New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      07-25-2013, 09:59 AM   #1
unicenter
Z4 35i DCT,X5 35d Hartge Tuned,Mini R56 JCW
unicenter's Avatar
Greece
Drives: Z4 35i DCT,X5 35d Hartge Tuned
Exclamation Problem with 19'' Michelin PSS
Hi.
Today i put new tires 225/35/19 & 255/30/19 Pilot Super Sport at my car.
When i went for a ride with the new tyres i notice that the car is very nervous at driving and very unstable even at straight line also at corners.
It is so bad that you cann't drive fast for any reason.
It is 35i with m suspension and 313 performance wheels.
Does anyone her know why???
Need your help.
Thanks
      07-25-2013, 11:12 AM   #2
CedarZ4
Drives: G05 M50i, Tesla M3P
Did you get them balanced when you got the tires mounted or were the old ones just taken off and new ones mounted back on and the shop called it a day?
I don't personally have PSS, but I did go from RFT to non-RFT, and before they were balanced the ride was very wobbly for sure.
Another possibility (but related to balance as well) is that while mounting, they could have knocked off a few weights on accident... Definitely check that first. And if the wheels won't balance, then I will look into a manufacture defect tire.
      07-25-2013, 11:31 AM   #3
E89Tardis
Drives: 2009 Z4 35i
Did they possibly talk you into an alignment and then mess it up ?
      07-25-2013, 12:43 PM   #4
VailM3
Drives: 2011 Z4 35is
sounds like balance and alignment issues.
      07-25-2013, 01:17 PM   #5
jparnes1
jparnes1's Avatar
Drives: 2016 340i, 2012 Z4 35i
It's NOT the tires.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      07-25-2013, 01:40 PM   #6
unicenter
unicenter's Avatar
Greece
The balance is ok.
Also the pressure is 36 front 45 rear.
How you are sure that is not the tyres???
      07-25-2013, 02:06 PM   #7
mbetoni
Drives: 2014 Z435is
I think what JP meant is that many of the folks here run PSSs with no problems whatsoever, so anecdotally, it's probably not the tires.
As others have said:
Balanced properly? Aligned? Beyond that, dumb place to look, but I've seen dumb things before: tires are unidirectional and staggered, are they all on the correct side/facing the right way? If all that checks out might be time to start looking for some suspension gremlins (bushings, tie rods, etc).
      07-25-2013, 04:32 PM   #8
jparnes1
jparnes1's Avatar
A long time ago I had a front set of no frills tires mounted and the car developed the shimmies at high speeds. After alignments, etc (with no success), I swapped the fronts and the rears and the shimmies went away. Bad tire(s). It's possible, but I doubt this would be the case with Michelin. It's' very likely something mechanical.
      07-25-2013, 06:32 PM   #9
CedarZ4
I agree it is most likely mechanical, but just for argument's sake... When I was looking at UHP A/S tires, I came upon the Michelin Pilot Sport AS and really liked it. Upon further research, looks like it had a lot of quality issues with the tire in various batches - namely pre-mature chunking. I know it's a difference tire and the PSS is such a high-demended tire it should be fine, but not something I would rule out completely. More importantly, who knows if the quality control is the same in Greece compared to the US. But anyway, off-topic.
OP, like every said. Check balancing and alignment. Making sure the tires are mounted correctly (outside is outside) and if all else fails, would then look into the tires themselves.
zpost
