 28i
Sorry for the delayed reply.
Here was the diagnostic. The start/stop button wiring harness was pinched, as was the comfort access harness. It was pinched at the factory during assembly. They replaced the harness and all is normal.
Cheers
      09-08-2013, 01:10 AM   #20
InsanePineapple
Shenanigans
InsanePineapple's Avatar
Drives: See Signature
Cheers
Wow, what a ridiculous problem. Glad you got it sorted out.
[Current] Tesla Model 3 Performance
[Retired] Audi R8 V10 6MT, BMW i3 BEV, BMW i3 REx, BMW Z4 sDrive35i DCT, BMW 335i Coupe 6MT
      09-08-2013, 06:55 AM   #21
BMWZ4RIDER
BMWZ4Rider
BMWZ4RIDER's Avatar
WOW. No one but the dealer would have found that one. That dash is Pre assembled and goes in complete. What a strange issue.
Great you got it sorted out.
      09-08-2013, 01:40 PM   #22
Innovative AutoConcepts
Drives: 2009 Z4 E89 Alpine White
that sucks. glad you got it all sorted out.
zpost
