07-17-2013, 02:24 PM | #1 |
Rep 12
Ride-On Tire Sealant
http://www.ride-on.com/auto-and-suv-formula.html
Has anyone used this sealant on their car? When I was riding bikes, I used it on both of them. Both bikes had aluminum wheels and the sealant does not attack the aluminum. It does not create a hugh mess on the inside of the tire. But what it will do is seal a puncture when your out in the middle of nowhere without a spare. This is different than the "Fix-A-Flat. Since I will buying new tires shortly, I though about adding this as well. Very easy to install. Let the air out, put this in, add air, drive away. On my bikes after the install I would drive away slowly at first to let the liquid coat the tire. |
07-17-2013, 02:46 PM | #2 |
Rep 2,387
That stuff is probably the same as the mobility kit BMW sells or Conti's emergency inflation kit. The only thing is that you need some compressed air to inflate your tire, so one of these kits may be the more convenient thing.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
07-17-2013, 02:51 PM | #3 |
Rep 12
This goes in the tire and stays in. It does not go in the tire after the flat.
07-17-2013, 02:54 PM | #4 |
Rep 2,387
I see. Make sure it doesn't mess up the pressure sensor on the valve. The stuff you use to fix a flat does and you need a new sensor.
07-17-2013, 02:59 PM | #5 |
Rep 12
07-17-2013, 06:12 PM | #7 | |
Rep 176
If so, I didn't think Z4's had tyre pressure sensors on the valves. I thought they had a system for detecting tyre deflation which was based on the different rotational speed of the wheel who's tyre had deflated? Apologies in advance if I have mis-understood. |
07-17-2013, 06:45 PM | #8 |
sportscars only
3300
Rep 3,219
Silly question, I've had my tire fixed for punctures numerous times by non-BMW techs...does my TPS still work or is it is missing now that they replaced the valves? I'm clueless.
07-17-2013, 07:25 PM | #9 | |
Rep 2,387
07-18-2013, 08:08 AM | #10 | |
Rep 547
07-18-2013, 08:40 AM | #11 |
Rep 2,387
they likely just plugged the hole without taking the tire off the rim. To patch it from the inside, you obviously have to dismantle the tire, but you would know because you'd be charged for mounting and balancing, not just the puncture fix.
07-18-2013, 09:45 AM | #12 | |
Rep 176
I'm based in the UK in case it makes any difference. Do cars with the TPMS system have to have special valves fitted when tyres are replaced? |
07-18-2013, 10:47 AM | #13 | |
sportscars only
3300
Rep 3,219
Everytime I had a plug, I needed rebalancing (that's what they always charged me for) so they had to take the tire off of the wheel. However, according to the above post, I guess that I should be ok or else I would have gotten an alert? Do non-BMW techs know about these TPMS and just work taking them into account? |
07-18-2013, 10:55 AM | #14 |
Rep 10,509
http://www.amazon.com/Victor-22-5-00...dp/B000AMOEGY/
With one of those doesn't seems like rebalancing or even taking wheel off car is needed. |
07-18-2013, 11:33 AM | #15 | |
sportscars only
3300
Rep 3,219
07-18-2013, 11:47 AM | #16 | |
Rep 2,387
07-18-2013, 05:04 PM | #17 |
Rep 176
07-18-2013, 05:12 PM | #18 | |
Rep 176
As an idea, I recently had a puncture repaired and it cost me £20 (approx USD 30) to have it repaired. Not sure how much you got charged but hope this gives you a rough guide. |
07-18-2013, 05:24 PM | #19 |
Rep 10,509
on the record BMW won't repair rft. Off the record bmw techs and sales people all use the type of kit I posted on their own vehicles. I paid a friend of a friend $20 the first time to see how it was done then bought the $10 next time and did it myself.
My fix was all good for 20k miles of 328 commuting. Never lost any more air than other tires and no need for rebalance. (I turned the car in after 20k miles... Fix was fine) Not sure I would do that for a tire I tracked but for street I would do it again for sure. Worst case, I need a new tire. Best case, $2 fix saves me $400 |
07-18-2013, 05:36 PM | #20 | |
Rep 176
Both Michelin and Bridgestone state that their run flats can be repaired subject to inspection and no sign of damage/degradation to sidewall etc. although they recommend that a new tyre is purchased (it's somewhere on their website). Think we'e gone slightly off topic here ;-) |
07-18-2013, 05:46 PM | #21 | ||
sportscars only
3300
Rep 3,219
07-18-2013, 06:23 PM | #22 |
Rep 10,509
It is so on topic.. We have advised OP to watch out for his TMPS and mentioned some other solutions rather than a preemptive usage of the fix a flat goop.
@tranquility... it is super easy... you thread the rubber twizzler thing through the eye hole in the T handle, then coat the twizzler with epoxy, pull out the nail, jam the handle (epoxy coated rubber twizzler and all) in then pull it back out. That motion creates a plug in the hole. You finish up by cutting the ends of the twizzler that are sticking out of the tire with box cutters, and put more epoxy on the outside for good measure. After that you top off the air and reset the TPMS. Takes about 5 minutes (and the kits have pictures of all steps). I've had 3 of those 1/4" diameter or less puncture that were more than 1" away from the edge of the tread. 2 of them fixed fine with the twizzler kit and 1 was a fix a flat epic fail back on topic... i think the orig product posted will fall into the fix a flat epic fail category EDIT: I think I left the twizzler repair kit in the trunk of the 328 I returned recently I can't find it.. I was going to post a pic of the instructions for tranquility |
