11-02-2013, 01:33 PM | #1 |
Rep 3,157
KW V3 Review
Gents,
I was enjoying a drive last night and realized Im long overdue for a review of my KW V3 coilovers so here goes. For as long as I have had cars I've very much been a proponent of spring/shock combos for mild drops and retained OEM comfort levels. I was swayed by many friends whom my wife has deemed 'bad influences' to upgrade to my first set of full coilover suspension. The choice was easy, KW. I made the switch from my EDC shocks/Eibach springs for two reasons. 1. I needed to be able to slam the car for photoshoots and shows but raise it back up a little to make it up my driveway. 2. I plan on tracking the car on a quarterly basis and wanted to +up my track prowess. I was kicking myself for purchasing the ZCP option and then removing the most expensive part! However, after several weeks of driving on the KWs I know that I made the right choice. The car handles like it is on rails and honestly the bumpiness/ride quality is very tolerable, even with the car lowered to the stops ('0' shock setting). I enjoy the occasional powerslide and/or drift around turns or long cascading corners and the car feels much more settled during such maneuvers and inspires confidence while driving. I have yet to make it to the track but will post a review once I do. The install was very strait forward and painless…I accomplished it in about 3 hours by myself on jackstands in my garage. The hardest parts were getting the stock trunk interior in/out and breaking some of the control arm bolts with limited maneuverability under the car. It would have gone much faster if I had had the car on a lift. In summary, I had never thought that coilovers were worth the price but now that I have had a chance to experience the dramatic improvement of the cars handling and appearance that the KW V3's provide I will not own a sports car without them. -Curt
Former Car: '16 SUNBURST GOLD F80 ///M3--6MT/Carbon Cloth (ED Thread) Former Car:'13 SANTORINI BLUE E92///M3--6MT/Speed Cloth/ZCP(ED Thread) INSTAGRAM:@C2KMotorsports Last edited by Curt2000; 11-02-2013 at 02:30 PM.. |
11-03-2013, 03:26 AM | #2 |
Rep 1,324
You have a sick ride my friend. good combo's with tires and brakes and looks just right as for hight.
I'm looking to lower mine too but I don't have ZCP. So few questions I have; - Did you get the emulator to shut off the check light for the EDC? - With bumpy and shitty SW roads, is it beating the snot out of the car? - How do you rate your turn in, grip, overall performance compared to when you had the ZCP OEM set up? I'm on the fence with keeping my OEM struts and going Dinan or KW Sleeve kit so to retain the drivability and shock strut travel and not screw it all up. Last edited by BimmerRob08; 11-03-2013 at 03:53 AM.. |
11-03-2013, 11:39 AM | #3 | |
Rep 3,157
I expected the car to ride like a skateboard with coilovers but the KW set-up really impressed me with ride quality. I have them lowered all the way and the shocks at the '0' setting so I can still soften the ride a bit with the negative settings. The only time Ive felt like the car really took a good jarring was going over an intersection with a large dip at about 50mph causing the car to squat pretty far and either hit the stops or bottom out. I suspect if I had them set up a little higher and softened the dampener setting then it would be pretty close to sport mode in EDC for daily driving. Turn-in is pretty aggressive with standard M3 oversteer but very grippy. body roll is dramatically reduced over stock and as I talked about in the first post, the car feels much more settled in turns. I wish I had logged lap times and entry speed data to show that Im able to carry more momentum into corners but unfortunately I don't have much track time in this car yet. I think my favorite part of this suspension is the feel of the steering wheel response, its so much tighter and more responsive…I find myself swerving down straight roads for no apparent reason other than the enjoyment of how solid the car feels lol. Hope this helps with your questions.
Former Car: '16 SUNBURST GOLD F80 ///M3--6MT/Carbon Cloth (ED Thread) Former Car:'13 SANTORINI BLUE E92///M3--6MT/Speed Cloth/ZCP(ED Thread) INSTAGRAM:@C2KMotorsports |
SEFcollector1.50 |
11-21-2013, 01:03 PM | #4 |
Rep 602
Nice review, great lookin' car.
I've got the Eibach springs so this is the exact comparison I've been looking for. I've been pretty pleased with the Eibachs in terms of comfort and improved handling. How do the coils compare to eibachs in terms of comfort? Like I've got a 6month old...in terms of his comfort on the roads (knowing I drive through NYC)...is he going to be happier (less head banging/bumping in his car seat) with coils or current setup =)
[08 e90 M3. Jet Black/Black. Dinan Rear Exhaust. ACM Test Pipes. ESS Tune. Eibach Pro-Kit + e36 bumpstops. 18x10 Apex Arc-8. AA Air Filter. RPI Scoops. CREE Angel Eyes. OEM Blacklines. Black Reflectors. Gloss Black Grills. Matte Black Gills. ZCP Shift Knob]
11-22-2013, 10:55 PM | #5 | |
Rep 3,157
SEFcollector1.50 |
12-01-2013, 03:48 PM | #8 |
Rep 3,157
12-10-2013, 03:02 AM | #10 | |
Rep 1,324
Looks great though. By the way, I saw a youtube video not long ago about I think was KW coil over installation, the wireless adjustable kit, and they go over the wiring issue you talked about. Complicated without a good wiring diagram so be careful and unless you know someone you can trust with electronics, don't let them or you go chopping into wires! Had an idiot friend that installed stereo's out of all things screw up my truck years ago to the point that when I turned on my headlights, I'd get a static jump through the speakers, no kidding! I had to go figure it out and fix it and I'm not an electrician but a mechanic. |
01-04-2014, 12:07 PM | #11 | ||
Rep 3,157
01-04-2014, 12:29 PM | #12 |
Rep 5,508
You can have the EDC coded out of the car if you know someone who does BMW coding. I still feel more comfortable knowing something is physically plugged into the plugs so it doesn't collect dirt and get messed up if I decide to go back to the EDC shocks.
Auto Detailing Enthusiast!
