11-14-2013, 06:15 AM | #1 |
Rep 258
Likely ordering soon...some suspension questions
Well, I have done a good amount of reading here and as of now I am leaning towards the X5 M Sport (over the Cayenne).
1) If I order an M Sport Diesel, is the 2vf option "Dynamic Damper Control + rear axle air suspension" standard or a $900 option in the US? If it's an option, does it add comfort to the ride or will it be more sporty/harsh? I would rather have it better with absorbing bumps. Is this option worth it? I do not want full adaptive suspension. 2) Will an Xline/Lux line give a smoother, more comfortable ride with comfort suspension? If so is it just marginally? I like the look of the M Sport quite a bit better. Thanks Last edited by SUV55; 11-16-2013 at 04:30 PM.. |
11-14-2013, 09:47 AM | #2 |
Rep 5
Hi, this is my first post and I have done a lot of suspension research so hopefully I can help you out on that part.
1) If I order an M Sport Diesel, is the 2vf option "Dynamic Damper Control + rear axle air suspension" standard or a $900 option in the US? If it's an option, does it add comfort to the ride or will it be more sporty/harsh? I would rather have it better with absorbing bumps. Is this option worth it? I do not want full adaptive suspension. In the US 2VF is a $900 option. It adds both a more comfortable and sportier ride because it is essentially DDC with a sportier mapping than regular DDC. It will be more comfortable than not having DDC but less comfortable than a non M Sport line with DDC. 2) Will an Xline/Lux line give a smoother, more comfortable ride with comfort suspension? If so is it just marginally? I like the look of the M Sport quite a bit better. Yes but not as much as you may think and that is only if you add DDC. If you are looking for the most "comfort" oriented suspension, from least, to most: 1. M Sport WITHOUT Adaptive M 2. Non M Sport WITHOUT DDC 3. M Sport WITH Adaptive M 4. NON M Sport WITH DDC 5. Any X5 with the Dynamic Handling Package I would recommend M Sport with Adaptive M. I think it looks the best and should give you enough comfort. Or you could go nuts and add Dynamic Handling. Last edited by nicu2001; 11-15-2013 at 10:50 AM.. |
11-14-2013, 03:08 PM | #3 | |
Rep 308
11-14-2013, 04:07 PM | #4 | |
Rep 127
11-14-2013, 08:00 PM | #5 |
Rep 258
Thanks for the comprehensive explanation. Is the Adaptive M option basically a new name for the suspension option for the M Sport vehicle, which is exactly the same as Dynamic Damper Control + rear axle air suspension for the Xline/Lux line vehicles?
11-14-2013, 08:27 PM | #6 | |
Rep 5
If you want DDC on the M Sport package you have to get "Adaptive M Suspension" which is essentially adding DDC with a sportier orientation setting. I have a great slide that I will post tomorrow that will definitely help explain it. |
11-14-2013, 08:32 PM | #7 |
Rep 5
Adaptive M is a $900 option in the US that adds electronic dampening that has a "sportier" setting. Without it your M Sport will not have electronic dampening. This means that "comfort" is more comfortable than a stock F15 or regular M Sport F15 but the comfort setting on Adaptive M is a little less "soft" than comfort on a regular X5 + DDC. Essentially if you want DDC on a M Sport you can only get it by adding Adaptive M. I will post the picture tomorrow which makes this much easier to understand but I think you have the general idea.
11-14-2013, 09:20 PM | #8 | |
Rep 127
I definitely appreciate you explaining things... The problem is I really do have an order in with an order number...M Sport with DDC (see screen shot from IVSR below). Adaptive M was $900, but I am paying $1500 for DDC (2VM). Hopefully we can all get to the bottom of this. My understanding is Adaptive M does not have air suspension, and what I ordered does. But bottom line, I don't want to spend or waste money for no reason. |
11-15-2013, 06:49 AM | #9 | |
Rep 5
11-15-2013, 07:21 AM | #10 | |
Rep 420
11-15-2013, 01:26 PM | #12 |
Rep 5,756
Drives: '24 iX50; '23 Audi RS etron GT
Now that Jason made your chart a Sticky, not sure how frequent the responses.
Here was my question: I know there is also another Thread below this discussing the same questions (and sorry for beating a dead horse), but let's stick with this one... If ordering, I would get the MSport w/out 3rd row and at least the $900 Adaptive M Suspension option. What more am I getting if I were to order the Dynamic Handling Package? My goal is sport not comfort. I would want the F15 to handle as flat as possible around corners unlike my E70. Is the ZDH worth a $3600 premium or would those monies be better off spent on other options for better resale?
'24-I20 iX 50; '23 RS etron GT; '23-G26 i4 M50*; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
11-15-2013, 02:02 PM | #13 | |
Rep 5
11-15-2013, 03:57 PM | #14 | |
Rep 5,756
11-16-2013, 11:57 AM | #15 | |
Rep 258
The chart is very helpful but just how accurate is it? It says an M Sport with Adaptive M on comfort setting is more comfortable/smoother ride than an ML350. Does this sound right? Last edited by SUV55; 11-16-2013 at 04:26 PM.. |
11-20-2013, 12:02 AM | #16 | |
Rep 46
11-20-2013, 04:13 AM | #17 |
Fragile Explosion
23
Rep 113
Assuming the chart is accurate, what it doesn't show is where the other cars rank with their various comfort/sport settings, that said I don't know if they all have them, but certainly the Cayenne offers additional sports mode.
