BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
European Auto Source (EAS)
      09-12-2013, 02:42 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Rogue Engineering Front Tension Rod/Arm Upgraded Bushing
Get in Control!
Are you looking for more control over the front end of your E9X M3? We've got the solution for you!
While the stock front tension arm bushings are designed to offer a compliant ride while trying to control the front, it cannot overcome age, added power, or increase use (like at the track). This front bushing takes a large share of the suspension load under braking and hard cornering. Our solution is designed to to outlast and outperform the factory bushing in many ways.
Rogue Engineering's Tension Arm Bushings (TABs) is an elegant, engineered solution to this issue.
Rogue Engineering's TABs are designed allow the thrust arm to move without this spring load, but instead, allowing movement though its range without this specific resistance. By allowing the center bolt sleeve to pivot instead of our custom urethane-silicone bushings smoothly, there is no unnecessary wear and tear.
Our exclusive, made in USA, urethane bushing has all the same properties as the other bushings Rogue Engineering produces. A special silicone formula is injected into each and every bushing mold during the casting process to ensure a lubricious film impregnated at all times (even without grease!).
Another Urethane Bushing?
Some will try to compare the Rogue Engineering Thrust Arm Bushings to a currently available urethane replacements. There is a big difference! Instead of using urethane to control the entire area of deflection, we've engineered an aluminum housing to reduce the ID of the hole of the thrust arm bushing. By doing this, we can fine tune the urethane compound so that we can get performance without unwanted NVH. In order to get our level of deflection control, other companies would have to make their entire bushing so incredibly hard that their product would either vibrate, squeak or both!
Less unwanted bushing deflection means more control! Take control of your BMW! These bushings are available in our STREET compound (black) or TRACK compound (blue).
This produce fits the following vehicles:
E9X M3, including Coupe, Sedan and Convertible
E9X 3-series with E9X M3 front tension arm retrofitted
E82 1 M Coupe
E8x 1-series with E9x M3 tension arm retrofitted
$239
Order yours here:
http://www.hpashop.com/Rogue-Enginee...-E9x-M-TAB.htm
      09-20-2013, 08:48 AM   #2
TurboBimmer
TurboBimmer's Avatar
Luxembourg
79
Drives: F82 M4
Hi,
does this replace the same bushing as Dinan's lower control arm monoball kit?
Is the price per bushing or for a pair?
Thanks.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
      09-21-2013, 06:33 PM   #3
HP Autosport
Drives: F80 M3
Originally Posted by Autobahn335i View Post
Hi,
Thanks.
Yes, these are the front tension arm/rod bushings or lower/upper control arms(different terminologies).
Price is per pair, a very good value.
      09-24-2013, 07:21 AM   #4
TurboBimmer
Luxembourg
79
Drives: F82 M4
Which compound would you suggest for a half-stripped weekend warrior/trackday car? Would "track" be overkill/not manageable on the street?
      09-25-2013, 03:31 PM   #5
HP Autosport
Drives: F80 M3
Street or the black bushings. The race or the blue is for track only car.
Just did this to my personal 1M. Steering, braking and over responsiveness are all improved. NVH increase is minimum.
      10-02-2013, 08:21 AM   #6
TurboBimmer
Luxembourg
79
Drives: F82 M4
Order placed
      10-15-2013, 11:18 PM   #7
HP Autosport
Drives: F80 M3
Order placed
Love to hear your feed back on these wonderful bushings!
      10-18-2013, 09:59 AM   #8
Triple M
Doc Rebel!
Triple M's Avatar
Drives: Fire Orange M3, X5M, Blk 135
Hi Harold,
Thanks for offering this great option. I have been staring at the Dinan piece for a while and I'm glad I didn't pull the trigger. NVH is not an issue to me (Heck most of us have abnoxious but beatiful sounding exhaust anyways that takes care of that :-) ). Nothing is much scarier than approaching turn 3 at Fontana and wondering if some day that front end may become too compliant trying to treshold break LOL. I would definitely love to pull the trigger, but need a few advise
1. Is the Monoball kit any better (for a car that is 80% 20% street)?
2. Do they offer the FCAB (Upper arm), I have been holding off on the Turner FCAB?
By the way, thanks for all your help with my 1351. I will be hitting you up soon on my 135 once the body work project is done so we can bring the suspension up to full spec
      10-18-2013, 11:27 AM   #9
HP Autosport
Drives: F80 M3
Originally Posted by Triple M View Post
Hi Harold,
The monoball kit is really meant for a track/race car only, it would be way too much for a street car in terms of NVH. Although some people are okay with it. If you drive on the street at all, I recommend the street version of this upgraded bushings. The track version is still softer than the mono ball.
