11-26-2013, 12:49 PM | #1 |
Rep 1,805
Stoptech st60/40 VS. Stoptech Trophy...
Any input here? Strictly for tracking...
Does the trophy kit really perform any better? Stopping power, consistency and fade resistance are most important.
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2 ACS - 1:49:6 WSIR - 1:30:6 |
01-17-2014, 12:03 PM | #2 | |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
The finish on the Trophy Sport will also remain fresh event after event without fading. The painted calipers will likely fade after a few track events. Trophy Sport is also lighter so you are saving unsprung weight. |
01-17-2014, 01:09 PM | #3 |
America
11
Rep 62
If its strictly for tracking I agree, the Trophy is the way to go. Its a step above the others designed specifically for track use. Regardless of the kit you get I recommend a front splitter with cooling ducts then they will be absolute beasts. Airflow is crucial!
-Mid-Ohio-
01-17-2014, 05:20 PM | #4 |
Rep 9,034
I didn't think it was worth the $1,400 difference when I got mine. It's not necessarily a bad thing to have a little extra mass in the brakes for increased thermal capacity.
There have been a few people here with the Trophies where the finished went bad pretty quick. Not sure if it was a bad batch or a they used some strong wheel cleaner.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
01-17-2014, 06:56 PM | #5 | |
Rep 891
IMO the Trophy kit is an aesthetic upgrade for some. I've driven the same car, E90 M3, at Watkins Glen with both kits and there was never an issue with fade, consistency or stopping power between the two kits. Last edited by Bx Tpr; 01-18-2014 at 02:34 PM.. |
01-18-2014, 12:13 PM | #6 |
Rep 2,342
I couldn't justify the extra expense, so I got the standard kit - from HP actually. The kits look like they spec out the same so I don't think you could go wrong with either.
I think if you're doing a true track only and that's the main consideration above all the Essex kit thats upcoming looks very promising. Although they are priced closer to the Trophy kits. |
01-19-2014, 09:15 AM | #7 |
Rep 8,077
Drives: 11 E90 M3 Individual
Get some titanium backing plates and your finish will likely not turn. Mine are still a nice red and I've only ever seen one set of ST red calipers turn brown.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-21-2014, 11:14 PM | #8 |
Rep 2,342
01-22-2014, 12:58 AM | #9 | |
Rep 7,298
How does that affect bias though? Funny. Ive always been that guy who says no one needs this shit the car can handle a lot more than one could throw at it aka a professional would prob be faster in a bone stock car but i find myself upgrading all this crap for track for confidence and better wear and tear. I better get fast soon or ill be that guy with a boat load of mods and slow Next mission is nannies off, start off slow and gain speed. Mdm has gotten me to a confort level already to start dsc off. Been reading speed secrets too so mentally preparing for it too (which is the biggest deterent to go dsc off as in look theres a walk there, another one there, etc) |
01-22-2014, 09:39 AM | #10 | |
Rep 3,675
01-22-2014, 09:41 AM | #11 | ||
Rep 7,298
01-22-2014, 09:59 AM | #12 | |
11818
Rep 23,187
01-22-2014, 10:12 AM | #13 | ||
Rep 7,298
01-22-2014, 12:10 PM | #14 |
11818
Rep 23,187
I did my bbk myself. Not that bad. I don't like my mod money going to labor.
01-22-2014, 12:22 PM | #15 |
Rep 996
knsbrakes.com sells the titanium shims.
http://knsbrakes.com/c/car-series/14...s+-+.5mm+Thick http://knsbrakes.com/c/car-series/14...ms+-+1mm+Thick |
01-22-2014, 12:26 PM | #16 |
Rep 996
Unless you have started to push the OEM system with upgraded sections then I doubt you will even push the ST 60/40 to its limits. I say go with the ST 60/40 if you really feel the need for a BBK. Or do minor upgrades to the OEM (Fluid, Pads, SS lines, Titanium shims and maybe a better Rotor) and use the rest of that money to get driving lessons to get your skills to the level in which a BBK is really needed.
01-22-2014, 12:46 PM | #17 |
Rep 2,342
I feel better using a BBK at 60% capacity than using my OEM brakes at 100% capacity. It's always easier to drive harder than it is to push something beyond it's limits.
Thanks for the info on the backing plates. A google search revealed quite a few options. |
01-22-2014, 12:54 PM | #18 | |
Rep 7,298
sometimes paying for mods doesn't even work...i've heard of bbk's being installed and not being able to bleed fluids because it was upside down (didn't even know) DERRR |
01-22-2014, 01:15 PM | #19 | |
Rep 996
Glad you found the shims, I think the website I stated has great prices compared to most. |
01-22-2014, 01:52 PM | #20 |
11818
Rep 23,187
I find that once you have increased capacity you find a way to use all of it fairly quickly and are right back at the same point only quicker laps. People don't add power then not use it right!
01-22-2014, 04:54 PM | #21 |
Shosholoza
32
Rep 188
I live in Florida, so heat is an issue. Sebring is my home track, so speeds are high, the track is heavy on brakes. I drive in the red/instructor group, so I use the brakes pretty hard.
I'm one of those who finally installed a BBK (ST60), and kicked myself for not doing it sooner. I installed front BBK only. Excellent track performance and modulation with carboteck and Endless track pads. The street pads are very good too. I now get 6-8 track days out of a set of pads. I wouls have saved a lot of money if I had installed my BBK sooner. Also, I feel that I am not using the system at 100% of its capability, so I feel safer. Before that I went through all the time and money of: Motul brake fluid, track pads (Pagid Yellows, Carbotechs), cooked and replaced my OEM front calipers, added a Cantrell brake cooling kit. The cooling kit meant that the pads last 2 days instead of 1 day. And I felt I was running the OEM brakes at 110%.
SOLD...E92 M3, Competition Package, MDCT, Ground Control Adjustable Camber plates, StopTech 380 BBK, OEM exhaust mod
01-22-2014, 05:27 PM | #22 | |
Rep 8,077
http://www.zeckhausen.com/StopTech/c...s.htm#Titanium The reason I prefer the ST40 setup is the better pad selection, cheaper consumables and less hassle in fitting wheels for the minimal if any increase in performance. The ST40 pads are 2mm thicker based on actual measurements. Just a visual tells me that the ST60 uses 3 smaller pistons on each side vs 2 larger ones on the ST40...not sure if the ST60 has more piston area which would give the car more braking force. But the ST40 caliper is lighter and the rotor is smaller. My guess is that they are about the same in terms of performance.
