11-11-2013, 06:19 PM | #1 |
Rep 7,902
New AP Racing FORGED Radi-Cal Brake Systems!
AP Racing, the leading manufacturer of performance braking and clutch systems, for road and race use, has created a new range of Radi-CAL™ brake calipers, which incorporate race technology into high-performance road products. AP Racing's Radi-CAL racing calipers have taken the racing world by storm, dominating the highest level racing series on every continent. The pressure forging process results in a strong, stiff caliper that is 20% lighter than similar cast calipers. Each caliper has been tested with over 500,000 cycles of pressure and torque to meet AP's stringent quality standard. The non-symmetric design is the result of Finite Element Analysis testing to determine where weight saving can be achieved without compromising strength and stiffness. Radi-CAL calipers are double sealed for durability. Hard anodized aluminum pistons are differentially sized to maximize pad life. A removable forged Bridge allows for easy pad changes. Anti-rattle springs prevent pad movement and knock back. Available as six and four-pot front calipers, as well as a four-pot rear caliper, the new range of Radi-CAL™ products distil the company’s expertise in producing brake systems for race and OEM installations, into calipers suitable for the aftermarket. As a result Radi-CAL™ delivers an advanced brake upgrade for the owners of high performance and sportscars. Featuring a two-piece aluminium body and h-piece, the forged non-symmetrical calipers offer a significant reduction in mass compared to conventional designs, and improved efficiency when resisting the torque generated by braking. This not only lowers a vehicle’s un-sprung weight, but also ensures continued high performance in demanding applications. AP Racing’s advanced design process allows the concept to minimise structure and weight, while improving caliper cooling surface area, without sacrificing rigidity. This provides improved brake caliper cooling and reduces disc temperatures during high performance driving. The Radi-CAL(tm) calipers feature a highly durable paint finish featuring the distinctive new Radi-CAL(tm) logo, and available separately or with matching performance road-car discs and pads for specific customer requests. The Radi-CAL(tm) Factory Big Brake kits incorporate floating two-piece disc assemblies, and include bespoke mounting bracket and bolts, a braided hose kit and DOT 5.1 high temperature brake fluid. Includes D701 Ferodo DS2500 Brake Pads AP J Hook Rotors Custom Goodridge SS Line Optional AP Racing, Street, Semi Track, Track brake fluid. Application E9x M3 APR7120 Front 370x36mm 6P E9x M3 APR7170 Rear 360x28mm 4P E9x M3 APR7110 Front 390x36mm 6P E9x M3 APR7160 Rear 380x28mm 4P E9x 325,328i, 330i or 335i APR6410 Front 370x36mm 6P E9x 325,328i, 330i or 335i APR6460 Rear 360x28mm 4P E46 M3 APR3810 Front 370x36mm 6P E46 M3 APR3850 Rear 360x28mm 4P Apex EC-7 18x9.5 ET22 will clear front 370MM Kit Apex EC-7 18x10 ET25 will clear front 370MM Kit & 380MM Rear. No spacers needed. Last edited by Pat@sonictuning; 12-19-2013 at 07:27 PM.. |
11-11-2013, 11:21 PM | #4 |
Rep 1,324
I had heard about this from Stilen while working on my AP's. There may be a chance the new rotors will fit the older calipers, do data to confirm that. When are these brakes released for sale? They look awesome!
11-11-2013, 11:31 PM | #5 |
11818
Rep 23,187
interesting design. looks like the h is the bridge like in the stoptechs for quick pad changes.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
11-12-2013, 01:28 PM | #8 | ||
Rep 7,902
Thank you!
They look more impressive in person. Yes sir! Quote:
Thank you! |
11-12-2013, 01:41 PM | #9 |
Rep 5,329
badass!!
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
11-12-2013, 02:18 PM | #11 | |
Rep 5,329
11-13-2013, 02:03 AM | #12 |
Rep 143
Has anyone test fitted these with Apex 18s? I doubt the 390 kit will fit under 18s, but just curious.
2009 E90 ///M3 SG Fox Red 6MT Slicktop, AA X-pipe w/straight pipes w/Eisenmann Sport, Dinan intake, AA Pulley, ZCP strut retro w/Dinan Stage III susp, BPM Stage II tune, Rear Fog LCI switch, BMW Edition Front & Side Grill/Gill, Thrust Arm Monoball, Solid Subframe Bushes, Black 19x9.5/10.5 APEX PS-7s, Vibra-Technics engine mounts, Auto Solutions shifter 20% throw, WPC treated Rod Bearings & AiB v4-Now, Not Wife approved!!
11-13-2013, 10:32 AM | #16 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Looks like a quality product from a quality brand but that name... Radi-cal? Very odd name that I don't associate with a quality product. It reminds me of an info-mercial name brand. Sham wow!
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
11-13-2013, 10:43 AM | #17 | ||
Rep 7,902
18s have not yet been tested Quote:
Its a design for both racing and driving on the street |
11-13-2013, 10:55 AM | #19 |
Super modder
104
Rep 1,973
Looks like a really nice kit...what is the "normal" kit cost and this kit cost for E90 M3 with stock 19" and 20" LM-Rs (6f/4r) large disks
Thanks
SOLD - 2005 E46 M3 ZCP - I/B on black CURRENT - 2011 E90 M3 - meticulously modified 2015 X1 Xdrive 28i |
11-13-2013, 12:10 PM | #20 | ||
Rep 321
prob moreso because "radial" brakes and radical |
11-13-2013, 02:22 PM | #22 | |
Rep 7,902
PM your email, and I can send it to you. We are in the finalizing phase for the template of the 370, just need to confirm few things. A good shot of the pads and caliper from another angle. |
Tags |
ap bbk racing, ap big brake kit., ap racing |
