10-26-2007, 07:50 PM | #1 |
Rep 55
EDC dampers: Expendable or serviceable?
They must cost a lot, so here is a practical question.
Can they be serviced / repaired or do they have to be thrown away (changed) at the end of their term, like ordinary dampers? What's the firm's policy on that? Btw: how much would they cost as spare parts? |
10-27-2007, 12:23 PM | #2 |
Law Enforcer
25189
Rep 22,304
That's a good question; one that probably cannot be answered accurately at this time being that the car and its EDC suspension is new. It would be nice if BMW made them rebuildable like an aftermarket damper.
11-23-2007, 06:29 PM | #3 |
Rep 239
But is history is any indication the EDC system on the e34 M5 had very expensive and not rebuildable shocks. I expect that these M3 shocks will be very expensive to replace. They might be very durable though, so this just might not be an important issue. Aftermarket solutions might also be possible.
11-23-2007, 08:07 PM | #4 |
Rep 10,407
Rebuild?
Most shocks are serviceable/rebuildable whether or not the factory/manufacturer claims that or not. Unless the shocks are quite expensive it will probably be less expensive to replace them rather than rebuild them. I'm not sure what your current shop rate is but mine is $90/hr. Rebuilding shocks is likely to be a skill most regular shops don't have. Fine work, getting very small parts crystal clean. Dealing with easy to damage and difficult to install seals, special tools, etc. Last but not least my OEM E36 M3 shocks lasted well over 100k miles. I would not feel too bad about replacing shocks on that type of schedule.
11-24-2007, 01:40 PM | #5 |
Rep 293
$574.74
Real OEM lists Rear Shock Absorber for M5 with EDC as $574.74 EDC control sensor is $525.64. Accelerating sensors price is not listed.
Perhaps this would give you an idea of the price for parts on the M3 with EDC shocks. Unsure how hard it is to tell if it's a bad shock or a bad sensor or accelerating sensor. |
11-24-2007, 05:01 PM | #6 | |
Rep 10,407
11-24-2007, 08:35 PM | #7 |
Rep 293
shocks
The price listed is for 2 shocks and a single control
01 SHOCK ABSORBER, REAR 2 33522283127 $574.74 02 HEX BOLT M14X105 ZNS 2 33506758105 $3.79 03 SPRING PAD LOWER 2 33532229913 $9.04 04 ADDITIONAL SHOCK ABSORBER, REAR 2 33532282524 $18.97 05 SUPPORTING CUP 2 33526758283 06 SPRING PAD UPPER 2 33532282767 $11.38 07 GUIDE SUPPORT 2 33522282766 $66.96 +core 08 SELF-LOCKING COLLAR NUT M8-8-ZNS 6 12/2006 31331092887 $0.56 08 SELF-LOCKING COLLAR NUT M8-8-ZNS3 6 07119904295 $0.30 09 PLATE 2 33521095030 $0.57 10 SELF-LOCKING HEX NUT M12X1,5 05 2 32211095267 $0.36 11 TUBING GUIDE 2 33526758888 12 EDC-K CONTROL UNIT 1 09/2005 37156767281 ENDED 12 EDC-K CONTROL UNIT 1 03/2007 37146773912 $525.64 13 BRACKET 1 37107835872 $32.09 14 CLIP 1 37146752824 $0.32 15 PLASTIC NUT M6 1 16131176747 $0.48 16 ACCELERATING SENSOR 2 04/2006 37146770204 $141.73 FRONT WHEEL ARCH 16 ACCELERATING SENSOR 2 37146776212 FRONT WHEEL ARCH 17 FILLISTER-HEAD SCREW M6X10 4 07119919962 $0.17 18 ACCELERATING SENSOR 1 05/2006 37146770205 $141.73 REAR WHEEL ARCH 18 ACCELERATING SENSOR 1 05/2006 37146776213 REAR WHEEL ARCH 19 HEX NUT 2 07119904030 20 UNIVERSAL SOCKET HOUSING UNCODED 3 POL. 1 61138365348 $1.95 ONLY IN CONJUNCTION WITH -- BUSHING CONTACT 0,2- 0,5MM ? 61130005199 $1.28 -- BUSHING CONTACT 0,75MM ? 61130006665 $1.12 22 UNIVERSAL SOCKET HOUSING UNCODED 18 POL. 1 61138364666 $0.39 ONLY IN CONJUNCTION WITH -- BUSHING CONTACT 0,2- 0,5MM ? 61130005197 $1.28 -- COVERING CAP 18 POL. ? 61138364662 $2.01 23 SOCKET HOUSING 10 POL./WEISS 1 61131383522 $5.30 ONLY IN CONJUNCTION WITH -- RUNDSTECKH 1,0-2,5MM ? 61131376204 $0.76 -- RUNDSTECKH 2,5-4,0MM ? 61131376206 $0.84 For comparison: a 2007 550i FOR VEHICLES WITH M SPORTS SUSPENSION S704A=YES 01 SHOCK ABSORBER, REAR 33527905315 $198.65 |
