M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding
      11-21-2013, 10:03 AM   #1
Stiggly
Drives: M5 2014 LCI
Headlight unit failure or normal?
My M5 has LCD headlight units and today I noticed a small patch of condensation on the inside of the glass, right by the section that has the BMW Adaptive signage.
I haven't used the car for 4 days and the outside temp is 8 degrees.
Question: is this normal or are both units faulty?
      11-21-2013, 10:16 AM   #2
RPiM5
RPiM5's Avatar
2878
Drives: Black M5
They might not be sealed properly if there is condensation. I'd tell the dealer to take a look at them.
      11-21-2013, 10:29 AM   #3
scoobyc
Scotland
Drives: LCI F10 M5
Red face
My LCI did this too the first time I washed it on a cold day. It's something I'll keep an eye on but not too bothered at this point unless it gets worse.
      11-21-2013, 10:32 AM   #4
B-1Pilot
Yankee Air Pirate
B-1Pilot's Avatar
Drives: '14 M5 w/CP
Me three... very minor condensation that evaporated out
deposit placed for 2025 G99 ///M5 Touring || 2020 F90///M5 || 2014 F10 ///M5 || My Epic ED trip report|| || 2009 BMW R1200RT
      11-21-2013, 10:33 AM   #5
stealth.pilot
Knight Commander
stealth.pilot's Avatar
Drives: 2014 911 Turbo S
This was considered normal with Xenons.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      11-21-2013, 10:38 AM   #6
Stiggly
Drives: M5 2014 LCI
I will keep an eye on it to see if it develops further.
      11-24-2013, 04:00 AM   #7
Bogbrush
Drives: M5 5.0 Grey
The light unit is not air tight or you would not be able to change the bulbs. The condensation is caused by water vapour in the air inside the lighting units and is not in itself a problem unless it damages electrical connections or starts any kind of corrosion or mildew infestation. It should go away with warmer weather, but if not have the lamp units checked for water ingress. A hair dryer will usually dissipate the condensation itself but will obviously not resolve any underlying problem.
      11-24-2013, 04:03 AM   #8
Stiggly
Drives: M5 2014 LCI
Ah...that makes sense.
I've done a bit if driving with the lights on and it seems to have improved.
Will keep an eye on it just in case
      11-24-2013, 04:45 AM   #9
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
Agreed its not air tight. Just take it in as its under warrantee and they should replace w no questions asked. You don't want to be somewhere where failure could happen when you need those lights.
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run
m5post