The thrust arm or tension arm is the upper arm in this case. If you are after the wishbone bushing, the M3 wishbone is what you want as it comes with a solid bearing and there is no need to upgrade that.
Harold
      10-19-2013, 11:24 AM   #10
Triple M
Doc Rebel!
Triple M's Avatar
Order placed for the bushings Thanks Harold. This upgrade for my E92M3 (Not for the upgraded 135 that has the oem M3 arms). How are they different from these:
http://www.turnermotorsport.com/p-23...r-e82-e9x.aspx
Just wanted to make sure all front bushings are matched/or balanced
      10-19-2013, 12:37 PM   #11
HP Autosport
Drives: F80 M3
Well, these are from RE and are urethane and give full articulation of the upper control arm without any bind. In addition, these provides the necessary control under braking and cornering loads. I have them on my personal 1M and love them!
The Turner version seem to be from the BMW Motorsport program or Group N, it's more of a race part than a street part, but it's rubber so that is a bit strange as most Group N parts are spherical in the past. The price point is a bit high for just two bushings in my opinion.
      10-20-2013, 10:02 PM   #12
Triple M
Doc Rebel!
Triple M's Avatar
Totally agree Harold. Just wanted to make sure it wasn't another arm bushing that RE didn't offwr. The RE bushings look amazing. Can't wait to install them!
      11-04-2013, 08:44 PM   #13
HP Autosport
Drives: F80 M3
In stock!
      11-05-2013, 11:58 AM   #14
italyix
italyix's Avatar
Drives: '08 E90 M3
Harold, which other bushings would you recommend to upgrade, besides this one? I see on your webpage you carry two other RE bushing kits. My car has 68k miles on it and at 52k, the engine mounts and diff mounts were trashed (pics are somewhere here on the forum). Am about to get coil overs and want a nice connected ride. NVH is not an issue, just look at my sig!
Thanks!
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782
      11-05-2013, 12:58 PM   #15
HP Autosport
Drives: F80 M3
Thanks!
This bushing is certainly a nice upgrade from the OE M3 rubber bushings, especially you have that many miles on them. The other bushing is more of a track/race bushing and will not be very compliant on the street.
The best coil overs for ride quality and performance in one package will be the Ohlins R&T. At softer settings it's Dr Jekyll and with the turned up it's Mr Hyde. The springs rates are soft for sport/aggressive street use and just firm enough for track days. Making the R&T a track coil overs simply means upgrading the front and rear springs along with a pair of camber plate.
      09-24-2014, 05:48 PM   #16
HP Autosport
Drives: F80 M3
In stock!
      10-10-2014, 09:30 PM   #17
squartus
Drives: 2010 E92 M3 6MT
2010 E92 BMW M3  [10.00]
Whats the install look like on these, can you pound them in and out with a rubber mallet or do you need a shop with a press?
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc
      10-10-2014, 11:25 PM   #18
HP Autosport
Drives: F80 M3
You will need a hydraulic press for this. You can remove them at home and take them to a shop with a press to help you with the rest of the install.
      11-12-2014, 12:27 PM   #19
HP Autosport
Drives: F80 M3
in stock
      02-18-2015, 06:05 PM   #20
HP Autosport
Drives: F80 M3
bump
      02-26-2015, 06:01 PM   #21
tmntmn
///M
Drives: e92 M3/M-DCT
Originally Posted by HP Autosport View Post
bump
Do you recommend getting a new Tension Arm when doing this bushing upgrade? my car has about 57k miles on it.
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI
      02-26-2015, 06:21 PM   #22
HP Autosport
Drives: F80 M3
I highly recommended. That way you have a new joint as well and not have to worry about it failing down the road.
m3post
