M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding
      10-26-2013, 04:26 AM   #1
lumberman
lumberman's Avatar
15
Drives: BMW F10 M5
coding help (CAS module read error)
About video in motion, I am not sure it is my car build, I follow instructions to the grid, the handbreak section, speedlock min/max, but still could not get it to work, any tricks I've been missing?
F10 M5 Juy 2012 build
I also encounter an error when reading code data in ACM module, it said something about file not found, that's annoying because that's where auto start/stop is
I could get TPMS and sports reading to work though
      10-26-2013, 06:15 AM   #2
rjn21
Drives: 2014 M5 LCI
Start stop is in the CAS module:
CAS => 3000 => TC_MSA_MEMORY => aktiv.
Change it to aktiv if you want it to remember the last setting.
Or if want it off permanently, change the below to aktiv:
CAS => 3000 => TC_MSA_DEFAULT_OFF => aktiv
For DVD in motion I have not tried it as its not something that interests me. For 2012 do you have CIC or NBT? Probably CIC.
2011-12 (CIC)
HU_CIC => 3000 => SPEEDLOCK_X_KMH_MIN => value = FF
HU_CIC => 3000 => SPEEDLOCK_X_KMH_MAX => value = FF
HU_CIC => 3000 => VIDEO_NUR_MIT_HANDBREMSE => nicht_aktiv
2012-13 (NBT) and 2014 LCI
HU_NBT => 3000 => SPEEDLOCK_X_KMH_MIN => value = FF
HU_NBT => 3000 => SPEEDLOCK_X_KMH_MAX => value = FF
HU_NBT => 3000 => VIDEO_ HANDBRAKE => nicht_aktiv
Are you saving the file after editing it, then go back into expert/coding to apply it to the module?
      10-26-2013, 11:16 AM   #3
lumberman
lumberman's Avatar
15
Drives: BMW F10 M5
you are right, auto start/stop is in CAS module, that's where I encounter error reading file
I am not sure whether I have CIC or NBT, I will try look for the NBT value tomorrow, in case I do have a NBT
I save after I changed the value of speedlock min/max, handbrake section, then use the back button to expert/coding mode, activate FA, then select that module and code FDL, am I missing something here? I could get trunk open from driver side button, tpms reading, sport gauge to work though
Thanks for the hint
      10-27-2013, 09:31 AM   #4
lumberman
lumberman's Avatar
15
Drives: BMW F10 M5
anyone out there also encounter error while reading code data from CAS module?
I got everything else coded, except VIM and disable auto start/stop, any help would be greatly appriciated
thanks,
      10-28-2013, 09:07 AM   #5
v12
Drives: F10
You either don't have the most recent CAFD for CAS or you lost power to the car.
      10-28-2013, 09:27 AM   #6
lumberman
lumberman's Avatar
15
Drives: BMW F10 M5
v12,
I've been trying to reach you by PM, I think it has been blocked
I text your cell too, but maybe it didn't went thru
where do I get the latest/correct CAFD for my car? I switched on my car the whole time and notebook battery is not a problem.
any help appriciated
Jeff
      10-28-2013, 09:31 AM   #7
v12
Drives: F10
Hey Jeff - I know... the admins on the forums turned off my PM feature on my account.
Didn't get your text.
      10-28-2013, 12:51 PM   #8
jmh
Internet Crash Test Dummy
jmh's Avatar
Drives: F97 X3MC / F80 M3 / F90 M5
Originally Posted by lumberman View Post
v12,
Jeff
You can get the latest PSdz datafiles from shawnsheridan on the F30POST forums
http://www.f30post.com/forums/forumdisplay.php?f=429
He'll provide you with a download link for the light or full files (only needed if you want to flash modules) and the RAR extract password
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107
      10-28-2013, 01:04 PM   #9
lumberman
lumberman's Avatar
15
Drives: BMW F10 M5
Thanks jmh,
I did get the files from shawnsheridan, (thank you by the way shawn)
I am working with esys 3.23.4 and 50.4 psdzdata, somehow it still doesn't have the correct CADF for CAS module
m5post
