12-04-2013, 06:33 AM | #1 |
Rep 591
Drives: E39 M5 & M6 Gran Coupe
Fitting the M-Performance Carbon Fibre shifter trim
Having looked for an install guide for the M-Performance shifter trim and failed, I thought I'd write up my experience.
First, the stock shifter and the parts that come in the kit P/N 61 31 2 343 709 The part is the same for left and right hand drive and common to the F06, F12, F13 and F10. The top plaque is a push fit and is also stuck on with double sided tape. I used a pair of plastic trim removal tools to pry it off. If you do it very carefully and slowly then you can re-use it, but a replacement is supplied so it's not the end of the world if you tear the tape or the glue comes off on the wrong part. Removing the top gives access to a small Torx screw which is at the bottom of a plastic part containing diffusers for the LEDs Once the Torx screw is removed the trim can be lifted off, it will probably come with the LED module and diffuser module. Gently remove the LED module from the back and the diffuser comes out of the front. Place the LED module back on the shifter, it locates in a small lug at the bottom. Put the new trim in place and re-insert the diffuser module, replace the Torx screw (a spare is supplied, no idea why really!) and stick the top plaque back on. Job done, total time including faffing about and taking the photos, about 5 minutes. It's a very good match with the rest of the trim as you'd expect. Even the angle of the weave is the same. The material and finish of the stock part looks very similar to the gear knobs on the early E39 M5's, plastic with a silvered coating. Those gear knobs suffered from the silvering coming off, I suspect that the DCT shift knob would suffer the same problem although it's not used as much as the manual gear lever. Hopefully the Carbon Fibre trim should be much more durable as well as looking good. |
12-04-2013, 02:03 PM | #2 |
Rep 248
Drives: 2013 E92 MW M3
Great DIY and that CF looks awesome.
12-04-2013, 02:31 PM | #4 |
Rep 591
List price is £177.50 +VAT, I paid £157.98 +VAT. Not cheap, but then you can sort of expect that for these cars!
12-04-2013, 05:50 PM | #6 |
Rep 2,183
Drives: .
Garage List 2018 Audi RSQ3 (8U) [0.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [0.00] |
You're so brave to do that! It came out very nicely..
12-05-2013, 12:52 AM | #8 |
Rep 277
Drives: 2014 M6 Gran Coupe
Looks good!
2014 M6 Gran Coupe-Alpine White/Blk
2015 740i Sapphire Blk/Blk 2018 Tahoe RST 6.2 2019 Porsche 911 Turbo 991.2 |
12-05-2013, 01:32 AM | #9 |
Rep 591
I bought it from http://www.bmminiparts.co.uk/ (I'm in the UK) it was ordered direct from Germany, arrived in about a week.
12-06-2013, 04:35 AM | #12 |
Rep 591
Just shy of 2K miles now, probably do nearly another 2K in the next 2 weeks by which time it will be officially run in!
02-23-2015, 08:21 PM | #13 |
Rep 365
I would proceed with caution here. I read that the plastic plaque doesn't sit as flush with the carbon piece as it does with the stock piece. There is a transition as oppose to being smooth. Sure enough - just installed mine and that is exactly the case. I'm gonna give it awhile and see if I can get used to it. It does look nice.
2015 ///X5M
2014 ///M6 (traded) 2014 ///M5 (traded) 2011 550i (traded) |
02-25-2015, 04:30 PM | #14 |
Rep 591
The radius on the Carbon Fibre piece on the edge that goes against the plaque is slightly larger than the stock piece, I'd guess this is just a characteristic of CF. There is a fractionally more noticeable transition between the two pieces, but to me it's not objectionable in any way, it does not leave a sharp edge for example.
02-25-2015, 06:52 PM | #15 | |
riding on rails
117
Rep 655
Oh well... I will sit tight until I hear people reporting it fits like a glove (might not ever happen lol). Brian
/// 2o13 m6 f13 . jb4 tuned . meth injected . msr intake . 21" adv1 wheels . eisenmann race w/ catless DPs . vorsteiner full aero . accuair e-level w/ bagged KW V3 struts . dinan sways . bel stir+ w/ alp jammer . jl audio subs
/// 2o13 x5m e70 . velos tuned . 22" adv1 wheels . dropped on kw variant3 coilovers . passport 9500ci radar & jammer. gets groceries fast |
03-02-2015, 09:19 PM | #16 | |
Rep 365
2015 ///X5M
